Question about HP 4570C Flatbed Scanner
Hi, My HP 4570C scanjet has an intermittent problem - during scans, the light bar will stop/jam at an arbitrary spot in the cycle. My guess is that the problem may indicate the need for lubrication on a sliding component. Any suggestions? Thjanks, Terry
Posted by Lonu Feruz,
I have HP scanjet but unfortunately i dont have the driver CD and it is not written anywhere to show HP scan model except this number C7710A. Which driver works on type of scanjet using windows XP
Posted on Jan 06, 2009
Scanjet 4600 is stuck halfway through scan
About 2,970 results (0.68 seconds) Search Results
    HP Scanjet Scanners - Scanning Stops at the Preview ...
    h20564.www2.hp.com/hpsc/doc/public/display?...na...
    Hewlett?PackardWhen attempting to scan from the front panel of the device, the Scan Preview window displays normally but does not show the document or picture being ...Missing: 4600
    Scan stalls half way through and never finishes - HP ...
    h30434.www3.hp.com > ... > Scanning / Faxing
    Jan 11, 2011 - 7 posts
    More times than not, the scan stops part way through (example attached) and then (after several minutes) displays the messages below:.Missing: scanjet ‎4600
    issue Scanjet 5590 windows 7 Business 64 bits - stop during
    Jan 19, 2010 - 10 posts
Feb 05, 2016 | Office Equipment & Supplies
Trying to connect to an HP Scanjet 4570c to a Dell Inspiron 1750 notebook computer. When I connected the USB cable, it said it updated some drivers, but there is no icon on the laptop to scan, and when I...
If you are under Windows 7 , it's because HP doesn't produce anymore drivers for your unit beyond VISTA .
Download the latest driver available from here : http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&lang=en&product=77368&
and try running your scanner with it . If you don't succeed , try in compatibility mode .
If it still doesn't work please don't blame me , blame HP .
Best regards .
Feb 01, 2011 | HP 4570C Flatbed Scanner
My HP scanner stopped working. THe light appears
Not worth fixing. The bulb is wearing out and you can't buy them.
Dec 20, 2009 | HP Scanjet 4570cxi Flatbed Scanner
HP 5200c scanjet - get black page
yes, your fluorescent bulb is burned out and you cannot buy a spare. Sorry
Oct 11, 2009 | HP Scanjet 5200c Flatbed Scanner
Scanjet 4570c lamp not lighting
Contact HP for warranty services, if it's still new and covered.
You will likely get a replacement unit or factory refurbished replacement.
If out of warranty you will likely have to buy a new one.
Dec 10, 2017 | HP Scanjet 4570cxi Flatbed Scanner
HP 4570c scans totally black or bluish-green with vertical bars
It could be one of two things:
1) The scanner isn't registering black or white during the initialization processing depending on what color it needs to get it started.
2) The CCD unit in the scanner could be failing which could explain why it was only working briefly before getting worse.
Nov 30, 2008 | HP 4570C Flatbed Scanner
Scanning bar light
Do you mean the green power light? I have the same brand and a similar scanner, and the light does always stay on. I think it is a normal function of the scanner. It may not be a good idea to unplug the scanner. I am going to be a bit more research so that we can both be reassured that this is normal.
I'll get back to you.
Aug 15, 2008 | HP 4570C Flatbed Scanner
Editing text
Windows
» HP Scanjet Scanners Supported and not Supported in Microsoft(R) Windows XP s.gif » Resolving 'Missing MSIEXEC.EXE File is Linked to Missing Export: MSI.DLL.222' Error Message During Installation of the HP Director Software s.gif » Resolving 'Scanner not supported' or 'Unsupported operating system' Error Messages s.gif » Resolving Image Zone Install Error 1402, 1406, 1714, 1904, 1935, 2203, or Unknown Error s.gif » Error 'The System Cannot Find the File Specified' While Attempting to Install the HP Photo & Imaging Software in Windows 98, 98se, or Me s.gif » 'Cannot Install This Hardware - The Required Section Was Not Found in the INF' Error Message in Windows XP s.gif » 'Error Install Failure' Message for the hpznfx01.exe Software Module Displays on the Computer When Installing HP Image Zone s.gif » The message 'Fatal error during installation' or 'Error Install Failure' Occurs When Installing HP Image Zone s.gif » A 'Fatal Error' or 'Error_Install_Failure' Error Message Displays on the Computer When Installing the Image Zone Software s.gif » The Error Message 'Error_Install_Failure' or 'Fatal Error' Occurs when Installing Image Zone Software s.gif s.gif
Macintosh
» Mac OS: Software Driver Install Causes Error, "Interface Lib Get Component Resource Could not be Found" s.gif » 'Cannot Install This Hardware - The Required Section Was Not Found in the INF' Error Message in Windows XP s.gif » 'Scanner could not be initialized' Message Displays in Mac OS X when the All-in-One Software is Installed s.gif » Mac OS: Software Driver Install Causes Error, "Interface Lib Get Component Resource Could not be Found" s.gif s.gifs.gif
Jun 13, 2008 | HP 4570C Flatbed Scanner
HP 4570C Flatbed Scanner Logo
369 people viewed this question
Ben Johnson
