Question about Sanyo SR-3770S Compact Refrigerator
Sanyo SR-3770S (3.7 cu. ft.) Compact Refrigerator manual
4 Suggested Answers
Agent Dort
  • 216 Answers
SOURCE: Sanyo SR-4912M 4.9 cu ft refrig temp problems
Greetings macx,
The average refrigerator temperature is between 35 & 38 degrees. The maximum temperature a refrigerator can be before bacteria begins to grow is 39 degrees. It would be my recommendation to exchange this unit if you can at your local retailer. If this was purchased at Best Buy, you have a 30 day return/exchange policy on this item with no restocking fee.
Thank you,
Agent Dort
Go Ahead. Use Us.
Posted on Apr 17, 2008
SOURCE: Where to buy Sanyo SR-366 parts? I need a freezer door.
I will probably have one, I'll look to see if it can easily be removed.
Posted on Mar 25, 2009
SOURCE: Sanyo 4.9cu.ft. compact refrigerator heats rather than cools
I'd already picked up a replacement (B&D 2.7cf) before I found the website and asked the question,,,, hoped for a quick fix answer and I'd be able to return the B&D.... oh well. With 'designed' obsolescence and 'disposable' appliances, Robert L's answer confirmed my 'fears'.
Now I'm trying to find someone locally (Conroe, TX) who would like to 'recycle' the Sanyo (everything but the compressor/motor is in great shape - door, glass shelves, etc. maybe even the coolant which I don't want to 'dump' in a landfill.
Posted on Jul 23, 2009
Hissing snayo sr 3660s
That's the refrigerant coming out. Major fix. I am not a ref tech, so I do not know if there is a guaranteed welding technique to do an effective weld on those refrigerator coils.
Jun 11, 2014 | Sanyo SR-3770S Compact Refrigerator
MY REFRIGERATOR'S EXTERIOR WALL ARE BOTH HOT WHEN IT IS RUNNING. HOW TO FIX IT?
It is possible that the condenser coils are located in the side wall panel. This is fairly normal is small refrigerators.
Mar 26, 2014 | Sanyo SR-3770S Compact Refrigerator
Tha comparesor do not work
If the refrigerator is getting power and the thermostat is good and the compressor is receiving power and does not run, then the compressor is no good or the start capacitor (if there is one) is no good. Replacing the capacitor is better since replacing the compressor is expensive; when you factor in the labor cost and age of unit, often the best thing is to just go out and get a new fridge.
Nov 27, 2013 | Sanyo SR-3770S Compact Refrigerator
How do you get the drip tray to come out of the SR3770S
pull it foward about 8 inches , then tilt it up slide drip tray out frontwards
Oct 04, 2011 | Sanyo SR-3770S Compact Refrigerator
I have a Sanyo SR-3770S Refrigerator and I defrosted it last night after turning it off and unplugging it. After it had defrosted I plugged it back in and turned it back on at a medium setting and let it...
Greetings
Do you hear the compressor running and no refrigeration? If yes, feel around the back fror the condenser coils.Near the compressor ,the condenser tubing should be very hot to the touch.If not , you have no or low refridgerant. You may have punctured an evap coil during defrost.
After 8 hours evaporator should be ice cold.
If compressor is not running it's thermostat
Was this helpful?
Aug 18, 2011 | Sanyo SR-3770S Compact Refrigerator
After someone cleaned my sanyo 3370 refrigerator it's on nut not getting cold.I hear a noise but not sure what it is.
it sounds like ice has built up on the evaporator. This is will prevent air flow that will cool the fridge, it will also touch the fan and make a noise.
You may find that the defrost heater has been dislodged from it's normal position and can no longer melt the ice on defrost.
You should get a technician to fix this problem
Mar 24, 2011 | Sanyo SR-3770S Compact Refrigerator
Items freezing in refrigerator
You can turn the temperature down by adjusting the temperature dial located within the refrigerator.
Mar 01, 2011 | Sanyo SR-3770S Compact Refrigerator
Broken glass shelves- SR-4433S
you would have to order them from sanyo at www.us.sany.com
Oct 20, 2007 | Sanyo 4.4 cu. ft Counter-High...
Freezer compartment on Sanyo SR-3660S
Nope. That's about $800 bucks in damage that only a licensed professional CFC tech could "possibly" repair with very specialized equipment. I'm afraid that was a fatal blow to your refrigerator.
Feb 04, 2007 | Sanyo SR-3770S Compact Refrigerator
Sanyo SR-3770S Compact Refrigerator Logo
75 people viewed this question
Top Sanyo Refrigerators Experts
John Tripp
John Tripp
christian nielsen
Are you a Sanyo Refrigerator Expert? Answer questions, earn points and help others
