Question about Microwave Ovens
Panasonic Microwave only works for 37 secs no matter what time setting
My microwave will only work for 37 secs no matter what time setting I insert and it does not heat up even over this 37 seconds
I have tried to re start but that has not worked either.
Thoughts? I have the exact same problem, turns on for approx. 25-30 seconds and then shuts off, does not heat during the brief time it is on.
Oven is approx. 1 year old - Panasonic Model T795, 1200w INVERTER
  • Microwave Ovens Master
  • 9,098 Answers
If it stops after 22 seconds, that means the controller has detected a problem, usually a problem with the inverter or a bad magnetron.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here.
In Canada, you can find an authorized Panasonic servicer here.
Posted on Jan 04, 2009
Why does my panasic the gemius sensor 1300 if i set it for 29 sec. it cut off at 7 sec why
The microwave is defective. If you owned it less than 90 days, take it back to the store but get a different brand of microwave. A few people purchased the same one that you bought and in lasted less than 1 year. The problem. It does not work at all.
Jun 04, 2014 | Panasonic NN-SN657SMicrowave Oven
I have a Panasonic combination microwave, NNA753. The microwave has stopped working. When I put it on with 1/2 cup of water in it, it runs for 27 secs and then switches off. I have tried doing this...
Magnetron fault. This requires service through an authorised Panasonic service department as it is extremely specialised due to the type of technology employed with this machine.
The unit is not heating in the time set by the sensor.
Jan 19, 2011 | Panasonic Microwave Ovens
My Panasonic Micro Oven is working for 37 secs and cuts off. What is your advice - to repair or replace it with a new one?
generally this problem occurs when the sensor detects overheating. Make sure all the vents are clear and there is a good air circulation around the unit.
Replacementonly necessary , if the suggestion is incorrect.
Please rate my help++++Thanks for using Fixya
Nov 29, 2009 | Panasonic NN-S760WA Microwave Oven
Microwave settings switch off after 22 secs/30 secs
If it stops after 22 seconds, that means the controller has detected a problem, usually a problem with the inverter, controller, magnetron, or a bad connection from one or the other.
Aug 30, 2009 | Panasonic Microwave Ovens
Panasonic microwave ''times out''
sounds like the control has become corrupted. try unplugging the unit for 5 min plug it in and try it again.. if it continues to do it then the control board may need to be replaced..
Feb 13, 2009 | Panasonic Microwave Ovens
Panasonic mocrowave oven resets itself
Try unplugging the microwave for about 30 seconds, then plug back in. This may work. What you are doing is resetting the micro processor.
Dec 26, 2008 | Panasonic NN-H264 Microwave Oven
Microwave shuts off before time elapes
If it stops at 16 seconds and is a sensor model, it probably has a defective humidity sensor.
The best place to order Panasonic parts is Tritronics. You can also call them at 866-779-5835.
If you prefer, you can find an authorized Panasonic servicer here.
Dec 07, 2008 | Panasonic NN-T990SA Microwave Oven
Micrwave does not heat, and turns off by itself before time
Unplug the Microwave and remove the outer cabinet. Inside the cabinet will be a thermal insulated fuse, looks like the old buss fuses for early model cars but white. Replace that with the correct fuse which can be found at Lowes or Home depot and see if that solves the problem. Be careful not to touch any capacitors if they are in there.
Mar 14, 2008 | Panasonic NN-H664 Microwave Oven
Microwave Ovens Logo
332 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
