Question about Jandy Laars Hi - E2 350,000 Btu Heater
How do i stop steam vapors from coming out with heater exhaust
The unit is 5 yrs old with average use, has a salt generator attached. some corrosion has appeared; a few electric parts have been replaced but it was running well there after; lots of condensation flowing out of tray but also there is some moisture on heater bottom and around heater on floor; its in a pool house; the latest trouble sign is there is light brown liquid that has left drips of liquid here and there and the new ignitor that was installed
    Top Expert:
  • Jandy Master
  • 5,075 Answers
Make sure the drain pan on bottom isnt plugged or hose make sure to change out rocks and fill pan with water
Posted on Jun 07, 2015
  • 22 Answers
SOURCE: My Heater is leaking water from underneath.
yes you can replace the core but you should check all the other components to be sure the chlorine hasn,t destroyed them.
Posted on Feb 21, 2009
SOURCE: low pressure reading on Pool Heater
I had this problem with ours last year. I replaced the water pressure switch and it began working fine. We later had a symptom that the blower would start but it would not ignite. The ignitor rod was corroded so I took it out and sanded it with some sandpaper---worked fine...until I dropped it trying to reinstall and it broke. Bought a new one and it works fine now.
Today's problem is related to the blower now.... it is always something, isn't it?!?
Posted on May 30, 2009
SOURCE: Aqualink Chlorine Generator not producing any chlorine
It shounds like that you might have a mustard algae issue. It feeds on chlorine. It is possible that your unit is producing chlorine but the algae is consuming it as fast as it can be made. You will need to do a shock treatment and use an Algae 30. It could be something else, but this is likely. You can google mustard algate treatments and read up on it to see if you have other symptoms.
Posted on Aug 04, 2009
  • 246 Answers
SOURCE: how do you replace an air flow switch in a Jandy
order the flow switch open the door take off hoses take screws off reverse with new air swtch just dont send the old one
Posted on Aug 19, 2009
john224
  • 1378 Answers
SOURCE: pool controls act as if not getting power- bad control board?
Thank you for posting your question here on Fixya.com.
I would suggest you hire a local pool heater technician to diagnose the problem for you. Any decent tech can ID the problem and likely have it fixed in an hour or so and it could be something as simple as a blown transformer which with parts and labor would be under $200; far less than a control board and a fraction of the cost of a new unit. Questions to ask a potential tech would be how much an hour? Is there a service call or travel fee? Do you carry replacement parts on your truck or stock them nearby? How long do you guarantee your work?
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Posted on Apr 05, 2010
We have a water softener and I think the water has too much salt and therefore, our Vicks vaporizer has too much steam. Any suggestion?
If your softener is working properly, you should never get any salt in your water. The salt is used only to reactivate the ionic media in your softener cartridge, and during the backflush cycle, all that salt is removed, down to PPM (Parts Per Million) levels.
In any case, even if you used salt water in your vaporizer, it would not increase the amount of steam that it produces. Salt water has a higher boiling point than fresh water. You would also notice salt buildup inside the tank as the water level goes down.
The Vicks Vaporizer works by using only heat to produce steam- the hotter it gets, the more steam it makes. The only practical way to get too much steam outside of a malfunction that causes your heating element to get abnormally hot would be if you live at a very high altitude where water boils at a lower temperature.
High humidity in your home will make it appear as if your vaporizer is making too much steam since the surrounding air will be less capable of absorbing it.
A slightly "off topic" note- if you chose the Vicks Vaporizer/humidifier and have children, you have made a wise decision. Because it produces water vapor by heating instead of ultrasonics, contaminants and minerals (such as salt, iron, calcium, etc.) remain in the tank and will not enter the vapor stream.
Mar 25, 2011 | Vicks Warm Steam Vaporizer 1.5 Gallon...
I need to know how to use the warm steam vaporizer i lost the instruccions..
you add vicks petroleum paste/jelly at the top where the air vent is. Add 1-2 tablespoons of salt with tap water in the tank, plug in the unit and warm steam will produce.
Feb 16, 2011 | Vicks Warm Steam Vaporizer 1.5 Gallon...
I bought our Vicks vaporizer and it worked great the first night we used it. We had added a pinch of salt and it steamed all night. Now my husband is sick and we cannot get it to work correctly. We added...
When you say you added apinch of salt I asked my wife and she says that is the measure that she uses. I doubt that you have to much salt but you can flush out your vaporizer with warm water while the unit is running. I would run two or three times for 1-2 hours each then remove element and rinse withe warm water.Also rinse out container and refill with warm water to fill line,make sure you don't overfill as this can cause the spitting. I would add about 1/4 cup of pure vinegar and let unit run. If you have hard water or high mineral content this should help to clean it.
I hope this helps you but if it doesn't I would return it as defective. Thank you
Dec 16, 2010 | Vicks Warm Steam Vaporizer 1.5 Gallon...
My vaporizer is barely putting out any steam...is there a way to clean this unit so that it will produce more steam? This is a Vicks 1.5 gal unit.
Is the water in your area soft? If so, add a few pinches of salt. Vaporizers boil the water by running electricity through it. If your water is too soft, no electricity and therefore no steam.
If you have hard water, and the unit must be cleaned, try soaking it in vinegar.
Dec 24, 2009 | Vicks Warm Steam Vaporizer 1.5 Gallon...
No steam output
Dec 06, 2009 - found solution: if unit is truely clean, unplug unit then mix about a teaspoon of iodized salt (table salt) to the water. Reconnect unit wait about 1 - 2 minutes, unit will start to make a grinding sound but shortly after steam will produce.
Nov 13, 2009 | Vicks Warm Steam Vaporizer 1.5 Gallon...
Steam out of exhaust no heater working bolt
You will need to re-post with better symptoms. ON a cold day the exhaust will steam as much of it is water vapor.
However, if the exhaust smells of coolant (sickly sweet) then you have a dying engine in need of a rebuild/replacement.
No heater? In what way is there no heater?
What is a "working bolt?"
Oct 06, 2009 | 1986 Volkswagen Wagon Camper
My vaporizer is making a spitting sound -
No salt, unless you had 0 steam - to stop water spit, throughly clean the water tank, just as clean as new. It will work like new if the tank is as clean as new! I dont know where the small particles of dirt come from, but trust me, I just went thru this with mine, it's got dirt in it!
Nov 19, 2008 | Vicks Warm Steam Vaporizer 1.5 Gallon...
Vaporizer That Works?
Have you tried adding salt to the water in the vaporizer? Sometimes the water needs to minerals for the humidifier to work...I add sea salt to mine every time I fill it.
Oct 12, 2008 | Vicks Warm Steam Vaporizer 1.5 Gallon...
No steam
Try putting a teaspoon of salt in the vaporizer, it should start blowing.
Feb 15, 2008 | Vicks V150 Humidifier
Jandy Laars Hi - E2 350,000 Btu Heater Logo
94 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Pj Kiley
Pj Kiley
Level 1 Expert
Bill Jordan
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
