Home | Sony | DVP-NS315 DVD Player | Cannot play error
Sony DVP-NS315 DVD Player
Problem for Sony DVP-NS315 DVD Player
Cannot play error
By Dan from MA on Jan 04, 2009
I try to pay a dvd and the "cannot play disc" error comes up. Played a dvd just two nights previous.Same Problem - any dvd I try won't play. worked fine a few days ago (last time I played a disk it worked fine).
Solution #1
posted on Jan 04, 2009
Not Rated)
Benimur
Rank: Guru  Sony Expert
Rating: 88%, 3768 votes
Hi and welcome to FixYa,
Initially, possibly dirty or weak laser/optics. Try to use a CD disc cleaner.
Good luck and Thank you for using FixYa.
Solution #2
Not Rated)
Dipu007
Rank: Wiz  Sony Expert
Rating: 80%, 917 votes
Sorry You need to replace the player as it is under warranty...
Solution #3
Not Rated)
technodeal
Rank: Wiz
Rating: 71%, 52 votes
its the problem of dirty lens in the payer which needs cleaning or the motor which spins the disk internally is getting blocked internally so it needs servicing.
Solution #4
Not Rated)
Ronnieh49
Rating: 82%, 1571 votes
you need to run a disk cleaner through it.they are only a few dollars and look just like a cd but has small brushes on it to clean the lense
Solution #5
Not Rated)
Ekse
Rating: 88%, 4676 votes
I mostly first always recommend a dvd lens cleaner to clean the lens incase there is something on the lens.
Is the player underwarranty? the lens may have a issue other than dirt and might need to be replaced.
What happened last time it worked fine? try unpluging the dvd player for 5 minutes and try again.
Popular Solutions for Sony DVP-NS315 DVD Player
Questions and Unsolved Problems for Sony DVP-NS315 DVD Player
Do you recommend Sony DVP-NS315 DVD Player?
Answer
Answer
A friend give me this dvd but with no remote or manaul i need to know how to hook up and to use
Answer
After working great for years, my dvd player suddenly won't turn on. When I press power, the player... (More)
Answer
my dvd player says, 'cannot play disc'
Answer
my sony dvp-ns315 has a power light flashing red and green intermittently, if i hit power over and... (More)
Answer
my sony dvd player stopped playing in color anybody no why
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Sony DVP-NS315 DVD Player:
Top DVD Player Experts
Rank: Guru Guru
Solutions: 689
Experience: 30 Years of professional repair and design.
Ask Me
Find more DVD Player Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
