Question about Maxon Radio Communications
Maxon sl25 power dropping of on one of them when transmitting
I have a pair of vhf maxon sl25 one tests ok i get full power out when transmitting , but the other one goes to full power then as you hold the ptt, the power drops off quite quickly making the range of one much less than the other, they are both transmitting on identical frequencies, is thiere a common fault i can look for ,thanks for any help
    Master:
  • 623 Answers
The output amplifier is defective.
Posted on Nov 05, 2013
2 Suggested Answers
ALLEN CLARKE
  • 47 Answers
SOURCE: maxon SL25
if the band assigned to the radio doesn't cover the frequencies you want then it will not happen. you need to get the software and the right programming lead. make sure the mic socket is good and clean
Posted on Nov 27, 2008
Channel issues
try reprogramming with latest software
Jan 08, 2014 | Motorola Radius Cp125, 4 Ch, W Chargers,...
GME TX3340 not transmitting
You may have a bad microphone, not uncommon problem.
Apr 18, 2012 | Computers & Internet
I have a one year old Raymarine 218 vhf which has been transmitting properly however the receiving has been spotty. I can sometimes only get about 1 mile reception. Lately even the one mile reception has a...
The main cause for lack of reception or transmit distance is the PL259 connector on the antenna coax that plugs into the back of the VHF. Check to make sure this connector is a high quality, marine grade connector. If it screws on and the coax shield is not soldered to the connector I recommend replacing the connector and soldering it. If the problem still exists I would try a different antenna to see if this is the problem. It is possible that the radio itself has a problem, but check these other issues first. Raymarine has a 3 year warranty on their VHFs so you could send it back for a no charge repair if the antenna doesn't solve your problem.
Jun 13, 2010 | Raymarine Ray218 Vhf Radio
Need a part for a maxon pm150
try phoning gb comms on 01388 778368 they repairs taxis radios
Mar 29, 2009 | Radio Communications
Maxon SL25
Nov 19, 2008 | Honeywell Maxon SL25 Two-Way Radio Battery...
Maxon sl70
You may want to search this site for a manual.
http://mods.dk/
Jun 20, 2008 | Maxon GMRS50 (16 Channels) 2-Way Radio
SL55 Not Transmitting/Recieving
the two radios are on different CTCSS Tones
Feb 01, 2008 | Maxon Radio SL55, SP130, SP140, SP150...
Maxon Model MCB10A
In order to test this unit you will need a power meter with a dummy load. connect the power meter and turn on the unit, key the microphone and look at the power meter it should have a reading of < 4 watts PEP unmodulated and = 4 watts PEP modulated. If you do not have this reading the RF transmitter in the CB might be malfunctioning. You will need a RF generator, a power meter with dummy load, oscilloscope and a multimeter to troubleshoot this problem with. If you do not have or do not know what this equipment is or how it works, please take your unit to a CB repair shop. Thank you, Shuttle83
Oct 05, 2007 | Maxon MCB-40 40-Channels Handheld CB Radio
VHF transmit power
Hi, It is not typical but neither is there a problem with the radio. Transmit Power output is loosely dependent on the: 1. Frequency or channel you are transmitting. Normally, Marine Band VHF are calibrated for max (25 in your radio) at Ch16 or 156.800Mhz; 2. If the SWR of the antenna is not a flat 1.0, power tends to go down; 3. After some time, the TX side of the radio needs to be re-calibrated; 4. Power Supply - some radios will push max output only when powered with 13.8 and tends to go down when used with 12 volts. Hope this be of some help/idea. Post back should you need additional information. Good luck and kind regards.
Oct 04, 2007 | Garmin VHF-725 2-Way Radio
Radio Communications Logo
69 people viewed this question
Top Maxon Radio Communications Experts
Steve
Van Allen II
Van Allen II
tvopft
Level 1 Expert
Are you a Maxon Radio Communication Expert? Answer questions, earn points and help others
