Question about Gateway 450ROG Notebook
Gateway laptop wont display my desktop -screen is black
After the windows XP displays and plays its little tune...screen goes black and I never get to my desktop
  • 1 more comment
  • mickfish Jan 15, 2009
    The back light is on but the Windows XP logo and the desktop never show on the screen. I've replaced the motherboard - now wondering what to check.
  • richgato Apr 12, 2009
    after the windows XP displays and plays its little tune...screen goes black and I never get to my desktop
  • Pat Batta
    Pat Batta May 11, 2010
    since when?
    did you changed something?
    Did you tried to revert to older date?
    Problem Solver:
  • 8 Answers
Does backlight stay on, or does it look like the screen is turned off? If it looks like it is turned off, can you look extremely closely and see your desktop if held in good light?
Posted on Jan 10, 2009
Why is my Gateway 4028GZ screen black
The display on this laptop is backlit. What that means, in a nutshell, is that the image on the display prevents the output from a constant light source (the back light) from showing through, thus giving a usable image on the screen. From your description, the backlight is no longer operating. This can be an issue with the LCD display panel, the backlight power module, our (less likely) a power trace on the motherboard. Repair would likely cost as much or more than replacing with a used laptop and just transferring your hard drive. If you choose to replace and swap hard drives make certain that the interface on the new laptop is the same as your Gateway's.
Jun 08, 2017 | Gateway 4028GZ Notebook
My Gateway Profile 5.5 is running Windows XP and it boots up, and gets past the windows XP display and then goes to a black screen. The mouse arrow is still visible when the black screen pops up, but it...
Try the fix I've described in this link:
http://www.fixya.com/support/r4501608-when_windows_xp_start_primary_fix
if that doesn't work, try this next one:
http://www.fixya.com/support/r4501848-when_windows_xp_start_secondary_fix
You can also try to start the computer in safe mode and do a system restore back to when you know it was working. (Just a hint--try this first!!!!)
Aug 02, 2011 | Gateway Profile 5.5 PC Desktop
Lcd screen stuck in external screen mode
How to use the function (Fn) keys on the keyboard - ThinkPad T40, T40p, T41, T41p, T42, T42p, T43, T43p
Switching the display output location.
Switch between the computer display and an external monitor. If an external monitor is attached, the computer output is displayed in the following three patterns by turns:
  • External monitor (CRT display)
  • Computer display and external monitor (LCD + CRT display)
  • Computer display (LCD)
Notes:
  • For any operating system other than Windows 2000 or Windows XP, no additional procedure is needed. Just press Fn+F7.
  • This function is not supported if different desktop images are displayed on the computer display and the external monitor (the Extend desktop function).
  • This function does not work while a DVD movie or a video clip is playing.
To enable this function in Windows 2000 and Windows XP, the following procedure is needed:
  1. When you log on to Windows 2000 and Windows XP for the first time, press Fn + F7 and select a display-switching function in the Initial setup window. Since in Windows 2000 and Windows XP multiple users can log on to a single operating system by using different user IDs, each user needs to select the function in the initial setup window when logging on for the first time.
  2. If the Fn + F7 key combination have been assigned to a presentation scheme function, start Presentation Director, and change the settings.
Feb 28, 2010 | IBM ThinkPad T41 Notebook
Windows XP on my Gateway PC will not accept Viewsonic Widescreen VA1912wSeries . My HP PC broke & I moved the montor to the Gateway. The HP had the same Windows XP system.
Reboot the computer into safemode. to do this tap F8 after the logo screen for gateway goes away. select Safe Mode.
Right click the desktop and click properties. in this window click settings. change the resolution to 1024x768.
click the advanced button. click monitor tab then set the screen refresh rate to 60 hertz.
if the monitor is compatible it will be able to be displayed. else try 1440x900 and 60Hertz for the settings
Feb 12, 2010 | ViewSonic VX2035WM LCD Monitor
I have connected my old dell laptop to this TV with VGA cable and audio cable and it worked with no problem. Have new Acer Aspire one netbook- connected to computer with same cables - can see windows...
First, you want to make sure the laptop's internal/external display mode is set properly. On Acer netbooks, this is usually changed by holding the "Fn" key, and pressing "F5". Either the TV or the computer display should flicker when you do this. There are 3 modes:
1 Computer only
2 TV Only
3 Computer and TV
If changing between thos emodes doens't work, continue on.
I am going to assume you are running Windows XP. Please correct me if I am wrong.
To display your desktop on an external monitor, you'll need to change/check some settings. Your netbook is most likely attempting to set it's display settings automatically, but it is expecting a computer display, not a television, so the resolutions and refresh rates are conflicting. That's why it will only display on one and not the other. Before Windows loads, the netbook is using a very low resolution,so it displays on the TV. Once Windows loads, it switches to some non-standard resolution that your TV cannot display and defaults back to your netbook screen.
The solution is to find a resolution that your television will display:
1.Right-click the desktop, and then click Properties.
2.In the DisplayProperties dialog box, click the Settings tab.
3.Click the Display list and select your external monitor (..the TV. It will most likely be display #2).
4.Select the Extend my Windows desktop onto this monitor option.
5.Select 640x480 in the "Screen Reolution" section for Display #2.
6.Click Apply or OK.
Note: If you see the background change on your television, mmove your mous there to make sure it's working. If it DOES work, go back to the "Screen resolution" section for Display #2 and find the highest resolution your television will display
Sep 19, 2009 | Westinghouse SK-32H540S 32 in. LCD TV
Randomly lost display on my pc.. and its not a faulty card.
Try to set your PCI-E card as a first one in BIOS. There also should be an option to turn off onboard video.
Mar 07, 2009 | Gateway GT4022 PC Desktop
Black screen after windows xp screen nothing else
Sometimes the function keys get depressed by accident and it takes away your display. Press the FN+F5 and FN+F6 three times each and see if your display comes back on.
Dec 27, 2008 | Acer Aspire 1640Z Notebook
Dell Latitude D600 Bootup then screen goes black
bad display drivers, boot into safe mode (F8 on boot) it should let you use the computer, unistall the graphics drivers and reboot again in normal mode, when your in re-install the graphics again
regards
Nov 22, 2008 | Dell Latitude D600 Notebook
Movie Files will not display on the TV.
Its quite possible your laptop has lost its association with your TV as a "secondy monitor".
To check this, minimise everything and right click on the desktop and go to Properties. Then navigate to the settings tab. This will show you how many displays it considers itself to have.
Click on number 2 (if visable) and click on extend my windows desktop to this monitor.
You should now be able to go between screens
Apr 22, 2008 | Toshiba Satellite A105 Notebook
Gateway 450ROG Notebook Logo
284 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
