Question about HP Office Equipment & Supplies
Hp 3070a printer only printing red pink
Hp 3070a printer only printing pink redish shade ,all inks are showing half full
jackboy
  • 2985 Answers
SOURCE: Everything printing in PINK
Assuming you have successfully eliminated cartridge/print head problems, the only other thing to try is to delete the printer software and reinstall [Start/Printers and faxes -right click on the printer icon click delete- install new printer -Have the software disk and handy or select from list- select maker, select model,] I suspect the problem is still print head/cartridge however
Posted on May 11, 2007
Inkworks
  • 87 Answers
SOURCE: Red is printing pink.
have u used this printer quite a bit....? if so the following may be the problem and I just did run across this recently in a printer we had in the shop....I recently read in one of my technical magazines that there may be a design flaw in the placement of the laser scanners and the openings that protect them....it seems that excess toner dust can readily get in to scanner area and specifically inside the scanner assembly and accumalate on the scanner glass and lens. Just cleaning through the opening in the back of the printer will not eliminate the issue. Machine will have to be disassembled, scanner removed and opened and the glass/lens cleaned with a q-tip....the placement of the fan (behind cartridges, lower right) seems to speed this process up and it usually becomes first notable with the magenta cartridge, seeing as it is at the bottom of the printer closest to the fan. Hope this helps..
Inkworks
Posted on May 22, 2008
  • 30 Answers
SOURCE: Ink Cartridges
If is an original brand? Some generic cartridges or refill ones gave that problem.
Posted on Aug 19, 2008
  • 3 Answers
SOURCE: copies are coming out pink
Call Kodak Support at 1-800-421-6699. Sounds like your print head. They are excellent and solved my problem with next day supply of new print head and ink cartridges Free. Amazing service and great Kodak 5500 AIO printer.
Good luck.
Joe J
Posted on Aug 22, 2008
tstraub
SOURCE: Canon i960 printer won't print in blue
Your problem is the print head. You can buy one from Canon for about $95, or find them new from dealers on Ebay for $60 to $70. For a less expensive fix, try to remove the print head and clean it. (You don't need any tools, just remove the ink tanks and pull the print head forward and out. Over time, the receivers tend to get dry & crusted ink on them. Note that the inks used are fast drying inks to keep your pictures, etc. from smudging after you print them. Try not to use solvent. I use q-tips and hot water, then dry using another q-tip. If this does not work, there are commercial cleaning kits available for about $10. Short of that, your choice is to replace the print head or the printer itself. My i960 prints such good quality color prints and normal color printing, that I would fix it rather than replace the printer. I hope the easy cleaning does it for you!
Posted on Mar 07, 2009
A manual and troubleshooting guide for your printer can be found here.
May 05, 2008 | HP Color LaserJet 2600n Printer
When i am printing anything it is printing with a shade of pink
Hi, You are getting a pink shade in your printouts because your colour ink cartridge is running out of ink, it is probably time to change the colour ink cartridge.
Apr 12, 2011 | Kodak ESP 5 Printer
My HP printer is printing colours in a pink shade, can you please help.
Printers usually have three PRIMARY colours: YELLOW, PINK, BLUE.
So, if you have no YELLOW or BLUE ink, what's left is PINK.
Sep 17, 2010 | HP Office Equipment & Supplies
Print keeps fading, even though using new ink
check your printer settings, make sure color only is not checked off, or if you mainly print black and white documents, you should have that option checked, you may have to go into advance printer options to do this.
Apr 07, 2010 | HP Deskjet 3845 InkJet Printer
5100 HP Desktop printer--magenta ink comes out pink not red (right out of sealed package!)
magenta is just a fancy name for pink.... its usually a darker shade of pink not overly dark but not a bright pink that most associate with the color.
most hp printers use the ckmy color format as opposed to the rgb that most are used to. check your other ink levels to ensure that they are at least half full and when you print out a doc or pic requiring red, the other inks will assist in creating the proper shade
Mar 27, 2010 | HP Office Equipment & Supplies
Color now is pink, does this mean I should repace cartridge @HP D4160
yeah replace the color cartridge, first allign the cartridge if problem presists then change it
Oct 31, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Ink Cartridges
Jul 06, 2008 | HP DeskJet 5150 InkJet Printer
Inkworks
Oct 04, 2007 | HP Color LaserJet 2600n Printer
66 people viewed this question
Seeker5211
Seeker5211
