Question about Toshiba 42H81 42" Rear Projection Television
Tv goes mute when changing channels
Sometimes whe i change channels i lose sound
    Top Expert:
  • Toshiba Master
  • 14,553 Answers
Sometimes may be a bit difficult to find as a problem, once a hour or once a day or what?
Posted on Nov 05, 2012
I have a 60' smart vizio tv and sometime the sound goes out. If you change the channel and go back the sound comes back.Can this be the tv or something else?
Never heard of this problem, but a similar issue seems to be the auto surround sound or TruSurround, whatever it's called. Try disabling that and see if it keeps your audio constant. I disable it on almost every TV I've gotten that had it; sometimes it sounds almost muted otherwise.
Jan 30, 2018 | Vizio Televison & Video
Losing sound when switching channels
A delay can be normal or caused by a glitch---often a cable box will start this---remove if used it and the set from power for a while and plug back to see if helps or not....
Nov 04, 2012 | Toshiba Televison & Video
I have a olevia 37 inch tv that when i turn it on and try to change the channel it goes mute. i tried turning the channel on the tv and same issue, goes mute. sometimes when i turn the tv off and back on...
sounds like av main board in back of tv try factory reset or make sure tv is off 10 mins then open back up try giving it hoover sounds daft but a lot of problems happen dust nothink to lose hope it helps mark google how tofactory reset and then make model of you tv should find help try same youtube videos
Mar 04, 2018 | Televison & Video
My Westinghouse 36 inch TV has picture and sound when I turn it on but when I change channels, the picture disappears and I have only sound. The picture comes back if you turn the TV off and back on but...
Hello, it sounds like your inverter board is goin out on the set, when you change channels if you notice on almost any TV the screen goes dark and the new channel appears, it sounds like you are not getting enough power out of the inverter board to power up the backlight enough to come on. This is why the sound remains because everything else works fine and the sound is connected to the main board.
Nov 22, 2009 | Westinghouse LTV-27w6 27 in. LCD HDTV
Black box comes up on tv screen
The black box is a text box for closed captioning. Some stations send the signal which turns on the box while not actually broadcasting any text. Go into your setup menu and turn off closed captioning, or at least change it to a different mode. The easiest option is to restore factory presets.
Nov 28, 2008 | Polaroid FLM-3732 Television
Yamaha Receiver loses audio when changing DTV stations
I believe changing stations is triggering the protection on receiver. When you go to another input and back you give time for the protection circuitry to release speakers again. Try muting your receiver before changing channels. Good luck!
Nov 21, 2008 | Yamaha RX-V463 Receiver
GE 32GT740 32" TV problem
there are two things that can cause this, 1 there is a muting transistor on the bottom of the PCB that is a surface mount transistor that goes short. this is the channel mute transistor. when you change channels it is designed to mute the static between channel changes. if it shorts then it mutes. 2 the EE-PROM is defective and needs to be replaced. i'de go with the transistor first. if you are unequipped to do this repair have a tech do it.
Mar 02, 2008 | GE 32GT740 32" TV
Sanyo DS32920 Blue Screen
My panasonic Tv pic suddenly turned into a blue color I can't see the pic any more just can hear the audio.....any solutions????
Mar 19, 2006 | Sanyo DS32920 32" TV
Toshiba 42H81 42" Rear Projection Television Logo
56 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
