Question about Dell Dimension 4400 PC Desktop
Problems when installing sp2 on my dell 4400
I am running XP Problem is when I install sp2 or sp3 my computer will only boot in safe mode.
  • 2 more comments
  • nfloyd52 Jan 04, 2009
    Thanks , but I have tried sp3 also with the same results
  • Anonymous Jan 13, 2009
    Same thing instant blue sceen.
  • dsmith22 Jan 20, 2009
    Brand new Win XP w/ SP1. Dell Dim 4400 works fine until SP2 installs the continually reboots, but will boot into safe mode.
  • JDTec
    JDTec May 11, 2010
    Usually this is due to spy ware or viruses. Update and run your protection programs. Then try SP3 (SP3 will encompass SP2).
    Novelist:
  • 176 Answers
Reboot and keep tapping on F8 into Safe Mode. You can select "Last known good configuration" or continue In safe mode and do a system restore to the day before you installed the SP3. To do a system restore, go to Start, Programs, Accessories, System Tools, System restore. Windows XP SP3 has some issues with certain programs giving the blue screen of death.
Posted on Jan 04, 2009
I finally fixed my problem. Several other sites referenced a problem with the hard drive and a driver conflict with SP2. So I went to the Dell site and downloaded the updated Intel IDE drivers along with a couple of other fixes that they had posted. Voila, SP2 installed without any problems. For more info see links below. Hope this helps someone.
Dave
Fixes:
http://tinyurl.com/9g8atg
http://tinyurl.com/9blvvh
http://tinyurl.com/a59vna
Posted on Jan 20, 2009
My computer works in safe mode, but it won't finish booting up in reg. mode. It locks up in the middle of starting and goes from a black bakground to a green one and it stops/freezes. It started doing...
Boot into safe mode, go to the start menu, all programs, Accessories, system tools, click system restore. Try restoring your computer to a date earllyer thin the installed sp3. Best wishes. Good luck.
Have a nice day!
Aug 23, 2011 | Gateway GM5048 (6304) PC Desktop
Dimension 5100 and windows xp pro SP3 clean install
I was able to dig this up.
Reference: http://4sysops.com/archives/tip-how-to-install-and-uninstall-a-program-in-safe-mode/
Run Windows in safe mode.
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\
Create a registry key REG_SZ key and call it MSIService and value data and call it Service, which is the windows installer. This will give you permission to uninstall windows service Pack 3 from add/remove programs while in safe mode.
May 09, 2010 | Dell Dimension 5100 (D51L1) PC Desktop
Hi, i am using dell insprion 1525 laptop. i am faceing problem in netwoek drivers . i am not able to install network drivers and at lan card palce i am getting red light please help me .. praveen kumar
Boot the computer in Safe Mode with Networking and see if it connects that way. If not, try this fix.
TCP/IP stack repair options for use with Windows XP with SP2/SP3.
Start, Run, CMD to open a command prompt:
In the command prompt window that opens, type type the following commands:
Note: Type only the text in bold for the following commands.
Reset TCP/IP stack to installation defaults, type: netsh int ip reset reset.log
Reset WINSOCK entries to installation defaults, type: netsh winsock reset catalog
Reboot the machine.
Download Network driver :- R161378.EXE on support.dell.com
Jan 16, 2010 | Dell Computers & Internet
Installed a rangeplus adapter on dell 1000 inspiron xp sp3 home
See if you can go into safe mode by hitting the F8 key right after the dell splash screen and right before the XP splash screen comes up. If you can get into safe mode try to uninstall the rangeplus adapter and try reinstalling again after rebooting the system normally.
Nov 15, 2009 | Dell Inspiron 1000 Notebook
Re-installed XP Pro + SP2 + SP3 - but have black screen
reinstall xp and dont install sp2 go to microsoft update and let it install sp3 for you
Sep 23, 2009 | Dell Latitude D600 Notebook
Dell Vostro will not boot up
During startup, just before the Windows splash screen appears, you should be able to hit the F8 key for a list of startup options. It looks from your post as if you know how to do this.
One of those choices should be to disable automatic restart on system failure. (or words very similar to that.) Use this choice to get into safe mode if you can, or into regualar windows.
Once there, go to the system restore feature and restore to a date when everything worked.
This error message is a message pointing to a piece of software (as opposed to hardware, as so many of these messages are).
The next best fix is to reinstall the OS from the ground up. this may be a major hassle, depending on the data you have on that hard drive.
Good luck
tony
May 18, 2009 | Dell Vostro 1700 Notebook
How to install xp sp1 in dell pc 220s
The latest service for XP is SP3.
You need to download SP2 from Microsoft (SP2 which includes SP1).
Then you need to install SP2 and after SP2 is installed you need to download SP3 to install.
SP3 is approx 350Mb so if you have a friend who has it on a CD, then borrow it and install it using the CD.
May 15, 2009 | Dell Computers & Internet
XP-Pro Crash
I don't know why but some systems which have XP (SP1 or SP2) simply can't take the upgrade to SP3. Your system appears to be one of them. For instance our family's computer had XP SP2 and upon upgrading to SP3 we received a fatal crash while XP was loading into normal operating mode.
I managed to resolve the issue by booting to safe mode and restoring the system to a date before I installed SP3. Sorry that the new SP doesn't work for you.
Feb 03, 2009 | Microsoft Computers & Internet
Windows will only start in safe made after sp2 or 3 install
you likely have some software issue that prevents all the new services from loading, most likely it is related to the antivirus/security software.
try disabling all the non-MS Services and all statup items in MSConfig, if it starts normally with all this disabled, reenable them a few at a time until you find the offending software
START
Run
type "MSCONFIG" withou the quotes
click the services Tab
check "Hide all microsoft services"
click disable all
click Satrtup Tab
Disable all
OK
allow to restart
during startup you will see a screen that says you have made the changes, this is normal (when you are all done, check the don't show again)
once you have found what causes the issue, Google the startup item and uninstall the related software.
Hope this helps
Jan 05, 2009 | Dell Dimension 4400 PC Desktop
Trying to restore dell 4400 and cannot get to a dell screen for f-12
If you boot from the XP CD and choose the first repair option it will load to a DOS prompt. From there type "chkdsk /r" and press enter. This will run checkdisk on your hard drive and repair any problems that it finds. It will take 45 minutes or more depending on the size of your drive. Once it finishes type exit to reboot and remove the CD. Your computer should boot normally.
Oct 30, 2008 | Dell Dimension 4400 PC Desktop
Dell Dimension 4400 PC Desktop Logo
219 people viewed this question
Alun Cox
