Question about Challenger Battery, 8.4V 900mAh NiMH 7-Cell. Works with RC Airplane Models: Commander
Battery operation How does a battery produce electricity?
  • 24 Answers
Please visit this site:
http://www.madehow.com/Volume-1/Battery.html
Posted on Jan 09, 2009
Check engine light comes on and voltage gage drops below 9 volts, the battery gets drained in the process, battery is not charging. Checked the alternator and it checks out good.
There may be a no charge state in this case, or internal issues with your battery. I recommend checking the charging system and its corrosponding parts/sectors. Use the procedure below to isolate this issue.
Wear protective eye wear and clothing and remove all jewelry when checking your battery and charging system. Jewelry is a good conductor of electricity and is not recommended. Most batteries wear out every 3 to 5 years and need to be replaced. Always replace your battery with an equal replacement battery to assure proper operation. Automotive batteries have a +positive terminal (red), - negative terminal (black). Electricity is stored in the battery and then supplied to the vehicle when the engine is not running. While the engine is running the vehicles alternator charges the battery for future use. (Note: never disconnect the battery while the engine is running. If the battery cable is disconnected from the battery a spark can be generated which can cause the battery to explode or a major electrical malfunction to occur.)
To check a battery surface voltage, remove the positive terminal protective cover. Connect the +positive side meter lead (red) to the positive side battery terminal. Connect the - negative (black) side meter lead to the negative battery terminal. With the vehicle not running and the car sitting over night the battery voltage should be between 12.5 and 12.8 volts.(You will need to use a voltmeter for this testing procedure)
The alternator is rotated by a drive belt driven by the vehicles engine while it is running. Electrical voltage and amperage are generated to recharge the battery and supply voltage to the electrical system of the car. The alternator is held in place with mounting bolts. There is a main electrical wire on the rear of the alternator that supplies voltage to a main voltage junction box. If your alternator is not charging properly, your battery will slowly drain down from operating all the electrical systems in your car and stop the car from running.(most non charge states will be the cause of a loose belt or a low tension rate, due to a mis-adjusted alternator. make sure you have enough tension in the belt for full rotation of the alt pulley)
Next, you will need to check the alternators output with the Amp meter.
Testing the amperage output of the alternator is good for measuring the amount (not the level) of voltage the alternator can produce. This test can be tricky because if the alternator is weak it can still show it as producing amperage. Which is good, but if the voltage is low, it will still allow the battery to go dead. To check the amperage output of an alternator an amp meter is needed. Once the meter is connected start the engine. Next turn on all electrical accessories and raise the engine idle to about 1200 RPM. The alternator should output the max amperage it was designed to produce. Example: a 90 amp alternator should output about 88 amps. Note: An alternator cannot sustain maximum output for long periods of time. If the alternator is forced to operate at maximum output it will overheat and fail. An alternator is designed to operate at max amperage output only for a reasonable amount of time.
((Connect the voltage meter lead the same way you would in a battery static voltage check, Start engine (do not drive) at engine idle the voltage should be between 13.6 to 14.3 volts. If not the alternator may need replacing.)))
Apr 23, 2011 | 1996 Jeep Grand Cherokee
The battery light on my car came on. I assumed it needed a charge or I needed a new battery. My car stopped, however, when jumped it would not stay on. I was advised by my brother that it is most likely...
There seems to be a no charge state in this case. i recommend checking the charging system. use the procedure below to isolate this issue.
Apr 02, 2011 | 2008 Dodge Avenger
Battery won't hold a charge
There seems to be a no charge state in this case. I recommend checking the battery first, then, move on to the charging system. Use the procedure below to isolate this issue.
Wear protective eye wear and clothing and remove all jewelry when checking your battery and charging system. Jewelry is a good conductor of electricity and is not recommended. Most batteries wear out every 3 to 5 years and need to be replaced. Always replace your battery with an equal replacement battery to assure proper operation. Automotive batteries have a positive terminal (red), negative terminal (black). Electricity is stored in the battery and then supplied to the vehicle when the engine is not running. While the engine is running the vehicles alternator charges the battery for future use. (Note: never disconnect the battery while the engine is running). To check a battery surface voltage, remove the positive terminal protective cover. Connect the positive side meter lead (red) to the positive side battery terminal. Connect the negative (black) side meter lead to the negative battery terminal. With the vehicle not running and the car sitting over night the battery voltage should be between 12.5 and 12.8 volts.(You will need to use a voltmeter for this testing procedure). If the voltage is not up to specs, replace the battery asap. If the battery is ok and showing good voltage readings; Move on to the alternator/generator drive belt and amperage test.
The alternator is rotated by a drive belt, which is, driven by the vehicles engine crank shaft pulley while it is running. Electrical voltage and amperage are generated to recharge the battery and supply voltage to the electrical system of the car. The alternator is held in place with mounting bolts. There is a main electrical wire on the rear of the alternator that supplies voltage to a main voltage junction box. If your alternator is not charging properly, your battery will slowly drain down from operating all the electrical systems in your car and stop the car from running. Most non charge states will be the cause of a loose belt or a low tension rate, due to a mis-adjusted alternator. Make sure you have enough tension in the belt for full rotation of the alternator pulley.
