Question about Dryers
Drum on drter does not turn
It sounds like the motor is humming like it cant turn the drum & not like the belt is off, the lights in my service porch, where the dryer is, get much brighter for about 1.5 seconds then the humming stops after a min passes the timed cycle minutes remaining goes from 40 to 39 & it tries to start the drum again. it does this over & over. when i first noticed the dryer doing this it read 32min remaining on the display, i dont think the drum had spun at all on this load. somebody help this was a rather expensive purchase just 4 years ago, & now im without work & can not afford to even have it repaired by a tech let alone buy a new one. thanks
    Top Expert:
  • Dryers Master
  • 9,472 Answers
Ckeck for a blockage at the motor or blower fan assembly.
Posted on Nov 04, 2012
TheMobilian
  • 8220 Answers
SOURCE: Fridgidaire Gas Dryer - Mod.#FDG
Your glides are brobably broken and missing. This will make the drum hard to turn and bind the motor. Get the front off the dryer:
7411f19.jpgStart by popping the top with a putty knife.
Get the screws out that hold the front on and take a look:
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Dec 16, 2008
  • 4 Answers
SOURCE: Dryer turns off after 30 seconds and beeps six times (over and over.....)
there is a moisture sensor by the lint screen, that could be defective.
Posted on Dec 23, 2008
  • 351 Answers
SOURCE: Dryer not starting, has to be "jump started"
Yes, that would be a motor, but i would fix it, kenmore is a very good brand, easy to replace and what not, my upmost suggestion is to change the motor, and if you want it to really be a superb dryer i would buy the maint. kit, includes rollers, idler and belt. other than that these dryers are great the timers hold up and door switch's are pretty strong. while you do this i would make sure it is all clean.. here is a link to my site get the number and give me a call if you would like....www.whirlpoolpartssurplus.com
Posted on May 09, 2009
  • 24 Answers
SOURCE: The heating compenent works, but drum won't spin
Have you checked the belt? That's generally the problem when a dryer stops spinning.
Posted on May 19, 2009
  • 864 Answers
SOURCE: LG DLE5977W dryer has stopped and developed a motor hum. How can I fix it?
I am assuming that the hum indicates the motor is running but the drum is not turning.  Possibly a broken drum belt however the check filter warning is indicating low air flow so the blower wheel could be broken at the connection to the motor shaft.
Posted on Jun 01, 2009
Drum doesnt turn the motor just hums.If I hold the button in and spin the drum by hand the dryer runs okay.
down load a service manual you didnt give a make an model so i cant give you a link
Aug 08, 2015 | Dryers
My dryer only makes a humming sound
Remove the drum belt & start it if it hums and starts hard you will need a motor. If it don't hum check the drum rollers & glides on the front. Check the idler pully and belt. Drum rollers should turn easy if not either replace of try oiling them with some good oil after cleaning them real good. Hope this helps
Mar 01, 2014 | Whirlpool GEW9250 Electric Dryer
Dryer motor just hums, drum doesn't turn
check belt drum drive? check drum turns at all, it may be stuck.most drums turn with a belt. if it broke it is laying on the bottom of the dryer.didnt u see it??look again.
Apr 21, 2013 | Kenmore 98702 Stacked Washer/Dryer
My LG Tronn Dryer will not turn. The Check Filter light was on and we cleaned the filters and it went off. The dryer hums when the power is on but does not come on or the drum does not move. The drum
listen carefully to the hum if it sounds like the motor is running its a broken belt, if it sounds like its not turning it could be the capacitor on the motor.
Dec 17, 2012 | LG Dryers
When we push the on button, you can hear a hum,
Sounds like the belt that turns the drum has broken. the hum sound is the motor turning. Does it still get hot in the drum? If so then you need a replacement belt ($15-$25).You can open the rear or the dryer to confirm the belt is broken. Be sure to unplug from the wall outlet to avoid electrical shock.
Aug 18, 2009 | Dryers
Humming sound
If you open the door can you turn the inner drum by hand , if you can is any there any resistance or does it just spin freely
It sounds as if your drive belt has snapped and what you hear is the motor running on its own
If the drum spins freely you will need to take the back off the machine and see what state the drive belt is in
Ps
Is there heat inside the drum when you try to make it work without a load.
Jun 05, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Sounds like the belt has been stretched and is not letting the motor turn the drum. If the motor is not turning at all then your motor is burnt out and needs ot be replaced
May 22, 2009 | Dryers
Push start and motor hums, but nothing else works.
Hi, If you release the start button, does the hum stop? It sounds like hte start winding in the motor is bad. You can try and start it manualy by truning the timer on, open the door so that you can turn the drum with your hand. You will need anoth person there so that one of you can hold the door switch button in and the other push the start button. While pushing the start button, try turning the tub and see if it starts. This will give you an idea on the motor bad or not.
I hope this helps. Please let me know if you need any more assistance.
Thanks
Vic
May 12, 2009 | Dryers
Dryers Logo
Top Dryers Experts
