Question about Jwin JD-VD135 DVD Player
JWIN DVD player horizontal control
DVDs played fine until recently, then the screen began to flip horizontally, even when no DVD loaded, the JWIN screen flips continuously, makes me wish for the predigital age when I could turn a knob to control the horizontal flip. Regular TV programs and VCR works fine. All advice is welcome, even if it is to junk the DVD player. Thanks
  • Anonymous Dec 20, 2008
    The DVD player has a problem with both horizontal and vertical roll. Need help if possible since there is no internal adjustment.
I had this problem and pressed all the keys until I hit the SYSTEM button on the remote control. All was fixed.
Posted on Aug 25, 2008
Power ON DVD, horizontal lines running on the TV screen. How do I get the horizontal lines to stop running and for me to view the screen to possible reset the DVD player.
Check video plugin to see if connect good on both tv and dvd player. You might try unplugging and re plug. If that doesn't help you might try another plug wire not sure if you have rca or HDMI plugs.
May 14, 2015 | Jwin Electronics JD-VD138 DVD Player
Disc play interrupted
I recomend that you clean the lens to see if that makes a difference.
Also you might want to look at my Tip on dealing with DVD's that jump.
Apr 05, 2010 | Mintek DVD-2580 DVD Player
Dvd's aren't fitting my screen, the sides and top/bottom is being cut of. I've tried the display menu, zoom, and making it widescreen, and it doesn't work.
Are you playing wide-screen movies on a 4x3=1.33:1 (standard=SD) TV? DVD output by default is SD. Even 16x9=1.78:1 (HD) movies with have top and bottom bars. Many "wide-screen" DVDs are squeezed horizontally so that you have to stretch them. Many theatrical releases are up to 2.7:1 or so. Side bars indicate you have the DVD output set for 4x3 and your TV is HD-like. There are usually controls for the screen format on HD TVs--no controls on SD TV. Hey, early movies were 1:1--take them side bars. More on aspect ratio (AR) in Wiki, I bet. With letterbox of SD you can get "pillar box" with black on all 4 side. Get a better source and/or choose a different AR. -Ken
Jul 15, 2009 | Pioneer DV-400V DVD Player
Dvd disc is not recognised after loading
i would like the code for this jd-vd141 dvd player
Oct 09, 2008 | Jwin JD-VD141 DVD Player
Won't play DVDs from asia .. need region code unlock.. help.
1- Open tray
2- Press setup
3- Press 1 3 8 9
4- Use Up/Down key from remote control to change the Region
5- Press setup
Apr 03, 2008 | Jwin JD-VD135 DVD Player
Denon 3910 won't load some dvds/cds and vibrates while trying.."disc error"!
I have the Denon 2900 (about 4 years of use) and until recently, suffered from the same (growing) problem. CD's were very difficult to start/read. I recently found advice which I tried and was succesful with. It was manually cleaning the laserlens. I took away the outer housing by unscrewing all off the on top (6), side (4) and the back (2) bolts. After that I took out the top plate of the laserunit which took two very little screws taking out. Now you are looking at the cd-tray with the lens. Take a very soft and clean cloth and moisten it a little bit with clean water (be very carefull with the moistening, don't allow any waterdrop to come out of the cloth into the laserlens while cleaning! Carefully clean the lens and dry it with a dry part of the same cloth. Replace the top plate and the outer housing and the player will recognize the discs like it's new again. Good luck! Robert Jan, The Hague the Netherlands
Dec 25, 2007 | Denon DVD-3910 DVD Player
Playing PAL system dvds
Turn unit power on
with dvd draw closed and with no disc
press 9735
hidden menu appears
select REGION 0
exit setup
for multi zone compatibility and enjoy...
Sep 21, 2007 | Jwin JD-VD149 DVD Player
Plays CDs but not DVDs
I had the same problem, don't try to hard it won't solve the problem. Just buy a new cheap one and it even will read more formats.
Mar 12, 2007 | Panasonic DVD-RV31 DVD Player
Jwin JD-VD135 DVD Player Logo
148 people viewed this question
Top Jwin Televison & Video Experts
Jaime Hernandez
Sheldon Dedek
Raj Patel
Are you a Jwin Televison and Video Expert? Answer questions, earn points and help others