Testing the amperage output of an alternator is good for measuring the amount (not the level) of voltage the alternator can produce. This test can be tricky because if the alternator is weak it can still show it as producing amperage(False reading); Which is good, but if the voltage is low, it will still allow the battery to go dead. To check the amperage output of an alternator an amp meter will be required. Once the meter is connected start the engine. Next; Turn on all electrical accessories and raise the engine idle to about 1300 RPM. The alternator should produce the max amperage it was designed to produce. Example: a 90 amp alternator should produce about 88 amps. An alternator cannot sustain maximum output for long periods of time. If the alternator is forced to operate at maximum output it will overheat and fail(due to a failed regulator). An alternator is designed to operate at max amperage output only for a reasonable amount of time. Once you have verified the amp readings, check the voltage. To check the voltage, Connect the voltage meter lead the same way you would in a battery static voltage check, Start engine (do not drive). At engine idle, the voltage should be between 13.6 to 14.3 volts. If not the alternator may need replacing.
  • NOTE_ Be sure to inspect the battery terminals for connectivity issues such as corrosion and so fourth..
Nov 21, 2010 | 2003 GMC Sierra 1500
How to diagnose charging system red warning light on
There seems to be a no charge state in this case. I recommend checking the charging system. Flow the procedure below to isolate this issue.
Wear protective eye wear and clothing and remove all jewelry when checking your battery and charging system. Jewelry is a good conductor of electricity and is not recommended. Most batteries wear out every 3 to 5 years and need to be replaced. Always replace your battery with an equal replacement battery to assure proper operation. Automotive batteries have a +positive terminal (red), - negative terminal (black). Electricity is stored in the battery and then supplied to the vehicle when the engine is not running. While the engine is running the vehicles alternator charges the battery for future use.(((-Warning-))) Never disconnect the battery while the engine is running. If the battery cable is disconnected from the battery a spark can be generated which can cause the battery to explode or a major electrical malfunction to occur.
  • NOTE_ Alternator's cannot sustain maximum output for long periods of time. If the alternator is forced to operate at maximum output it will overheat and fail. An alternator is designed to operate at max amperage output only for a reasonable amount of time.
  • NOTE_Connect the voltage meter lead the same way you would in a battery static voltage check, Start engine (do not drive) at engine idle the voltage should be between 13.6 to 14.3 volts. If not the alternator may need to be replaced.
Jul 01, 2010 | 1996 Nissan Maxima
Why is my charging light coming on at 2000 revs
There seems to be a no charge state in this case. I recommend checking the charging system. use the procedure below to isolate this issue.
Jan 17, 2010 | Renault 181 Cars & Trucks
1997 seville SLS, is showing ''batery no charge'' took the Battery and Gen into the local parts store ad they checked OK. ??? did not find any broken wires. a little rust and corosion on the ground wire...
Dec 29, 2009 | 1997 Cadillac Seville
1997 eclipse has to be charged every day in order to drive
Dec 22, 2009 | 1997 Mitsubishi Eclipse
1996 SATURN 16 VALVE TWIN CAM BATTERY LIGHT CAME ON THEN TWO DAYS LATER WOULDN'T START
Nov 10, 2009 | 1996 Saturn SC
2000 ford zx2, battery light keeps coming on/off, had alt checked (good), battery checked (good), could this possibily be a wiring issue (short/bad connection)?
Nov 02, 2009 | Ford ZX2 Cars & Trucks
The alternator is good, new battery , wont stay charged
Ok, i understand that you have replaced the alternator, but there seems to be a non charge state in this case. i recommend checking the charging system. use the procedure below to isolate this issue.
Wear protective eye wear and clothing and remove all jewelry when checking your battery and charging system. Jewelry is a good conductor of electricity and is not recommended. Most batteries wear out every 3 to 5 years and need to be replaced. Always replace your battery with an equal replacement battery to assure proper operation. Automotive batteries have a +positive terminal (red), - negative terminal (black). The battery in this illustration has a protective cover over the positive terminal to prevent short circuit in case of an accident. Electricity is stored in the battery and then supplied to the vehicle when the engine is not running. While the engine is running the vehicles alternator charges the battery for future use. (Note: never disconnect the battery while the engine is running. If the battery cable is disconnected from the battery a spark can be generated which can cause the battery to explode or a major electrical malfunction to occur.)
Sep 30, 2009 | 2006 Chevrolet Aveo
Challenger Battery, 8.4V 900mAh NiMH 7-Cell. Works with RC Airplane Models: Commander Logo
54 people viewed this question
Top Challenger Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Challenger Toy Expert? Answer questions, earn points and help others
