Question about Music
How to fix the defected pedal sensor of digitech rp80
Defected pedal sensor
2 Suggested Answers
PolyrhythmFX
  • 109 Answers
SOURCE: how do i fix my expression pedal on my digitech
I think it is controlled via a LDR instead of a pot. If you see a pot under the pedal then it may need a new pot but I believe they have a LDR, which is an LED/light controlled resistor system. Either of these can be fixed by an experience repairman.
LDR parts are available at SmallBearElec.com. It will require some soldering experience. Be sure to test the pedal's control circuity with a digital multimeter to be sure the problem lies within this area and not somewhere else.
Posted on Oct 09, 2009
Digitech rp3 fx pedal too much voltage wont turn on
Usually the manuf. have diodes used as protection against over voltage or adapter polarity issues. Try the correct adapter (sleeve and tip have specific voltage polarity...check for drawing denoting each) and if it fails to power the unit up, it's probably time for Digitech authorized repair.
Oct 29, 2012 | DIGITECH Music
My digitech rp 500 has power supply but it won't
Make sure you have the OFFICIAL Digitech power adapter. Universal adapters or those for MOST other pedals will NOT work... things may light up but you will NOT get audio. This unit requires an adapter supplying 9 VAC (not DC) at about 1 amp. These AC output adapters are not very common and people get the units without an adapter and try using universal adapters and they do not work. An AC adapter is used by Digitech so they can generate both plus and minus voltages internally. I don't know what your utility power voltage is in Cebu, so you need to get an adapter for your voltage that will give 9 VAC output and fit the power jack on the unit.
Sep 15, 2011 | Digidesign Digitech Control 2 pedal for...
I'm trying to add a Digitech X Series EX-7
You CANNOT use the Voodoo as it outputs DC voltage and the EX-7 requires an AC voltage and of 9 VAC and also 1.3 amps at that.
May 07, 2011 | Digi-Tech Digitech X-Series Synth Wah...
I was using my digitech vocalist live 2 pedal during a gig 3 days ago and about 2 songs in, everytime i touched any part of the pedal or pressed the harmony on/off switch to activate the harmonys, the...
Yeah I have an idea... It is likely static electric discharge. At this time of the year we get zapped touching metal things and it also drives electronics nuts... You don't even have to feel it to get zapped.
Try using in your bare feet and see if it fusses... We had a lady vocalist wearing those ugg boots and caused static pops in her microphone... anyway try the test and if it fixes the problem, then look up Staticide spray... You can get it at Amazon.com for example... spray floor in the area you are playing on to kill the static.
The only other thing is to check if wiggling the power input plug causes the problem. Those plugs are notorious for poor connections when they wear.
Dec 28, 2010 | DIGITECH VOCALIST LIVE 2
Expression pedal wont work
Here is a link with a source for the manual on the right of the page:http://www.digitech.com/products/Bass/bp200.php Further information can be found at support at the top of the page.
Mar 20, 2010 | Music
How do i fix my expression pedal on my digitech rp80?does it need a spring underneath it??? or is it read by sensor????
Oct 07, 2009 | Music
After a few minutes of use, there is clipping and sound cutting out with the guitar through. Vocal and harmony are fine. I tried using different guitar cords, different guitars, different amps to no avail....
I know you hate this answer, but it needs to be repaired. It has a circuit board inside, and there's really not a work-around. But it is broken. I totally understand about not wanting to send your gear out, especially if it's a pedal board you have set just right, and are completely usweed to using. You'll be a lot happier with it if you get it fixed though. Or find another one on eBay. I sold all me Digitech pedals when I got my Pod - but that's just me, I use a lot of distortions and it fit the bill better for me. I used Digitech pedals for about 20 years and thought I would hate anything else.
Take care.
Mark
Jun 05, 2009 | Digi-Tech Digitech Vocalist Live 4...
Digitech rp6
Try contacting their service center rep at (801)566-8800. They might send you a schematic for the pedal if you explain your situation. They do recommend using the original power supply PS0912 which should still be available. Hope this helps.
May 25, 2009 | DIGITECH VOCALIST LIVE 2
I need the pin out details of a digitech rp6 guitar effects pedal
Try contacting the service center rep at (801)566-8800. They might send you a schematic for the pedal if you explain your situation. They do recommend using the original power supply which is PS0912.
Digitech RP 90 foot switch is not working
I removed the back cover, unscrewed the two (of 4) screws holding down the circuit board, replaced them again, and it worked fine.
Jan 11, 2009 | Music
Music Logo
102 people viewed this question
Top Music Experts
Michial Gueffroy
Are you a Music Expert? Answer questions, earn points and help others
