Question about GPS
I have a uniden igo50 and cannot connect it to my computer it keeps coming up usb device not recognised
RAC_ICS
  • 143 Answers
SOURCE: PC does not recognise TomTom
Dont use a HUB, connect it directly to the PC.
Reset the unit by pushing a bent paperclip or pin into the hole on the bottom marked 'reset' turn it back on, plug it in & charge it via USB overnight or as long as you can in the car, make sure the led on the top is green, tap the bottom right of the screen & check the battery symbol on the unit says charging underneath.
If this doesn't help.
contact them about the problem...
http://www.tomtom.com/support/support.php?ID=2
Posted on Dec 16, 2007
SOURCE: cannot communicate with pc/ laptop. device is not recognised
I had the same problem and sure enough the cord with the screw in it was upside down.
Amazing what connecting the unit properly will do...
Posted on Jun 24, 2008
SOURCE: trying to connect tomtom 910
pressed RESET button on TomTom & usb device then recognised.
Posted on Jul 17, 2008
SOURCE: usb device not recognised by pc
will not connect or connect?
Posted on Jul 23, 2008
  • 37 Answers
SOURCE: flashing red cross on tom tom go 510
If the unit is giving you yelow message like a warning can be the charging connector .Fix That problem first and after fix the software isue.
If you dont knoe how just send it to a repiar centre .
Try this one www.satnavservice.com
Posted on Aug 29, 2009
Testimonial: "thanks - will have to do that I think. Hopefully cheaper than buying anew one ."
Why doesn't scanner recognise usb connection
What type of device are you trying to connect to the scanner? The USB connection might not be working because the scanner can't register the device. It might also be a bad USB port. Have you tried a different device in that same port?
Elisa Jed ' http://www.azvalleygeeks.com
Jun 23, 2014 | Computers & Internet
Printer and computer not communicating
Reinstall the printer drivers again and see if the problem corrects itself or if you prefer roll the computer back to when the printer worked using System Restore. If this fails to correct the Issue time may have come for a printer upgrade unless this is a high end business printer, then have it repaired, home units are dirt cheap right now.
Mar 16, 2017 | HP LaserJet 1100 Printer
How to update map
I helped a buddy update his Uniden GPS (Trax350). Simply follow these steps and you should be done.
Uniden's MapTrax350 GPS device accepts voice-command programming and provides detailed audio commands, as well, speaking aloud the map directions that are displayed on its screen. Keeping your Trax350's firmware updated is crucial to keeping it working correctly. Usually, you can go to a company's website and download the latest software, but with Uniden, you must register your product first to access the proper free upgrades. It takes minutes.
Instructions
things you'll need: USB cable
1 Navigate to the link in the Resources section and fill in the required fields. Click on "Register."
2 Turn on your device and connect it to the computer using its USB cable.
3 Log in to the site with the password that was sent to your email address after you registered the device.
4 Choose "Software Upgrades." Select the MapTrax350 device, and the latest firmware upgrade will appear. Click "Download."
5 Select "Save File" and choose a location on your computer to save it to. After it has downloaded, double-click the program icon, select "Run" and follow the prompts to update your Trax350.
Mar 21, 2011 | Uniden GPS
Brother printer will not recognise usb cable I can load printer onto laptop through usb cable now want to load onto dell pentium 4 and keeps coming up does not recognise usb cable so keeps asking you to...
Try a new cable and a different USB port. It's possible dirt is making for a bad connection or that the cable is slightly damaged and this other computer is more sensitive to the problem.
I hope this helps.
(who has dealt with a damaged USB cable that didn't look bad and gave an intermittent problem with one computer and associated hardware.)
Apr 10, 2010 | Brother DCP 115C All-In-One InkJet Printer
My cruzer 4 mb usb stick is suddenly not recognized by the computer
this may have many causes. first possibility: the stick is dead and needs replacement. second: there may be a problem with the usb-port or -controller. if you connect a different usb device to the same port as the stick, and it's recognised, the usb- port is fine and it surely will be the stick which is broken. if the other device isn't recognised either, it's a usb related problem. in this case you should verify if all settings for usb in the BIOS are enabled, if the usb-controller in device manager has been installed supposedly. if not, reinstall, reboot and try again. if this does not work, you need to replace your computer's system board
Oct 22, 2009 | SanDisk Computers & Internet
"USB DEVICE NOT RECOGNISED"
Try this first...
  1. Unplug everything connect to a USB port on your PC.
  2. Open up the device manager (in Start/Run/devmgmt.msc)
  3. Click on the + next to ''Universal Serial Bus Controllers'' to expand it.
  4. Right-click on each item in the list and select ''Uninstall''.
  5. Once all items listed under ''Universal Serial Bus Controllers'' have been uninstalled; restart the system.
  6. Once the computer restarts and comes up to the desktop, plug your USB devices back in one at a time. You should see a ''New Hardware Found'' message in the lower right corner of the screen. After you do this you should get your devices back. If not then most likely your USB device or the USB controller on your motherboard are bad.
Otherwise, it may have finally died on you. USB flash drives are not as durable as internal drives on your computer and will fail if used a lot, a lot sooner than the bigger drives. If you can somehow get your computer to recognize it, copy all data you can off of your drive and any files you have problem with, I recommend you install data recovery software Recuva by Piriform and attempt to recover any data you can on it if it will allow you to.
Aug 31, 2009 | SimpleTech SimpleDrive Pininfarina 500GB...
Usb problem
absolutely no idea but mine does the same thing....works ok on my sisters non dell computer.......
May 02, 2007 | Tatung Elio Photo JukeBox MP3 Player
GPS Logo
61 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
