Question about Xerox WorkCentre 3550 Laser Multifunction Printer - Monochrome - Plain
Xerox workcentre 3550 displays offline mode - Xerox WorkCentre 3550 Laser Multifunction Printer - Monochrome - Plain
  • 3 Answers
SOURCE: Xerox WC Pro 35 - Error 14-563
this code means your scanner has failed to setup correctly. this could be a problem that you would need a qualified tech to service the copier. there is nothing that you can do after you power off and power on (popo) the copier. it could be voltage, pwb board, or a binding scanner assembly.
Posted on Oct 07, 2008
  • 24 Answers
SOURCE: Need to enter service mode on a Xerox 7435
The service tech should do this. The 7435 should be less than 3 months old, and Xerox should fix it. If you bought it from Global, or another company that does not actually employ Xerox technicians, try appealing to them, but I cannot tell you for sure what the outcome will be. Buying from an authorized agency ensures that you can use your "Total Satisfaction Guarantee".
Posted on Jun 10, 2009
  • 24 Answers
SOURCE: Service Manual for Xerox WorkCentre m55. URGENT!
Does this link help?
http://www.support.xerox.com/go/results.asp?Xtype=docs&prodID=WC_M55&Xlang=en_US&Xcntry=USA
  • 990 Answers
SOURCE: xerox docucolor 3535 displays offline mode
Hello sir; Turn power off for 30 seconds then turn back on let it get online.
Posted on Sep 19, 2009
  • 17 Answers
SOURCE: Need printer driver for Windows Vista 64 bits for Xerox WorkCentr
http://www.support.xerox.com/go/results.asp?Xlang=en_US&XCntry=USA&prodID=GLOBALPRINTDRIVER&ripId=&Xtype=download
You can try this driver. It may be quirky at first but it should work for basic printing needs. There is a PCL6 and post script try both sometimes it will take one but not the other. Its vista flip a coin :) -Phil
Posted on Apr 03, 2010
How do I change the cartridge region from a xerox workcentre 3550
The toner cartridges have a small CRUM chip fixed on the end of each tube. If you change them from a previously empty cartridge then it will still show empty. You just can't fool them.
Good Luck.
Jul 14, 2014 | Xerox Corporation WorkCentre 3550 Laser...
My workcentre 3550 multifunction printer is constantly printing the configuration report, how do i fix that?
Anthony,
I'll assume your printer is wasting paper.
Firstly remove the paper, that should stop it, then try and enter Centreware, check the www.Xerox.com website as to how to do that. From there you will have more control from there.
Replace the paper as a check, and hopefully the problem will be sorted.
Good Luck.
May 24, 2014 | Xerox Corporation WorkCentre 3550 Laser...
Xerox Workcentre C226 - Error H5-01
This might help, but I don't know how to put it in tech mode.
"The fuser error reset code will reset the machine so it will run after the problem is fixed.First remove any jam in the fuser then enter tech mode;
press program, * ,clear, * enter 1 4 press start then turn machine off and then back on."
Jul 29, 2009 | Office Equipment & Supplies
I need to restore NVRAM from the WorkCentre 2424.
1. From the System Setup menu, go to Information --> Troubleshooting --> Service Tools menu.
2. With the cursor at the top of the Service Tools menu, press both the Up Arrow and Down Arrow buttons to display the Hidden Service menu.
3. Reset NVRAM is in there
If that doesnt work try below.
1. Turn the system power ON.
2. Wait for the Xerox logo to begin moving across the display.
3. Before the logo is centered on the display (stops moving), press and hold the Back and Info buttons on the control panel.
4. Hold both buttons until the display reads 'Beginning Service Mode Initialization'. Release the buttons and the system reboots into service mode with the Service Diagnostics menu displayed. You should find it in the function sub menu.
Jul 16, 2009 | Xerox WorkCentre C2424DN All-In-One Laser...
Xerox Workcentre Pro 416 P
This would be the first thing to try..
  • Press the 0 and 8 keys simultaneously and switch on.
  • Input 400 using the numeric keys, and press the enter key.
  • Change displayed status counter to 0, and press the enter key.
  • Switch the machine off then on. Check that the machine returns to the normal standby mode. If the machine does not return to normal standby mode, perform the following checks.
  • Feb 18, 2008 | Xerox WorkCentre Pro 416 All-In-One Laser...
    Xerox WorkCentre 3550 Laser Multifunction Printer - Monochrome - Plain Logo
    159 people viewed this question
    Top Xerox Office Equipment & Supplies Experts
    Michel
    Xeroxrep
    Level 1 Expert
    Philip Hughes
    Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
