Question about Epson STYLUS R230 InkJet Photo Printer
My Epson R230x printer get paper james and not feed paper, how can I solve or repair this problem
Paper feeding &paper James problem?
    Top Expert:
  • Epson Master
  • 11,573 Answers
Epson Clear a paper jam in printer
Posted on Aug 03, 2016
    New Friend:
My problem do you what pepar gsm.?
Posted on Apr 28, 2013
5 Suggested Answers
SOURCE: paper doesn't always feed, and when it does, the paper rolls through without printing
Get a Q-Tip and alcohol. Wet Q-tip with alcohol. Stand in front of the printer and look down where the paper feeds through. On the righthand side you will see a big roller that pulls the paper through and a little one right up under that. Clean both of them with the alcohol and Q-tip. Press the paper feed button and as it trys to act like it is feeding the paper, clean the roller with the Q-tip. Do this until the paper feeds through correctly.
Posted on Jun 01, 2009
SOURCE: paper will not feed through - epson DX4000 printer/scanner
Did you check the thickness? My printer won't feed paper that's to think or thick properly it sould say in the manual what thickness of paper you should use.
Posted on Mar 24, 2009
aicaxz
  • 511 Answers
SOURCE: alternate flashing red lights on epson stylus photo 900
Flashing alternately? Need reset waste ink. SSc ver 4.3 support this model. Find at indoreset.blogspot.com.
Posted on Jun 26, 2009
  • 115 Answers
SOURCE: paper will not feed into printer epson r300 printer
This is a common prob of all epson printer. If you use more than 230GSM thickness paper with the printer and use 80 gsm paper next, it wont pick up. This is due to the spring in the back side of the paper picker unit elangated to more thickness and fail to function fully. you can remove the paper pickup unit and change the spring if you have the service manual.
Posted on Aug 11, 2009
i want to know. printer back side some gape i see. but i don't know which work do in this back side.
Nov 04, 2012 | Epson STYLUS R230 InkJet Photo Printer
Paper jam
Removed the jamed paper clean properly , reset the printer & start it.
Thanks, i am waiting for your feed back & if you satisfied then thumps me please.
Jan 31, 2010 | Epson TM-T88III (C420863)
Xante Ilumina paper james on duplexing
Are your settings for media type and media weight are correct. Remember different paper, different settings. Make sure your feed rollers are not worn, if worn replace them. A lot of paper jams are caused by miss-feeding, due to worn feed rollers(try cleaning them with alcohol).
May 21, 2009 | Xante Ilumina Digital Color Press Printer
Paper will not feed through - epson DX4000 printer/scanner
Mar 24, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Paper jam on initial feed
It sounds to me like your pickup rollers are worn. You should order a new set and replace them. That should solve your paper jam issue.
Feb 15, 2009 | Brother MFC 7420 All-In-One Laser Printer
Paper feed problem on Epson C87
In view of vk_malik's lack of interest in this problem, I think we may declare it "solved by poster"
Nov 24, 2008 | Lexmark X644e All-In-One Laser Printer
My epson cs7800
I had the same problem and found a small spring was loose and interfering with the paper. The Spring was on the right side as you look at the printer, near the bottom of the paper feeder. I took it out and it works fine, for now.
Jun 15, 2008 | Epson Stylus CX7800 All-In-One InkJet...
Paper Jamming
Could be a faulty roller, or jam you have not found yet. Check again with a torch right up insied unit. If no go, try uninstalling and reinstalling printer.
Jun 29, 2007 | Canon PIXMA MP150 All-In-One InkJet...
Epson STYLUS R230 InkJet Photo Printer Logo
233 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
