Question about Samsung Refrigerators
Not defrosting circuit diagram
    Top Expert:
  • Samsung Master
  • 9,472 Answers
What is the model number of the unit?
Posted on Nov 04, 2012
Looking for a diagram of heater control valve vacuum lines on a 2003 GMC Envoy with a 5.3 engine
There are no vacuum lines for the HVAC , electroniclly controlled .
Mode Actuator
The mode actuator is an electronic stepper motor with feedback potentiometers. The HVAC control module sends signals to the mode door actuator through the mode door control circuit. Zero volts drives the actuator in one direction while 5-volts moves the actuator in the opposite direction. When the actuator receives 2.5 volts, the actuator rotation stops. A 5-volt reference signal is sent out over the 5-volt reference circuit to the mode actuator. When you select a desired mode setting, logic determines the value of the mode actuator signals. The HVAC control module's software uses this reference voltage in order to determine the position of the mode actuator through the mode door position signal circuit. The motor moves the mode door to the desired position.
Defrost Actuator
The defrost actuator operates the same as the mode actuator. The HVAC control module sends signals to the mode door actuator through the defrost door control circuit. Zero volts drives the actuator in one direction while 5-volts moves the actuator in the opposite direction. When the actuator receives 2.5 volts, the actuator rotation stops. A 5-volt reference signal is sent out over the 5-volt reference circuit to the defrost actuator. When you select a defrost setting, logic determines the value of the defrost actuator signals. The HVAC control module's software uses this reference voltage in order to determine the position of the mode actuator through the defrost door position signal circuit. The motor moves the defrost door to the desired position.
Feb 24, 2017 | GMC Cars & Trucks
My rear wiper, defroster and licence plate lights stopped working on my 2007 suzuki swift but when I open the rear hatch the licence plate lights come on . Any ideas what's wrong?bad ground?
[PDF]Wiring Diagram.pdf - Ken Gilbert
ken-gilbert.com/wrx/mans/99.../Wiring%20Diagram.pdf
Each connector number shown in the wiring dia- ... Rear defogger cord (Ground). Fuel tank cord,. Roof cord, ... circuit. Then check the switch, relay, fuse, ground, etc. 4. .....Rear wiper motor. Rear wiper ... License plate light RH. Tail light LH.
#? license plate light - Circuit Wiring Diagrams
circuitswiring.com/tag/license-plate-light/
2008 Volkswagen Newbeetle Main Fuse Box Diagram 2008 Volkswagen Newbeetle ...Parts: rear window defogger, shift lock, battery positive voltage, interior light, A/C clutch, ... brake light, daytime driving light, wiper and washer system, vacan, fuel pump, central ... 1997 Suzuki Geo Tracker Left Dash Fuse Box Diagram.
#? license plate light - Circuit Wiring Diagrams - Page 3
circuitswiring.com/tag/license-plate-light/page/3/
Audi A4 Engine Fuse Box Diagram Audi A4 Engine Fuse Box Map Fuse Panel ... mirror control, wiper, washer, horn, brake light, cruise control, heated rear window, ... 2003Suzuki Aerio Dash Fuse Box Diagram 2003 Suzuki Aerio Dash Fuse Box ... rear defroster, fuel injection controller, radio, A/T controller, hazard light, ...
Jan 05, 2016 | Suzuki Cars & Trucks
My rear defrost doesn't work what can be the problem
Possibly a relay ! If you go to www.bbbind.com/ you can find free wiring diagrams to see what all is involved in that circuit . Then you can go to youtube an search rear defroster not working , you will find videos on how to test the circuit . You mite also check out basic electrical trouble shooting videos . good luck , hope this helps
Nov 24, 2015 | Cars & Trucks
Ge Wiring Diagram
Request the wiring diagram directly from GE.
Oct 24, 2017 | GE Refrigerators
Refrigeration ynit not going into defrost, I need a electrical wiring diagram to help me troubleshoot this one. Where can I get that?
See defrost timers and wiring diagrams and manuals
http://waterheatertimer.org/Paragon-timers-and-manuals.html#defrost
You posted under 8145-20
8145-20 is time initiated, temperature or pressure terminated.
Defrost timer training pdf
The 8145-20 timer:
Power leads connect to terminals 1 and N.
For 120Volt circuit: L is black hot wire to terminal 1, N is white neutral wire to terminal N
For 240Volt circuit: L1 and L2 are the hot leads from 240V breaker
'NO' means normally open, so terminal 3 turns ON only when timer turns on (that is 'time initiated')
So the hot gas valve for defrosting is connected to terminal 3 and turns ON when timer turns ON.
The other wire from hot gas valve connects to terminal N where it completes the circuit
'NC' means normally closed, so terminal 4 is ON at all times EXCEPT when timer turns ON.
That means fan is ON all the time, except when time initiated sequence begins, and then fan turns OFF while hot gas valve is defrosting unit.
The other wire from fan connects to terminal N where it completes the circuit
The cycle limit switch is connected to terminal X.
This is the switch that terminates the defrost sequence and turns timer OFF
Other wire from cycle limit switch connects to terminal N where it completes the circuit
I also suggest you ask a paid fixya experts who can provide additional information by phone.
Paid experts will not answer your question unless they know the answer, and if their answer is not complete, then fixya offers money back guarantee.
Dec 15, 2010 | Paragon 8145-20 Defrost Timer
On a Paragon 8145-20 Defrost Timer, I know you land the refrigeration circuit on terminal 4, the heater on terminal 3, but what goes on terminal "X" and terminal "N"
Link below has 8145-20 wiring diagram:
Terminal N is 2nd wire needed to complete circuit.
In 240V 8145-20, there are two hot wires.
One Hot connects to terminal 1, with jumper to terminal 2.
Second Hot connects to terminal N, and this will power the clock motor and timer.
Terminal X is for temperature or pressure termination switch.
Defrost cycle works like this:
Timer is running but switched OFF.
Refrigeration fan is ON.
Timer switches ON, defrost cycle begins.
Refrigeration fan turns OFF.
Hot gas defrost turns ON.
When temperature-or-pressure limit switch reaches trip point, it switches timer OFF.
Refrigeration fan turns ON again.
Hot gas defrost turns OFF.
Aug 01, 2010 | Paragon 8145-20 Defrost Timer
Need a wiring diagram for a Whirlpool ED5VHEXTQO1 Refrigerator to diagnose the defrost circuit, ref not defrosting
I will give the wiring diagram a try but your refrigerator has a simple defrost timer that is most likely the reason for your problem. Give me a few moments and I will give you a photo. Inside the fresh food compartment and behind the control panel is where the timer is located. Sea Breeze
Oct 22, 2009 | Refrigerators
Westinghouse Virtuoso Fridge - Circuit Diagram
It won't be the defrost timer, unusual, it will be the defrost element inside the freezer section behind the back panel or a shorted defrost klixon.
Mar 30, 2008 | Refrigerators
Circuit diagram for WEstinghouse Virtuoso Side by Side Fridge
It helps us to help you if we have a model number to work with. I have a site called www.mymarcone.com that if I have a model number, I can look up virtually ANY appliance diagram. Please post on this again with a model number and I will do my best to help you.
Freezer stops working for no reason
sounds like a defrost issue, see if theres a wire diagram id ck your heater/defrost circuit
Feb 23, 2008 | Refrigerators
Refrigerators Logo
41 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
