Zanussi turbodry 1000 w1042w will not spin - Washing Machines
kjmac
  • 97 Answers
SOURCE: Zanussi Turbodry jetsystem 1200
hiya
e90 means there is a communication error between the circuit boards inside. remove the plug then take the lid off the machine, remove the block which has the 5 (iirc) blue wires in it and give it a quick squeeze then replace, this should hopefully solve your problem.
hope this helps
please dont forget to rate the helpfulness of this reply, thanks kj
Posted on Aug 03, 2008
gittos73
  • 244 Answers
SOURCE: zanussi Turbodry 1200 spin problem
if this washer is used alot then it will more then likely be the carbon brushes which u will need to take the lid off undue 4screws out where it joins front to the back screws at the back to the bottom and 1screw either side of the bottom where the panels join together behind a little cap which will have an hole in the middle of it to get it out u will then be able to get to the motor to replace the carbon brushes
Posted on Nov 25, 2008
  • 17 Answers
SOURCE: What is E 40 on Zanussi Turbodry 1200?
E40 indicates the doors not closed properly. Sometimes it can be the lock itself or the main control board
Posted on Dec 17, 2008
  • 135 Answers
SOURCE: Washing Machine trips circuit breaker when Drying
This will be the dryer heating element needs replacing.
Hope this helps.
Posted on Jan 22, 2009
  • 57 Answers
SOURCE: zanussi jetsystem turbodry 1200 door wont open
its the doorcatch,turn power off, remove lid and put hand in machine where doorlock is situated feel about and try open catch, repair or replace?
Posted on Jun 24, 2009
Wont spin.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Apr 16, 2011 | Zanussi W1042W Front Load Washer
Hi i need a manual in english for zanussi 1140m am in denmark but only read and speak engish
Hi!!
Try the following link to download your manual. http://www.nodevice.com/user_manual/zanussi/washing_machine5/w1042w.html
Scroll down, enter the code on the box and click DOWNLOAD
Good Luck!! A HELPFUL - 4 THUMBS - rating for this solution would be greatly appreciated. Thank you for using FixYa!!
Feb 16, 2011 | Zanussi W1042W Front Load Washer
Zanussi turbodry 1000 W1042W doesn't spin or empty the spin water. Help. I've taken the back off and one of the sides. It's on its side now lying on the floor. I replaced the big belt a year ago and that's...
Sounds like a blockage in the sump pipe to drain pump or something stuck in the drain pump or drain outlet blocked.Lack of fluff depends on the type of wash not that suspicious.Be careful when lying the machine on its side never lie it on the side the programmer is on as water can get into the electrics.Can you hear the pump turning when you put knob to spin/drain or just a buzzing if latter then the pump is jammed or faulty either way it will need investigating.
Hope this helps.
May 28, 2010 | Washing Machines
Zanussi jetstream 1000 turbodry door remained locked this morning. Emptied machine through filter port and cleaned filter. Door opened ok. Machine will now not start any program although the power light...
the drain pump is jammed .........remove the filter at the bottom left of the machine get down and look in the hole and you will likeley find something in there if not you need a new pump
Feb 26, 2010 | Zanussi FJS1225W Front Load Washer
Hope this helps.
Jan 21, 2009 | Zanussi WDA1055W Front Load Washer / Dryer
Nov 24, 2008 | Zanussi FJS1225W Front Load Washer
Zanussi Turbodry 1200 spin problem
Nov 22, 2008 | Zanussi ZJD1219 Front Load Washer / Dryer
Zanussi jetsystem Turbodry 1200
It appears that you may have a faulty door interlock or a faulty PCB. pcb is not really a DIY job as some boards require proramming on certain versions. Regards Advisor
Oct 30, 2006 | Zanussi FJS1225W Front Load Washer
Washing Machines Logo
29 people viewed this question
Top Washing Machines Experts
