Back to:
Tags:
Jensen Q2749J 27
Jensen q2749j (by 2 users)
posted by rigdig34 on May 20, 2007
picked up this tv for free,problem is seems like no red in picture just blue and green.any ideas on fixing or approximate cost?
thanks
shane
Comment by rigdig34, posted on May 20, 2007
thanks will try it tonite
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by Macdumby1, posted on Apr 14, 2008
Love the set/picture when I have all three colors. Most recently the red went out. It comes and goes so I don't think it's serious. Which connections do I look for to see if the solder contacts are loose?
Mac
Best Solution
Helpful (85)
Johannah
Rank:Wiz Wiz
Rating: 80%, 43 votes
if u know about fixing appliances, u may open it and check the CRT Board for looose solder on the three color driver transistor or the IC Pins that's responsible for the color. simply soldering the pins and components nearby may fixed the problem. More serious cases may need a true technician.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on jensen q2749j:
I don't want to Accept this solution
Can you Help with these Standard Televisions problems?
Jensen Q2749J 27" TV
The bottom half of the screen is solid black. Pressing the...
The + volume button no longer works
i was watching tv when suddenly it went out. i unplugged...
no sound when first truned on after warmed up sound is...
My child locked our T V by mistake and we do not have the...
Loading problems.
Repair Service
Find Standard TV Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
