Question about Crosley 40-pint Dehumidifier
Dehumidifer - Working??? Not Sure.
I have a Crosley dehumidifier that sits on a shelf in a wall. The back side of the unit (air intake side) is open to my utility room that is completely enclosed. The front side of the unit faces my finished basement. I have a drain hose hooked up to the back. Lately (over the last 2-3 months) I'm noticing that the drip pan has alot of dust and the coils don't seem to get cold anymore. Is it just because the intake room is really that dry and maybe I should install some ventalation so air from the finished portion of the basement flow in or has the unit just stopped working?
If you can verify that the compressor is still active (is there a noticeable hum or buzz and / or do the room lights slightly dim during power on?) then the most likely problem is a loss of freon. if the compressor never turns on, then a faulty humidistat is likely...an electrician can run a test of this by "jumpering it out" to force on the compressor motor.
Posted on May 20, 2007
Whirlpool Basement Dehumidifer is freezing up about l/3 from the bottom. Compressor will not turn off. Coils were cleaned and cleaned fan is running freely. Sitting in well ventilated area and temp...
IIt may very well be that the the air intake filter needs to be removed and cleaned. But, before doing this, turn the unit OFF & unplug it. Allow the unit to completely thaw, before removing the filter.Never operate the unit without the filter in place, As this could damage the unit.
Hope this helps you & thanks for choosing FixYa.
Sep 11, 2011 | Whirlpool Gold AD70USS 70 Pint Per Day...
My dehumidifer collect water but the fan blows hot her so it makes the room hotter
This may be caused by running the unit in continuous mode, rather than timed mode. The heat is generally is generated when the defrost mode cycles on, to defrost the cooling coils. This happens more frequently, if the air space around the unit is obstructed or it's operating in a temperature range of 40 to 60 F. Cleaning the air intake filter at least once a week, can help solve this problem, too.
Maintain a minimum of 12" free air space around all sides of the dehumidifier. Use a timed mode rather than a continuous mode. Make sure the room is within the proper operating temperature range and clean the air intake filter weekly.
Hope this helped you troubleshoot and solve the problem.
May 28, 2011 | Maytag M7DH65B2A Dehumidifier
Need float switch that cuts off dehumidifer when bucket gets full
Without a Model Number or Part Number it's hard to help you. But here are three links, where you can find the float switch, if it's still available. You'll definitely need the Model Number to find anything.
http://www.apwagner.com/index.php?main_page=page&id=148
http://www.appliancepartspros.com/crosley-dehumidifier-parts.aspx
http://www.partselect.com/Entry.aspx?Source=GAWS&Brand=Crosley&Term=crosley+dehumidifier+parts&gclid=CIzJ3ZvR4KgCFcV95Qodnh3C0g
Hope this helepd you. Please let me know. Thanks.
May 11, 2011 | Crosley 40-pint Dehumidifier
Dehumidifer will not turn on. An E2 code comes up on the panel. Has been working fine for 4 day.
Since it has been working well for 4 days, it may be a case that the unit needs to reset itself. To accomplish this, turn the Master ON/OFF Switch to OFF. Unplug the unit from the wall outlet and wait 12 - 15 minutes. Then plug the unit back into the wall outlet and turn the Master ON/OFF Switch to ON. Set the controls as you normally do. Hopefully, that timeout allowed the unit to reset itself. Also, check to make sure that the water collection bucket is installed properly and is making good contact with the safety switch.
Hope this helps you solve the problem.
Apr 27, 2011 | Haier 45-Pint Dehumidifier
My dehumidifer is freezing up what could b wrong
If the air intake filter is dirty, that can affect the operation and cause it to freeze up. Operating in temperatures below 40 degrees will also cause it. Or a low refrigerant level can also cause it. Turn the unit OFF and unplug it. Place some old towels under the unit to absorb any dripping water. Once the unit has completely thawed, remove the filter and clean it. Carefully replace the filter (be sure it's dry) and give the unit a try.
Mar 24, 2011 | Whirlpool Dehumidifiers
Frost
Dehumidifiers2_bing.gif freezing up can be causes by a few different problems.
Here is a tip that I wrote to help people with the freezing dehumidifier2_bing.gif problem....
Dehumidifier2_bing.gif is Freezing up and not working
http://www.fixya.com/support/r4662033-dehumidifier_freezing_up_not_working
heatman101
May 17, 2010 | Goldstar DH304 Dehumidifier
The dehumidifer doesn't
sounds like your evaporator coil is dirty its the coil where the air goes in
Apr 08, 2010 | Whirlpool AD50USL Dehumidifier
Need manual for fedder dehumidifer to hook up drain hose. need to know were drain hose connects.
Pull out the water collection tray. You will see a small pipe (about 1/2" diameter) in the top of the area where the tray came from. This is the "drain" that fills the tray. Connect a hose to this pipe and run the hose to a floor drain if you have one. I used a section from an old garden hose for my unit. There also may be a small opening in the back wall of the dehumidifier to route the hose more aesthetically.
Dennis
Jun 12, 2009 | Fedders A7DH45B2A Dehumidifier
Unit Runs (fan and condenser) but no water?
By condenser I assume you mean the compressor is running. Is there ice forming on the front coil?
Jan 08, 2008 | Comfort-Aire BHD-651 Dehumidifier
Maytag Dehumidifer
Hello Jaws,Sounds like either Shorted Plug or Compressor....Let me Know ttech
Jul 24, 2007 | Maytag M7DH45B2A Dehumidifier
Open Questions:
Crosley 40-pint Dehumidifier Logo
149 people viewed this question
Top Crosley Dehumidifiers Experts
Gil Shultz
Michael Youngman
Michael Youngman
Marvin
Marvin
Are you a Crosley Dehumidifier Expert? Answer questions, earn points and help others
