Maytag centennial washer mvwc200xw1 lid locks and machine makes clicking noise but won't fill no water
  • 311 Answers
SOURCE: washer's warm setting alternately fills hot and cold
Call for wty svc- the temp switch is bad; they had many of these built like that Please contact me if you need further help or leave feedback if appropriate as that is how I get paid. Thanks for letting me help you!
Posted on Nov 30, 2008
FIXYA Benny
  • 165 Answers
SOURCE: maytag top load washer won''t fill with hot or cold water.
solenid valve
may be faulty.
to test disconect from the cold side and atch to the hot side,
the solenid valve is an electronic valve that switched the water on and off its usally atched inside of the back of the machine where the hose attaches to.
http://en.wikipedia.org/wiki/Solenoid_valve
Posted on May 04, 2009
  • 220 Answers
SOURCE: Maytag Bravo Washer flashes F50 code
Most likely a bad machine control,can also possibly be a motor per whirlpool but I have never had to change a motor,changed a lot of machine controls.
Posted on Sep 01, 2009
beltronic205
  • 1461 Answers
SOURCE: Overfilling maytag centennial - brand new?
Sounds like a hose off pressure switch or faulty switch/ however make sure drain connected ok 1st....
Posted on Oct 02, 2009
jamesstoner
SOURCE: want to disengage lid lock on maytag centennial
I had the same problem. The lid lock assembly is broken. If you are under warranty get it replaced. If not remove the top of the washer and take out the switch assembly. The 4 wires going in are Yellow, Red, White, and Blue. If you short the white and blue together, the washer thinks the lid is closed. If you short the red white and blue together the washer thinks the lid is closed and locked. The yellow is only there to activate the electromagnetic switch.
Disconnecting the switch assembly will not work.
The electromagnet locks the lid and it also unlocks the lid. It is not a matter of cutting the power to the magnet.
Installing 2 switches that connect the red white and blue is the best option if you want to remove the lock.
The first switch should connect the white and blue. (LID CLOSED)
The second should connect the red to the white/blue connection. (LID LOCKED)
After that the lid should work.
Please post a follow-up if this works for you.
GOOD LUCK
Posted on Aug 06, 2012
When lid lock flashes, that is an indication of a bad lid lock in some of the mvw washers.(depending on your unit and model number &error codes)
Nov 03, 2013 | Washing Machines
I have a Maytag Centennial top load washer. When washing in normal or heavy with large or super load size, the washer remains in sensing mode. Some water does start to fill, but never reaches wash cycle....
This unit does not handle a super large load as it advertised. When you put a super large load, the sensor is over-sized and will not move on the next cycle.
Sep 03, 2013 | Maytag Centennial MTW5800TW Top Load...
I have a maytag centennial washer MVWC400XWO it is 3 years old. The washer has stopped after the initial wash cycle leaving the cloths wet in a tub full of water. The washer will not go to the spin/drain...
For saftey the lid lock and lid down switch must be activated before the machine can advance to the next cycle. This has been the sequence for all top loaders..
Check the switch for the lid it is likely defective.
Make sure that the power is removed.
Simple repair by a qualified technician.
Hope this helps?
Jun 14, 2017 | Maytag Centennial 3.2 cu. ft. SuperSize...
Washer won't start and lid won't lock . it keeps clicking and the sensing light keeps flashing
Thank you janesstone ive been looking for 2 hours trying to figure out that simple wire bypass i just couldnt find what wires did what. Your my hero for the day lol. Everyone should be able to find this answer easier just sayin
Oct 26, 2012 | Maytag Centennial Series MVWC200XW
Maytag Washer won't agitate after filling
Believe you are on right track would try door lock switch first easier to replace and most likely cause.
Aug 04, 2017 | Maytag Centennial 3.2 cu. ft. SuperSize...
Centennial washer, will fill with water, wont spin or agitate, power is good
Easy fix. Lid switch is bad. This is a direct drive machine. Older models would wash but not spin these latest babys won't wash or spin with the lid switch broken. To access te switch you flip up the control by using a putty knife to release each end. Older models had a screw that needed to be removed, not so with the newest ones. The switch has 2 hot wires and a ground wire. Jump them 2 hot wires and see if she runs
Video: How to get into these machine:
How it works
Apr 30, 2011 | Maytag Centennial MTW5800TW Top Load...
Oct 02, 2009 | Maytag Centennial 3.2 cu. ft. SuperSize...
Washing Machines Logo
113 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
