KVM switch and Desktop Monitor Issue
I had the desktop computer and laptop successfully working through a KVM switch, but when I changed the resolution on the monitor through the desktop computer, the monitor blanked out and gave me the message that "Input Signal Out of Range." I unplugged the monitor from the KVM switch and plugged it directly into the computer and it worked fine, so I tried to fix the resolution while it was directly plugged in, but now I get no signal from the desktop to the monitor. I tried to reset the monitor to factory settings from the menu of the monitor, but nothing happened. Under the information menu on the monitor it states that the current setting is 1152 x 864 and recommends 1680 x 1050 60hz. Any help anyone can provide would be great.
3 Suggested Answers
riceski
  • 1851 Answers
SOURCE: KVM Switch Issue
There is a natural order of things in pc's. It sounds to me like you may have an issue with the pc being just quicker than the lap top and it is loading in a hodge podge way.
I wish I could help you more but I would try going to a ps2 mouse and keyboard if you have the usb type and if not swap these two out as these must pass before the unit will even boot. Also - do you have a slave drive marked cable select? These things upset a delicate balance. I would also email the maker and see if they can help.
For a more definitive answer please send the make - model and operating systems on each pc - lap and desk - also have you done all your updates? Try updating the driver on the KVM website as well. These issues usually are a small matter to get lined out.
Let me know how it goes and send ur pc info
Gary
riceski@gmail.com
Posted on Feb 04, 2010
  • 52 Answers
SOURCE: I have been using my
This almost sounds like the display setting on your laptop was changed to an external device. Most laptops are designed to be hooked up to an external display, such as a monitor or projector, specifically for presentations. You can alternate the display options in the following ways:
  1. Laptop display only
  2. External display only
  3. Laptop+External clone
  4. Laptop display + extended desktop on external display (dual monitor setup)
Check your laptop display settings and make sure that it's not in presentation mode (options 2-4) before connecting the KVM switch to it. It may be recognizing the KVM switch as an external display in option 4 mode.
Posted on Mar 25, 2011
How can I switch between systems. I need to be able to toggle between Desktop and Laptop.
Did you not set it up the same with the new monitor
I use a KVM switch
Mar 20, 2016 | Acer Computers & Internet
USB Mouse works, keyboard does not
You will need to update the drivers on the computer for the docking station. It will be the windows seven drivers or lack of them that is causing a failure to remap the usb ports that the wireless dongle is plugged into.
May 25, 2017 | IOGear GCS632U 2-port KVM Switch
I have been using my Iogear kvm switch for almost 2 years now to switch between a desktop and a laptop, both Windows XP. I unplugged the laptop in a hurry to go do a presentation, and plugged everything...
Mar 25, 2011 | IOGear GCS634U KVM Switch
I've got a 4 port switch with two computers hooked up - a desktop and a Lenovo Thinkpad R60 laptop - the desktop works perfect but when I switch to the laptop only the keyboard works - no video or mouse
The Thinkpad does not divert the video automatically to the external monitor via the KVM switch, you need to divert the video by pressing on the Fn key and the press the F7 key to toggle between the Thinkpad's LCD screen and the video port/external monitor. You may need to use a separate USB mouse connected to the Thinkpad.
Mar 20, 2011 | IOGear 4PORT DVI KVMP SWITCH WITH AUDIO...
IOgear KVM not working with laptop
First, you have to make sure that the KVM switch is directly connected to your laptop, and NOT to a docking station.
This KVM switch is designed to work with direct connections to the computers.
Second, the light indicator on the KVM switch is not an indicator for power. It's an indicator to see which port is active. If your laptop is connected to port 2, but the focus of the KVM is in port 1, then the port 1 will have a light, not the port 2.
You may also refer to the user manual of the KVM.
Thank you!
May 13, 2010 | IOGear GCS634U KVM Switch
Dual Screens with a VGA connection
The easiest way would be to purchase a video card that has 2 vga ports on it, allowing dual monitor support. Here is an example.
http://www.amazon.com/Matrox-G450-16MB-Dual-Video/dp/B00194CT5A
Dec 29, 2009 | Samsung 2333SW 23" Widescreen DVI LCD...
I have a kvm switch vista lap and xp desktop stopped working
I've gone through alot of KVM switches. Something in the electronics just gives up. If your keyboard and mouse are the pci type (round connector) then don't switch their locations while the computers are on. Windows won't see the change and you may damage the system. If thy're USB type then switching is OK.
Apr 07, 2009 | Computers & Internet
KVM Switch Issue
MAYBE THE LAPTOP IS SUCKING THE JUICE FROM THE PORTS ON THE DESKTOP.
May 05, 2008 | Inland 08216 2-port KVM Switch
Gatewaymodemfor20004dx2-66
More info please, laptop, desktop, cable-modem, or dial-up, brand of computer is usefull too. If cable modem, use a LAN cable(LOCAL AREA NETWORK) it looks similar to a phone cord, and plugs into the back of a desktop, or side of a laptop.
For more than 1 computer, you'll need a router of some kind.
Internal dial-up modems are a whole nother thing, if you need one of these you may want to take it somewhere and have a pro put it in, especially if its a laptop.
Dec 01, 2007 | VIA JKP11516e: 1U Rackmount 15" LCD...
Problem with laptop connection
KVM's work best when you are using the same or similar type of hardware however there might be an issue with your video card interfacing with the KVM. I would switch the Video cables and see if the problem moved or disappeared. If the problem moves, then I would suspect the video card is the culprit. Since many problems can be traced to software compatibility issues, I would check to see if there is an updated driver for your video card and or your monitor first. If the problem disappears it could possible be a loose cable connection on the destop PC or the KVM itself. I would also try a different set of cables.
Jan 30, 2007 | Belkin F1DK102P 2-port KVM Switch
Computers & Internet Logo
389 people viewed this question
David Payne
David Payne
