Question about RCA P61927 61" Rear Projection Television
Help! Menu options missing!
So we moved today, and (though this TV has been moved several times before) somehow the projectors were knocked out of alignment. So, I downloaded the manual and it says to go to "Menu" and then "Screen" and then the convergence setting. The only issue is that when I go to the screen menu, the option to adjust convergence is just MISSING. I called the RCA folks and they had no idea why that would be. Their advice was "try unplugging it and plugging it back in." This didn't work. Am I going to have to pay someone to manually go in and adjust them? I can see through the back that the projectors are motorized, so they must be designed to control from the remote/menu. Why would these options be missing? In fact, as I see in the manual there should be several convergence related options under "screen" but they are all missing. Any assistance is greatly appreciated. Thanks, Matt
  • 4 more comments
  • Tim_W Jan 06, 2008
    Same here, I do not have a convergence setting under menu either.
  • chillbilly Jan 23, 2008
    Different model, same problem....convergence option missing from menu......where did it go?
  • Ze_frenchie Feb 03, 2008
    The 3 color beams seem to have shifted of about 1 inch each this morning... I cannot find the convergence menu!!! Where is it ???
    Daniel
  • bubmjf Feb 10, 2008
    Same problem, the convergence is off and some how some way the covergence option has dissappeared from the menu??? please help
  • val007 Mar 02, 2008
    I'm having the same problem, how do you get the convergence menu if it dosen't show up.
  • donnier70 May 19, 2009
    I have a RCA HD61W66, the colors are not aligned. I get three images, one in each of the three colors. The convergence option is also missing on the menu.
  • 3 Answers
Many of the RCA's have a pico fuse that feeds the convergence board. If these have blown there will be no 24 volt supply to the convergence board.
Posted on Oct 13, 2008
Half a year and still no answers, this site is lame....
Posted on Aug 27, 2008
Sanyotv com
Sanyo TV Service Menu Method 1
1.Unplug the power cable.
2.Press and hold the {MUTE} button on the remote control while plugging the power cable back into the outlet.
3.Keep pressing the {MUTE} button until the TV powers on with the Service Menu displayed.
4.Use the {CH+} {CH-} buttons to select menus.
5.Use the {VOL+} {VOL -} buttons to change settings.
6.Some menus might have sub-addresses. Use the numeric buttons {0} to {7} to adjust sub-item data.
7.Press the {MENU} button or turn the TV off to exit.
Sanyo TV Service Menu Method 2
2.Press and hold the {VOL -} button on the TV while plugging the power cable back into the outlet.
3.Keep pressing the {VOL -} button until the TV powers on with the Service Menu displayed.
Sanyo Projector Service Menu Method 1
Factory Menu Access
1.Press and hold the {SELECT} and {INPUT} buttons on the Projector at the same time for about 10 seconds.
2.The Factory Menu will be displayed.
Service Menu Access
1.Press and hold the {MENU} and {INPUT} buttons on the Projector at the same time for about 10 seconds.
2.The Service Menu will be displayed.
Use the {UP} {DOWN} {LEFT} {RIGHT} buttons to move through menus and change values.
To exit, turn the Projector Off.
Sanyo Projector Service Menu Method 2
1.Press & hold the {MENU} button on the Projector for about 10 seconds.
3.Use the {UP} {DOWN} {LEFT} {RIGHT} buttons to move through menus and change values.
4.To exit, turn the Projector Off.
Jul 20, 2013 | Televison & Video
Hello. How do I invert the image on a Toshiba TLP-2000 EDU Projector. Many thanks, Paul
Go into the setup menu.
One of them is the picture or positioning menu.
There are normally 4 options,
front projection standard / inverted.
rea projection standard / inverted.
dont move the projector whilst on or bulb is warm as bulb is very fragile at that time.
Please dont forget to vote this answer was helpful
Many thanks
Feb 19, 2011 | Toshiba TLP-XD2000U Mobile Projector
Somehow the image is upside down on the smartboard
This is a setting in your projector. It's setup so you can hang the projector upside down or set it right-side up on a table. It's in the menu options under display I think.
Jun 10, 2010 | Sharp Notevision PG-B10S Multimedia...
Why is image upside down? the image appears inverted on the board
You need to set up the image using the menu. Press menu button on the remote then use the arrows to go down the list until you come to "mirror". Now press the enter button on the remote several times to cycle the orientation of the image (on some remotes you may have to use the right arrow button instead of the enter button). The projector will remember this setting next time it is switched on. These options are there for people who use ceiling mountings that hold the projector upside down.
Jul 10, 2009 | Epson EMP-S3L LCD Projector
Can changing settings delete the memory card?
It's no problem at all to get them back. Please see this post for several free software that you can download. You'll need to use a card reader with these programs though:
http://camerarepair.blogspot.com/2007/12/recovering-those-accidentally-lost.html
May 14, 2008 | Canon PowerShot S1 IS Digital Camera
Red / Green issue when connecting Mits DVD to Mitsubishi TV
Convergence problems, look in menu and find manual conver. and read for more info goto ctechnicians.com
Dec 22, 2007 | Mitsubishi WS-55511 55" Rear Projection...
Sylvania SST4272
I had the same problem with a Sylvania SRT2227S. I kept trying to fix it using the remote but after reading your posting I pressed the Volume (down) button, which cycled through the same menus you mentioned. Then I pressed the Power button on the TV and that fixed it.
The problem started for me when pressed PIP, CC, and Guide buttons on a Philips universal remote control. My TV does not support these functions and it seems to put it in this "service mode". Now I can fix it by pressing Volume (down) or Menu then the Power button on the TV (do not use the remote as it is useless when the TV is in this mode). I hope this works for you too.
Nov 25, 2007 | Sylvania 6419TC 19" TV
Pip position
Hi there
The PIP ( picture in picture ) is only to determine where the Menu block itself will show on your screen.
Try the Vertical and Horisontal shift in the Menu Options.
Oct 23, 2007 | BenQ PB6100 Multimedia Projector
Convergence problem
We need a better description of what you mean by shadowing. However I am assuming: 1. You mean it ''bleeds'' off to the right when you have something with a hard red/blue drive. 2. When you turn the contrast and color down a bit it gets better. unfortunatly I cannot tell you how to fix convergence, but I can think of some other possibilities. In this case the red/blue emmision of the crt is dying off and going into saturation when driven hard. To fix, replace with a new picture tube/crt. In some cases you can get a little more life out of that tube (with a watchable picture) by having the screen, focus, cathode bias, and drives slightly readjusted. It will take someone with experience in doing these adjustments on a weak tube to get it looking as good as possible. Given the construction of the cathodes (guns) in that crt, only a very low level crt reactivate should be tried on it. The hard rejuv most crt testers give is highly likley to completely destroy the cathode on that crt.
Mar 22, 2006 | Toshiba 55H70 55" Rear Projection...
RCA P61927 61" Rear Projection Television Logo
353 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
