Question about Relic Watches
How do I remove the stem on a relic ZR15514 mens watch
The second hand fell off and I need to remove the stem to reach the movements.
SOURCE: Watch Band Adjustment
I just got this watch for a gift and was able to remove links myself after doing some research. It really isn't difficult if you are patient, have a little mechanical experience, and have some very basic "tools" available.
Tools:
  • 1 push pin like you use on bulletin boards with a plastic head
  • 1 small hammer like a tack hammer
  • 1 pair of small pliers. Needle nose pliers would be best but I used diagonal wire cutters (be careful not to cut the link pin)
  • 1 small block of wood
Try to pick a well lit table in a room where you will not be interrupted.
Procedure:
1. Lay the watch and band sideways on the block of wood so that a pin for the link you would like to remove is just hanging over the edge of the block and pointing down. You need the block to brace the band while you hammer lightly on the pin. Someone to hold the watch in that position would be helpful, but it can be done alone. Only try to remove pins that have an arrow on the back of the band pointing at them. It does not matter with this watch band which way you go with the pin.
2. Carefully line up the push pin point with the top of the pin.
3. Slowly, lightly and carefully hammer the plastic side of the push pin so that the pin in the link just emerges from the band on the bottom side enough so that you can grab it with the small pliers.
4. Slowly and carefully pull the pin straight out with the pliers. You can pick up the watch from the block of wood to get a better grip. Be careful not to bend the pin since you will need to replace at least one of the pins you remove.
5. Repeat steps 1 - 4 until the band is the correct length. I needed to take out 3 so I removed 2 from one side and 1 from the other side of the clasp.
6. To fasten the watch back together again, gently insert the pin back in the hole it came from it. You will probably need to use the tack hammer to make the top of the pin flush with the band.
Posted on Jan 09, 2008
  • 3 Answers
SOURCE: Remove link form Relic Wrist band
For my relic ZR15372, all I did was take a thin, hard object (a thumbtack in my case) and carefully pushed out the connecting bar from the link.
If you look at the inside of the band of your watch, you may notice that on some of the links (the ones nearest the clasp for me) there is a little arrow pointing at the side - if you look at the side of the links, there should be a little hole, big enough to push a thumbtack into. If you apply enough pressure (again, carefully - no need to stab your thumb or any other part of your body), the connector pin should slide out a little on the other side. Then it's just a matter of pulling the pin out - perhaps a pair of tweezers would do the trick.
Hope this works for you!
Posted on Mar 04, 2008
SOURCE: luminox 3000/3900
I just fixed the same problem .There is a small arrow pointing to a small hole .insert a very thin screw driver or a pin and the stem will come out easily.
Posted on Aug 24, 2008
escapement
  • 2334 Answers
SOURCE: Removing the crown/stem of CASIO EF-321
There is a tiny point (end of small metal piece called setting lever) on the left side of the stem (on watch movement, very close where the stem is entering the movement).
You have to push that point down with a metal pin or tweezers. Crown (winder) must be pushed in to normal position otherwise you will not be able to put the stem back properly.
So, do as follows:
1) Push the crown in,
2) Lay the watch down on flat surface and push on setting lever point,
3) While holding setting lever pushed in- extract the stem by gently pulling crown out of watch.
If this doesn't work- upload picture here.
Do not forget to rate, please.
Posted on Jan 15, 2009
escapement
  • 2334 Answers
SOURCE: taking back off relic watch
If this is screwback, then there should be grooves for inserting case opener claws. For this yoy need case opener with interchangeable claws. You can buy it on ebay for approx. £7.00.
If the casebask is snap-on, then there shouldn't be any grooves, just small opening (lip) between the caseback and case. This is exact point where the watchmakers knife blade must be inserted and pryed up.
Posted on Jan 26, 2009
Need a new glass for men's seconds watch
I assume you mean a Sekonda watch.
Watches from large scale manufacturers like Sekonda come with a wide range of glass sizes. 30mm diameter is a common one, but you would need to remove the glass in one piece to measure it. Watch glasses are commonly in 0.5mm steps (e.g. 30.0mm, 30.5mm,31.00 mm etc.) and may have rounded or bevelled edges so it is often very difficult to determine the exact size without removing the glass.
Additionally, there is the thickness of the glass to consider.
Finally, the 'glass' may be plastic, mineral glass or sapphire crystal.
All in all, you will have to know how to remove the back of the watch, how to remove the crown and stem in order to remove the movement, how to remove the glass in one piece, how to fit a replacement glass, how to refit the movement, how to refit the crown and stem and how to refit the back.
Alternatively, take it to a watch repair centre - you'll still have a working watch after they've finished with it.....
Oct 18, 2017 | Watches
Battery on m Invict Pro Diver watch replaced , now the second hand stays swinging back and forth in the same place
Do the minute and hour hands keep proper time? I've seen your problem before when the hand has come loose from the center post that turns it. You probably need someone who knows what they are doing to pull the crystal and reseat the second hand. Do this when the watch is off!
