Question about Fisher and Paykel Fisher Paykel Intuitive Eco Washer IWL15
Model iw711e, fault code 136 - Fisher and Paykel Fisher Paykel Intuitive Eco Washer IWL15
  • Fisher and P... Expert
  • 554 Answers
136. (10001000) Motor Stall
The Motor Control Module has been unable to start the motor. Possible causes of this fault
are: Faulty motor harness, faulty or jammed motor, seized bearings or seals, faulty Motor
Control Module, faulty Rotor Position Sensor or harness.
Primary Source: Wiring.
Action: Measure/check the motor harness, connectors and motor for
discontinuity. This can be done by taking a resistance measurement
between phases of the motor harness at the Motor Control Module
end. If an incorrect reading is obtained the reading should be taken
directly from the stator.
Secondary Source: Motor.
Action: 1) Check free rotation of the agitator and bowl by rotating by hand.
Bearings and seals may be seized.
2) Check the Rotor Position Sensor and associated harness for
water, mechanical damage or corrosion.
Tertiary Source: Motor Control Module.
Action: If the primary and secondary checks pass inspection, then replace
the Motor Control Module.
Posted on Dec 17, 2013
2 Suggested Answers
  • 713 Answers
SOURCE: Error code 136 Fisher & Pykel washing macine
Hi just read your posting.Now Error code 136 means you have a motor stall fault.This means the motor controller cannot start the motor turning.Has your machine been noisy on spin?The things that cause this fault are,seized or faulty bearings, wiring to the motor faulty,faulty motor,faulty rotor position sensor, or faulty motor controller.Do you have or can borrow an electrical test meter ?If the answer is yes I can guide you throe the testing of the components to track this fault done.Please reply with additional information about the spin cycle and if you can get a meter and I will help you further.
Posted on Jun 19, 2010
Error code 136 on aquasmart wl80t65cw1
If your bowl turns freely bearings are not seized,
Your rotor position sensor must be faulty & not outputting the right signal to the motor controller.
Feb 11, 2013 | Fisher and Paykel Washing Machines
I have a F/P washer model 1w712e The machine will not finish the whole cycle and comes up with the fault 136. can you help as I live in remote area and its not easy to get a service man out.Thank you.
fault code 136.
Motor Stall
The Motor Controller has been unable to start the motor. Possible causes of this fault are: Faulty motor harness, faulty or jammed motor, seized bearings or seals, faulty Motor Controller module, faulty Rotor Position Sensor or harness.
Check the motor harness, connectors and motor for discontinuity. Also check the Rotor Position Sensor and associated harness for water, mechanical damage or corrosion.
Finally Motor Controller module could be gone
Nov 28, 2010 | Fisher and Paykel Washing Machines
My washing machine fills very slowly even though there is plenty of water supply. Sometimes the water only dribbles in. The worse time is on nthe rinse 2 cycle. Now it stops when the machine gets to...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips…
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Sep 01, 2010 | Fisher and Paykel (IWL12)
Washing machine stopped after wash and spin cycle. It would not start rinse cycle until I turned the machine off and restarted it. The message said 'Call for service, fault 136.' Thank you for your...
Hi just read your posting.Now Error Code 136 is called Motor Stall.This means the Motor Controller was unable to start the rotation of the motor.The possible causes of this fault are : Faulty wiring to the motor,faulty or jammed motor,seized bearings or seals,faulty control module,faulty rotor sensor.or wiring to the sensor.Now has your machine been noisy on spin?Could you please confirm the model number of your machine.Has your machine been leaking?Does the machine get a lot of work? Please reply with additional information on the questions and I am sure I can help you track the fault down.Looking forward to your reply.
Aug 06, 2010 | Fisher and Paykel (IWL12)
Jun 19, 2010 | Fisher and Paykel (IWL12)
Calls error code at end of first rinse
Hi just read your posting.Error 136 means you have''Motor Stall " fault. Now just a couple of questions, has your machine been noisy on spin?does the machine leak water?Please reply with answers and I can help you rectify this fault.
Jun 06, 2010 | Fisher and Paykel GWL11 Top Load Washer
What is error code 136 on a fisher & paykel IW709AU top load washer
136 fault is 'motor stall'...Quite often this is a broken wire to the motor. However it could also be a Motor fault, or Rotary Position Sensor problem. Water damage can cause this fault as well. After a visual check for broken wires or water damage, and if your machine is in good condition, you should consider a tech....Good luck...Nomess
May 20, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher Paykel Intuitive Eco Washer - IWL15: what is error code 136 on a fisher & paykel IW...
fault code 136 is a hard one possible causes are faulty rotor speed sensor on motor,siezed bearings or rotor,motor windings ,or motor control module, would suggest you get a tech for this one to diagonse correctty ,without proper tools to test eg: rss tester you could cot yourself more money... hope this was some help....:)
May 18, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
Intuitive eco Fisher & Paykel
try google search for the actual model and fault code
Jun 04, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher & Paykel Washing Machine IWL12
130 rotary position switch fault 136 motor fault
Apr 29, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Washing Machines Logo
149 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
