Question about HP LaserJet 1022 Printer
Hp 1022 printer installation error showing error 0x000006be
    Habit-Forming:
    New Friend:
  • HP Expert
  • 21 Answers
Check if you are using the latest version of your printer driver and software.
If this does not resolve the problem, roll-back or install the last working version of the printer driver.
Ensure that you are using the latest version of your operating system, printer firmware and software.
123 hp com Quick HP Printers Setup Easy Installation Guidelines
Posted on Jan 05, 2018
3 Suggested Answers
fredtmccoyjr
  • 380 Answers
SOURCE: I have installed Windows 7 now How to connect HP
When you installed Win7, did you upgrade or did you do a Clean install? If you performed an upgrade, you may have the problem with older conflicting drivers and services. Read this to see what I mean. http://members.shaw.ca/bsanders/CleanPrinterDrivers.htm
Posted on Jul 20, 2009
n25an
  • 622 Answers
SOURCE: I have HP LaserJet 1020 CD, but when installing
ok... this is a bit complicated but check the link below and it goes into what needs to be done...
http://forums.techarena.in/vista-print-fax/671244.htm
Posted on Dec 31, 2009
Hp 1018 printer installation error showing error 0x000006be
Try updating your driver and printer software.
If this does not help, roll-back or install the last working version of the printer.
Make sure that your are using the most recent version of your Operating system, printer firmware and software.
123 HP COM Setup Printer Quick Setup and Install Support
Dec 16, 2013 | HP LaserJet 1018 Printer
Operation failed with error 0x000006be
http://www.vistax64.com/vista-print-fax-scan/34406-printer-installation-error-0x000006be.html
all explained at above post essentially you need to download the right drivers, and ensure print spooler is enabled too.
May 12, 2011 | Office Equipment & Supplies
LaserJet 1022 Printer: After installation Hp laser 1022 printer itts show...
Make sure the cable from your printer is properly connected to the CPU
Make sure it is well recognized.
On start menu, click printer and faxes..
you will see your printer model.(if you said its offline then the image of your printer is blurred...right?)
Now right click on the printer model.. and click the "Use Printer Online"
After that you will see that the image of your printer is clear with the word "ready"
Try to print again.
May 16, 2010 | HP LaserJet 1022 Printer
I have HP LaserJet 1020 CD, but when installing there comes an error message (0x000006be). Help me install the printer correctly
Dec 31, 2009 | HP LaserJet 1020 Printer
I have installed Windows 7 now How to connect HP Laser Jet 1022 printer installed at windows xp in lan network. being connect to it, got an error ''Operation failed with error 0x000006be''
Jul 20, 2009 | HP Office Equipment & Supplies
I need to know how to re-install my HP Laser
go to the printers folder, click add printer then ok and let the machine search for plug and play printers, you may need the installation disk for the printer. you also can go to add hardware in the control panel and use the manual install printer.add new hardware, select printer.select manually install printer and select it from the dropdown menu. if you are lucky it will be in the list
Jul 13, 2009 | HP LaserJet 1022 Printer
Trying to install a print hp 1022 to my laptop which uses vista
Go www.hp.com and let the website auto-detect your printer and download the drivers automatically.
Jan 18, 2009 | HP LaserJet 1022 Printer
Can not get a hp lj 1022 installed
Go to www.hp.com and let the website auto-detect your printer and down load the drivers automatically
Jan 16, 2009 | HP LaserJet 1022 Printer
52 scanner error turn off and on is displayed in the contoll panel,the same thing is again displayed if i turned off and on also nothing can be printed due to this displey. please help
The printer has burned a scanner assembly. The part number is RM1-2033-030CN. The part is extremely expensive in relation to the printer cost. ($182.00 @ HP)
I would recommend surfing ebay for an HP Laserjet 1022 printer as it is the cheapest printer that has the same scanner. Even a dead 1022 will work as they tend to either have formatter or fuser issues when dead. A scanner error on your printer or the 1022 is extremely rare.
I have included a link to the HP 3050 service manual for you that will walk you through it step by step. The teardown is significant however very do-able by the novice with the service manual.
http://h20181.www2.hp.com/plmcontent/NACSC/Printers/LaserJet/30328_020806/course/library/service/service.html
Good luck, You can do it.
Jul 09, 2008 | HP LaserJet 3050 All-In-One Printer
HP 1020/1022 PRINTER OFFLINE
No drivers / Incorrect driver setup on user pc
Oct 19, 2007 | HP LaserJet 1020 Printer
HP LaserJet 1022 Printer Logo
135 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