Sep 08, 2014 | Invicta Pro Diver 9309 Watch for Men
I have a FOSSIL mens wristwatch model # AM3423. I recently had a watch repair person replace the battery. Battery type and charge confirmed. I received the watch used as a gift from a relative who was...
Quartz watches stop working most often for one of three reasons: (1) dead battery; (2) dirt in the gears blocking the train; and (3) a bad crystal. This is the order in which I typically troubleshoot watches.
If the watch isn't working after you change the battery, first check to see that the stem is fully pushed in. A watch movement can shift just enough inside the case that a stem sometimes looks pushed in, but isn't quite in far enough to re-engage the movement. Pull out and push in the stem a few times to see if that changes anything.
Next, assuming that the battery is indeed fine, look closely at the second hand. Is it moving at all, even a tiny bit? Hold the watch up to your ear. Is there any kind of "chunk" sound about once every second? If you can answer "yes" to either of these questions, a speck of dirt has gotten into the movement and is preventing the gears from moving freely. It doesn't take more than a a big spec of dust to cause this. Sometimes, advancing the time will move the gears enough to cause the dirt to fall out. Some watch repair places also have a special machine that spins the hands rapidly to blow out or compact any dirt in the train. It's usually not economically rational to have the movement professionally cleaned beyond this point.
Finally, if you don't hear anything coming from your watch, the battery is good, and the setting stem is pushed firmly and completely into the watch movement, you may have a bad quartz timing crystal. It does happen, and when it does, the only repair is to replace the entire watch movement. Sometimes, that's affordable; sometimes, it just doesn't make sense.
Sep 20, 2012 | Fossil AM3424 Wrist Watch
How to remove crystal from Pulsar watch PF3142 chronograph to refit small seconds hand
There is usually a way to remove the crown and stem together so that the movement can be removed from the casing.
Have a good look over the movement and see if there are any identifying marks and let me know what you find. Alternatively, post a photo of the movement.
Oct 07, 2017 | Pulsar PXF100 Wrist Watch
I have a diesel watch model dz-2136 I need to know how to remove stem
Thank you for contacting FixYa.
I dont know why you want to remove the stem but here you go.
To remove the stem you must first loosen the set lever screw, then you can pull the stem out.
You only need to turn the set lever screw a couple turns to release the stem. Some movements use a button instead and in that case you would simply push the button down lightly with a pointed tool and while holding the button down pull the stem out.
For watches with one-piece cases where the movement comes out the dial side and the case has no removable back, you will not be able to get at the set lever screw. For this type of watch you must grasp the crown firmly and pull it out, or use plastic or soft brass tweezers to get behind the crown and pop it off. These watches have two-piece stems that have male and female ends that snap together. Then remove the bezel and let the movement come out into your hands. Then remove the hands and the dial and put the movement face down into a movement holder. Now you can remove the stem as described above
Aug 26, 2010 | Diesel Audio Diesel Watch
How do I remove the crown/stem to take the watch movement out of the case? thanks Marc
Apr 04, 2010 | Watches
The crystal is cracked in my Relic mens wristwatch. Can I order a crystal on-line and replace it myself?
Problably not something you should tackle by yourself. I replace them and have experience. You would need to make measurements and order from a place that has inventory. Then you would need to remove case back and movement. Then you would push out the crystal from the inside. The new crystal needs to be installed with the proper "glue". This also needs to be ordered. I suggest you take it to a local watchmaker that knows how to do this. But, best of luck
Oct 02, 2009 | Relic Multifunction Watch
Need to remove winder on mens seiko titanium so i can remove the
Ensure crown is in neutral position i.e. pressed home (not in set hands posn.) Remove back and adjacent to the winding stem on the movement there should be a small button (may be indicated with an arrow) depress this gently whilst withdrawing the crown and stem from the watch. Ensure you don't engage to set hands position in the process. You might also find a couple of screws securing the movement into the case. P.S. Usually don't need to remove from case to replace battery.
Mar 30, 2009 | JCPenney Seiko Men's Titanium Watch
Mens Relic watch stopped working after battry change
I suggest that your watch has an oxidized contacts and electricity can not reach the movement.
Do as folloes:
Take out the batttery,
Clean (scrape) all battery related contacts till they are shiny (use hardened steel needle for that),
Use the dust blower to get rid off any tiny dust and dirt particles after cleaning,
Refit the battery back.
Now your watch should work again.
If all written above do not help, then there is a problem with your watch and you will need the help of the watchmaker.
Feb 09, 2009 | Relic 0504648FA
Watches Logo
180 people viewed this question
Top Relic Watches Experts
Ansel Alberto
Ansel Alberto
deton8 von Splosion
Are you a Relic Watch Expert? Answer questions, earn points and help others
