COMPUTER DOES NOT BOOT
COMPUTER COMES ON AND FANS (PS & CPU) RUN AND THEN AFTER A FEW SECONDS COMPUTER SHUTS DOWN . P4VMM2
MOTHERBOARD
    President:
  • 2,692 Answers
If nothing was disturbed then this is usually an indication of either the power supply going bad or the hard driver going bad. I start by substituting a power supply of the same wattage or larger. If that doens't work , I change out the hard driver.  I believe that is usually a good place to start.
Posted on Jan 05, 2009
Toshiba A135-S4527 starts to power up then shuts down.
When the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a small brush and can of compressed airto do this.
Mar 08, 2012 | Toshiba Satellite A135-S4527 Notebook
I turn on the computer and it may run some times for about 10 or 15 min. and then shut down i was wondering if i need a bio's update or what i have two hard drives in the computer xp pro on 1 and vista...
It could be overheating. After it shuts down, restart it, and enter BIOS SETUP, and look for a "PC Health" or "Status" entry on the menu. If you're lucky, it will report the current CPU temperature, and the speed of the fans, and the settable temperature at which it will shut itself down.
Check the capacitors on the motherboard -- any capacitor with a "dome" on top, instead of perfectly-flat, is a leaking capacitor that is intermittently failing.
Jul 19, 2011 | Mach Speed (MSNV-939) Motherboard
When I turn on my computer it runs for a couple of seconds and then stops.
Unplug everything inside the computer, except the motherboard and the front panel power on switch. Power up the computer. If the PS fan continues to run, (power supply doesn't shut down)and the CPU fan runs, then power off the unit and reinstall each device, one at a time, turn the power supply on after each device is installed (and off, before installing the next device).
You can not easily start the power supply if it is not connected to the cpu motherboard.
If the power supply shuts down with only the motherboard attached, then you will need either another power supply, to test the MB, or another MB to test the power supply.
R
Feb 02, 2011 | Acer DPS-420GB (dps420gb) Power Supply
Computer will not boot. It makes a few sounds and fans run
Was it working prop in first place, shutting down properly when last used?
What prog are u running. XP/Vista?
Nov 01, 2009 | MSI PM8M-V Socket...
Cannot get new Motherboard to boot up in Normal Mode
what u may have done is wwhen u were installing the new board, gave a static shock to the system...that will cause only the fans to come on and nothing more...this is a bad problem bc u cannot fix it...if u figure out something else is wrong, and it gets fixed, let me know
Jun 20, 2009 | Gateway Computers & Internet
Nvidia gedorce 8500 gt and the cpu gets overheated and shuts down
well it might be over clocked, but i have a computer with 4 fans and cpu fan and other fans to. though this still doesnt make a difference casue my cpu still heats up. so get a liquid cooling system, expensive i knw but it will keep your computer running, but you coudl also try cleaning you computer out. Like all of the dust and everything
Apr 26, 2009 | XFX NVIDIA GeForce 8500 Graphic Card
Computer does not boot
If you computer over heated, this could have caused the board or power supply to short. I would first start by trying a new power supply unit (since this is cheapest of the options). If that does not work then try replacing the motherboard and/or processor. Since you not getting any power, my guess is motherboard or power supply unit.
Apr 20, 2009 | Intel Desktop Board D845PEBT2 Motherboard
VIDeo CARD not working
You will need drivers for the FX5000 first, disable the driver for the one your using, shut down and then install the new FX5000, boot up and wait until the VGA comes on, it can take several mins sometimes.
Sep 26, 2008 | EliteGroup P4VMM2 Motherboard
Computers & Internet Logo
516 people viewed this question
David Payne
David Payne
