Question about Boating
Where can I view a Johnson 9.9hp out board motor older model manual and parts book Serial No A 07605368
Model A J10 BACCD
  • 43064 Answers
SOURCE: how to install choke shaft on 4hp Johnson motor
model year makes some difference but it usually has ` small screw holding a clip in that it slides thru remove the screw and put in the new one right side up and put back together
Posted on Apr 26, 2010
  • 677 Answers
SOURCE: Is removing the lower end of a 15 hp older Johnson
There is also the gear change rod to undo.Look on the side of the leg,for a small plate.Inside it,is where the connecting bolts will be.Be in nuetral when you undo it and put it back together.On the water pump.Pay special attention to which way the lobes on the rubber impellar are facing.Wrong way around and you will damage the new impellar.Hope this helps
Posted on May 15, 2010
Testimonial: "Thsnk-you! I've booked the motor in for replacement of impeller but your diagnosis is bang on! I'll likely use the service again"
  • 677 Answers
SOURCE: how tough is it to change water pump impeller on 15hp johnson
There is no special tricks.Unbolt the gearshift linkage that has access through the side of the leg.Usually a small plate.Unbolt the lower g/box.4 bolts I think.The box should then drop.If not,use a rubber hammer and be patient.Put the lower skeg of the g/box in a vice to make things easier.NOW.When you lift the housing of the w/pump take a note of which way the impellar pump lobes are curled.DON'T put the new impellar in the wrong way.It's probably worth putting in a new seal whilst it's apart.You spin the housing or imp. as you put it together.Use a small bit of grease for the initiall dry start-up.Put some very good grease on the top splines on the driveshaft.It goes straight into the crankshaft.If it corrodes,nothing comes apart.As you put the g/box back on,spin the prop so the splines go back in.There is no special alignment.Gearchange linkage and you go fishing.(take the prop off and regrease the splines on the shaft of it)Hope this helps
Posted on Jul 22, 2010
mjdagis
  • 11 Answers
SOURCE: What year is my Johnson motor Model 175EXEUE
your engine is 1997.
Posted on Aug 22, 2010
bob_computer
  • 3153 Answers
SOURCE: trying to find a johnson reel model number 110B
A BOT question methinks coz its about as useful as a chocolate fireguard
Posted on Nov 29, 2011
I have a Iver Johnson 12ga double barrel with 30" barrel's s/n 28586 How old is it and What is the Value?
These will all help you.
Iver Johnson's Arms & Cycle Works - American Firearms
www.american-firearms.com/.../Iver%20Johnson's%20Arms%20.../Iver%20Johnson's...
  1. Cached
  2. Similar
Aug 7, 2011 - Single top latch, 100'000 were manufactured in 1894, serial number without letter prefix, marked on the top of the barrel rib. IVER JOHNSON'S ...
*IVER JOHNSON SERIAL NUMBERS ' The Firearms Forum
www.thefirearmsforum.com > ... > The Ask the Pros & What's It Worth? Forum
  1. Cached
  2. Similar
Jan 11, 2012 - 15 posts - ‎10 authors Is the gun large frame or small frame, hammerless or a hammer gun? ... I have a Iver Johnson Top Break 5 shot hammer gun. ... I just purchases an iver Johnson hammerless 5 shot top break revolver. Iver Johnson Serial Numbers 6 posts 26 Jun 2016 Iver Johnson Serial number help 15 posts 1 Nov 2014 Old Iver Johnson shotgun 12 posts 10 Nov 2011 Need Info on Iver Johnson Hammerless Revolver 15 posts 13 Apr 2006 More results from www.thefirearmsforum.com
Blue Book of Gun Values - IVER JOHNSON ARMS & CYCLE WORKS
bluebookofgunvalues.com > Gun Values
  1. Cached
  2. Similar
IVER JOHNSON ARMS & CYCLE WORKS gun model and pricing information.
Iver Johnson Arms - M1CarbinesInc.com
www.m1carbinesinc.com/carbine_ij.html
  1. Cached
  2. Similar
Introduction to Iver Johnson, Iver Johnson's Arms, & Iver Johnson's Arms & Cycle .... With the exception of the D-Day Carbines the serial number on Iver Johnson ...
manufacture date of Iver Johnson revolvers based on serial number ...
www.rimfirecentral.com > Other Rimfire Guns > Misc -- Other Rimfire Rifle Brands
  1. Cached
May 17, 2016 - 14 posts - ‎3 authors There is a serial number listing for the Iver Johnson SuperShot 22 Top Break Revolvers in W.E.Goforth's book/reference, "Iver Johnson Arms ...
