Question about Health & Beauty
I need a users manual for the Homedics Model 86712
There's a remote outdoor temp sensor that comes with the clock. It's radio controled as is the clock. PPSSRMT1 is the model number of the outside temp sensor.
robotek
  • 1512 Answers
SOURCE: Need radio shack remote control code.
It will be one of these codes.
Orion 0236, 0463, 1463
http://www.remotecentral.com/cgi-bin/files/rcfiles.cgi?area=other&db=devices&br=radioshack&dv=universalremote&md=1521473in1easytouse&kw=&st=&ar=&dt=&so=&pg=3&file=others/radio_shack/152147-manual.zip
you can go to the manual direct at. Good luck
Posted on Jan 29, 2008
  • 3 Answers
SOURCE: 3M Precision Digital Atomic Wall
After replacing the transmitter batteries several times, I tried replacing the clock batteries. They must have been getting low. Once I put in new batteries in the clock it worked fine. Good Luck.
Posted on Jan 15, 2009
SOURCE: Wireless thermo clock not reading outside temp
I've had a similar problem with another model, an Oregon Scientific Model IWA-80055 Wireless Thermo Clock, in which when I replaced the batteries in the remote sensor, the clock would not read the temperature from the remote sensor.
I found it fairly consistent to solve this by taking a battery out of place in the clock and putting it back in.  Unfortunately this also messed up the clock's time and date.  This is also in the instructions catalogue for the device, check and see if yours gives a similar solution.
Posted on Apr 13, 2009
SOURCE: Lexibook Meteo Clock Weather Station needs resetting - help!
Manuals online at http://group.lexibook.com/index.php?option=com_content&view=article&id=87&Itemid=105〈=en
Posted on Nov 19, 2009
  • 484 Answers
SOURCE: I need an owner's manual
You can download the manual using this link:
http://www.retrevo.com/support/Memorex-MC2864-CD-Players-manual/id/18501ci872/t/2/
Thanks.
gylacz
Posted on Jul 07, 2011
Do not have the manual for model ss-5050
Search Results
    HoMedics SS-5010 Clock Radio User Manual - Portable ...
    portablemedia.manualsonline.com > ... > HoMedics Clock Radio
    de obra por un plazo de un a?o a partir de la fecha de compra original, con las siguientes excepciones. HoMedics garantiza que sus productos no tendr?n ...
    Free HoMedics Clock Radio User Manuals ' ManualsOnline ...
Dec 21, 2015 | Audio Players & Recorders
Outdoor display doesn't work
My clock display of the outdoor temp is only blinking and not display the the temp. I have the senser put in in outdoor window. The senser shoes the temp but is not carried over to the clock. Ive put in new batteries and have the senser in the correct distence from eachother. Why is the clock contunue blinking outdoor temp.?
Jan 15, 2013 | Audio Players & Recorders
The wireless transmitter doesn't work
Mine quits working when the batteries in the outdoor part need changed .
Dec 15, 2017 | Centrios Audio Players & Recorders
Need the specs for the Homedics ss-5010 power adaptor
Product Attributes
Product attributeProduct Line: SoundSpa
Product attributeProduct Model: SS-5010
Product Summary
Manufacturer: Homedics
Mfg Part#: SS-5010
Buy.com Sku: 211467114
UPC: 031262038029
UPC 14: 00031262038029
Package Weight: 1.9 lbs
Buy.com Sales Rank: 64081
Advertisement middle
Features
Product Type Desktop Clock Radio
Manufacturer Part Number SS-5010
Manufacturer Website Address www.homedics.com
Manufacturer HoMedics EMEA
Product Model SS-5010
Product Name SoundSpa Premier SS-5010 Clock Radio
Product Line SoundSpa
Brand Name HoMedics
Frequency Band/Bandwidth AM/ FM
Tech Specs
Brand Name HoMedics
Frequency Band/Bandwidth AM/FM
Feb 13, 2011 | Audio Players & Recorders
HOW DO YOU SET THE HOMEDICS SS-4500
http://www.retrevo.com/s/Homedics-SS-4000-Clock-Radios-review-manual/id/21951bh630/t/1-2/
having the manual will be your best option, just click on the link below
Nov 12, 2009 | Homedics SS-4000 Clock Radio
Shift 3 Projection Alarm clock remote cannot open
Once the batteries are installed in the remote the temp will appear in the LED screen. Now you are ready to link signals between the main unit and the remote. Simply remove one of the two triple A batteries from the main unit and then replace. You should then see what appears to be a flashing object shaped like a kite with a tail while the two units link up. Then you should see the temp reading at the remote appear in the LED readout at the main unit. By the way there is also a very small reset at the top of the switches on the back of the main unit that can be depressed with a SMALL pointed object like a scissor point or safety pin point.
Feb 06, 2009 | La Crosse Projection Alarm Clock with...
Dec 30, 2008 | Oregon Scientific Lwb0997110113004...
SS-5000
the manual seems to indicate that it should be OUTSIDE but under a protected eave if possible.
Jan 09, 2008 | Homedics Sound Spa Premier SS-5000 Clock...
Cant get outside time to work???
I have the same problem with mine. The outside temp displays OK for a while, then it displays two dashs. I unplug the main unit from the wall until the outside temp comes back. I then plug it back in and it works OK. I found that if the remote sensor is located more than 40 ft from the main unit and there are a couple of walls between the two, the outside temp fails more often. I have noticed that putting my wireless phone in it's charging craddle can cause the radio or nature sounds to turn on. I moved the main unit further away from the phone and that cured the problem. Sometimes it will do this if the humidity is low and I build up a static charge and then touch the unit.
Jan 04, 2008 | Homedics Sound Spa Premier SS-5000 Clock...
Health & Beauty Logo
371 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
