Question about Whirlpool LEW0050P Electric Dryer
Dryer blower motor runs slow and makes loud humming noise.
I suspect that the run capacitor is defective. Attempting to increase the motor speed by hand turning the shaft (which sometimes works with centrifugal switch motors ) did not help. I have researched for online parts and found none in stock. Before I special order a non-returnable part I thought it best to confirm my troubleshooting. The motor windings are not shorted to the case ( vom readings not megger ) nor are they discolored. The windings read approx. 24 ohms across the input connectors with or without the cap. The red wire to the input power connector is not used but measures 26 ohms to purple and 42 to blue. If my logic is correct, I would also like to confirm that AP3964628 is the correct number for the capicator and also find out about availability / price. Thanks Clif
It will almost certainly be the capacitor. Instead of buying the $60 part thru parts suppliers, I went to a local engine repair shop and bought one for $8.50 and installed it. It worked fine.
You can order the part from Beidlers motor repair, just as I did. Their number is (304) 263-9995
Posted on Dec 05, 2009
    Problem Solver:
  • 11 Answers
Try to check the drive coupling of the dryer if it is not loose to the drive shaft.
Posted on Mar 21, 2009
  • arthurpj1765 Mar 21, 2009
LG Tromm electric dryer model DLE5977B is making an extremely loud humming noise.
Humming is caused when the slow start capacitor on the motor fails. Better to buy a new dryer as the motor is usually around $160. Yours is $145. I suggest you take professional advice on such a high outlay rather than risking the advice of someone who hasn't physically checked the machine. I have two pro dryers in my hotel fail, and they buzzed.
LG Dryer Model DLE5977B Parts
Feb 02, 2017 | LG Dryers
Dryer starts and runs fine but makes a loud buzzing noise from the motor that sounds a lot like the end of cycle signal
FIXED Dryer won't start. Makes electrical buzzing noise - model ...
www.applianceblog.com/.../7655-Dryer-won-t-start-Makes-electrical-buz...
Feb 12, 2007 - 10 posts - ‎1 author
It makes electrical buzzing noise when you press the start button. ... One would think that if it's the fuse that it wouldn't buzz at all but ... unplugged, re-assembled back, hooked back up to hose, turned on and running hot .... The belt was fine. ... Kenmore gas dryer 70 series is making very loud buzzing noise.
Troubleshooting Your Dryer Noises ' PartSelect.com ...
? 4:32
https://www.youtube.com/watch?v=Tk1YezyYMDY
Aug 26, 2011 - Uploaded by PartSelect
In this video you'll learn why your dryer may be making a variety of ... that is not only making a grinding noise but it also makes a loud banging noise. ... it's been drying about 15-20 min. it startsa loud humming sound. ... The dryer is working just fine, but I am concerned about the noise as it sounds electrical.
DRYER BUZZING NOISE - Dryer For Sale
Dec 18, 2015 | Amana DLE330RAW Electric Dryer
Dryer stops
If the hum is loud I would suspect something is jammed and the motor is stopped leading to a heavy current running through the motor. After 5 or 10 minutes I would anticipate the circuit breaker would trip or the motor would burn up. If the humming suddenly stops then a thermal overload switch might be activating and when it cools down normal operation resumes. This is my only insight.
Jun 08, 2013 | Kenmore 73952 Gas Dryer
My blower is making a humming noise, I can see the motor moving very slowly. Is it possible it's just dirty or do I need to replace it?
Hello, dirt or a weak run capacitor will cause the motor to run slow, if the blower whell is clean then change out the capacitor.
Sep 05, 2011 | Heating & Cooling
I get a loud humming noise . The dryer works good but makes a loud humming noise when it's working .
The motor is going bad and this will make that loud humming when it is running...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 25, 2010 | Maytag Dryers
LG DLE5977W electric dryer hums when attempting to restart
This is usually the motor but not always. Remove the belt. Check for obstructions in the blower fan housing. Manually rotate the shaft of the motor.
If the motor is very stiff, or impossible to rotate manually, and the blower fan housing is clear, you need to replace the motor. If the motor rotates freely, run the motor momentarily with the belt removed and the blower in place. If the motor runs fine with the belt removed, there may be a problem with the idler pulley or the clothes drum. Try to rotate the drum by hand. If it is very difficult to move, correct any problem with the rollers, pulley, rear bearing, then reassemble the dryer and try it again. If the motor hums but doesn't rotate on its own even with the belt removed--yet you can turn it freely by hand--you usually need to replace the motor or the motor start capacitor. You can also enter your model # for diagrams and illustrations at www.appliancehelponline.com
Mar 31, 2010 | LG DLE5977 Electric Dryer
Blower makes a loud humming noise and does not start. With a push on the blower it will begin to run.
find and replace the start capacitor. If it has none, you will need to replace the motor.
Feb 22, 2010 | Heating & Cooling
Motor making loud humming noises and kicks out. Could this be a capacitor on the motor going bad ? This doesn"t happen all the time, but frequency is increasing.
this is the motor overheating and, the overload shutting down the motor: check to see if the motor belt is binding
Jan 23, 2010 | Washing Machines
Dryer making loud noise
the humming noise is most likely your motor. does it overheat or shut down on you? do you smell anykind of burning? Joe
Nov 14, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Whirlpool LEW0050P Electric Dryer Logo
570 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