Iver Johnson - Wikipedia
https://en.wikipedia.org/wiki/Iver_Johnson
  1. Cached
  2. Similar
Iver Johnson was a U.S. firearms, bicycle, and motorcycle manufacturer from 1871 to 1993. .... William McKinley in Buffalo, New York on September 6, 1901 with an Iver Johnson .32 caliber Safety Automatic revolver (serial number 463344). Iver Johnson 12ga Google Search
Nov 30, 2016 | The Optics
What year is a evinrude outboard with serial number 1451821
The motor HP is critical in such searches. Here are all the resources you need to find the information yourself.
About this result
How To: Outboard Engine Serial Number Year Match, iboats.com How ...
www.iboats.com/basics/serial_number_year.html
  1. Cached
  2. Similar
For engines prior to 1969 refer the the Johnson 1960-1979 serial number year chart located here. If you have a commercial model refer to the Johnson commercial serial number year chart located here. Evinrude changed how they indicate year in the model number in 1980.Mercury Outboard · ‎Evinrude Outboards 1950-1979 · ‎Johnson Evinrude Commercial
[PDF]5006145_Model Number Reference.fm - Evinrude
shop.evinrude.com/media/document/ModelNumberReference.pdf
  1. Similar
MODEL NUMBER DESIGNATION - OUTBOARDS. Model Years 1980-1998. V E 70 T L ED A. MODEL VARIATION. A = Australia. B = Belgium. C = Canada.
Evinrude Outboard Motor Model Numbers & Codes - Marine Engine
www.marineengine.com/manuals/evinrude/
  1. Cached
  2. Similar
The nameplate should contain a model number and a serial number. The model number will identify the year and certain details of that motor. 1980-Present: Evinrude outboards from 1980 to the present use a model number that can help determine the year and features of the motor. See the model number code here.0.5HP · ‎0.9HP · ‎1HP · ‎1.1HP
Marine Motor Look-Up Guide - Auto Repair Manuals
www.autorepairmanuals.biz/page/599222
  1. Cached
  2. Similar
keywords: Find year, serial, number, model, number, #, outboard, motor, marine, motor, look-up, Johnson, Evinrude, Mariner, Mercury, Force, OMC, Yamaha, ...
EVINRUDE OUTBOARD MOTOR MODEL YEAR LOOKUP GUIDE ...
www.maxrules.com/models/OMC_models_files/EVthru79/ev_index_79.html
  1. Cached
  2. Similar
WHAT YEAR IS THAT OLD EVINRUDE? FIND OUT HERE ON OUR MODEL YEAR LOOKUP CHART! evinrude outboard with serial number Google Search
Nov 29, 2016 | Boating
Serial number J3062276 model 6r 69m what year is this Johnson boat motor and where is best for parts
a johnson dealer will be the best place for parts and you can find them by going on line to johnson outboards and opening the dealer distribution page
you may be able to get the year for the motor from the same on line contact page
Jul 12, 2015 | Boating
What year is a johnson 4 hp outboard serial number b 7643180 model number bj4brccs
To get the year of Johnson and Evinrude outboards use the word "INTRODUCES". Each letter corresponds to "1234567890" respectfully. It's best to check with a model year reference book, but this motor's model number contains "CC" which would indicate it's a '88.
Sep 21, 2014 | Clymer Evinrude/Johnson 2-70 HP Two-Stroke...
Year model serial number
1978 It is in the model on an Evinrude. 6804.... 6 HP.....1978
Jul 22, 2014 | Clymer Evinrude/johnson Manual 2 Stroke Ob...
Can i find the year of of manufacture of my old johnson 25 hp outboard motor by its serial number?
yes if yuo go to iboats.com the forum will allow you to search by serial number and give info on your outboard.
Aug 17, 2013 | Sierra International 18-4310 Marine...
Boating Logo
18 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Boating Expert? Answer questions, earn points and help others
