Question about Sony HMD A220 17" CRT Monitor
Toshiba CF3566A I have a problem with above referenced set. It was dead except for a faint "ticking". I found a post in this forum by "pasty" who advises the following: "Common for the horizontal output to short in these models is a 2sc3892A which usually shorts because of a 10 uf 160V filter capicitor on the primary of the H drive transformer deteriorates & distorts the waveforms causing H out transistor to overheat & short" I have located the Horizontal output transistor which is located at Q404. I replaced it. The TV now powers up (no Ticking noise) but shuts down after 10 to 15 minutes. I can NOT locate the above referenced 10 uf 160V filter capicitor. I have found one such cap on the power supply board and is identified as circut # C416. I dont think it is that one. I dont know where "the primary of H drive" is that the solution post refers to. Can someone please identify it for me by telling me on which board and what circut number it is? I am almost home free on this...I welcome any assistance. Thank you, The Bandit
  • Robert Iacobello May 22, 2007
    Sorry, but I was unable to follow your instructions because I did NOT understand them.
    But thanks anyway.
  • 45 Answers
Follow the diagram, the base of the hor out should go to the secondary of the hor drive transformer, and going to the primary circuitry you should find a transistor, a small transistor, look for its collector and you should find a filter capacitor, may not be the same value but it is the filter capacitor.
Posted on May 20, 2007
How to turn on web cam
Troubleshooting listed on the Toshiba website:
The TOSHIBA Web Camera Application provides you with convenient operations and easy access to:
  • Preview the video that the Web camera is currently capturing, at the same time
  • Support 2D mode, Shutter Glasses 3D mode and Red-Cyan Glasses 3D mode
  • Capture still images
  • Record videos
If this utility or feature is not installed on your computer, you can verify if it is available for your specific model under "Downloads" on the TOSHIBA support web site (support.toshiba.com). Not all utilities are available for every model and operating system. When installing any utilities, install the TOSHIBA Value Added Package first.
To open the Web Cam:
  1. Click the Start menu. On Windows 8, go to the Start screen.
  2. Enter "Camera" into the search field. On Windows 8, type "Camera" while viewing the Start screen.
  3. Click "Web Camera Application" in the search results.
  4. The Web Cam will open and live video from the camera will be displayed.
  5. When you place your cursor over the web cam video window a row of icons appear at the bottom.
Link to the Toshiba webpage referenced from above:
http://forums.toshiba.com/t5/General-Features-Knowledge-Base/TOSHIBA-Web-Camera-Utility/ta-p/346954
Nov 21, 2013 | Toshiba Satellite Computers & Internet
Pasty liquid in the coolant tank and radiator
Coolant leaking into engine?? Transmission fluid leak into coolant?
Nov 14, 2017 | 2004 Hummer H2
No post to bios on new pc build
FIRST....... Make sure you remove the stock thermal compund (pasty/sticky stuff) from the bottom of the heat sink as well as from the top of the cpu.........
Second APPLY some ARCTIC SILVER 5 compound-ust a thin coat of it over the top of the cpu......use an old credit card.....keep it ff the sides and bottom though......it's important not to use too much........one little tube will do anywhere from 3 to 5 CPUs...!!!
(stock thermal paste/thermal compunds......**** BADLY and can cause a cpu to burn up)
reseat (properly) the cpu and carefull
Now make sure you're 24 pin or 20+4Pin Power connectors are connected, as well as your fans..........disconnect all your SATA Devices, and remove everything but the video card , CPU, and fans.......Now it should post (if all your jumpers are set correctly...........
IF it still doesn't post, remove the video card and reboot.
If it doesn't beep at all......... You have one of 2 things.........A DEAD CPU, or a DEAD MOBO
Mar 19, 2009 | MSI P4M900M-L Motherboard
Toshiba + Azurewave wirless set up
i have a wieless router how do i instal have no book
Oct 09, 2007 | Computers & Internet
Toshiba CF3566A Tac 9190
the cuestion is if every time it shut down you have the hot shorted,or not. have measure the flyback/yoke/Hot working current? it must be under 0.6Amp ,if is greater something is wrong and cause overheating.Normally I touch with my fingers to "measure" the temperature. and what about the Micro?.there´s one pin that control power on/off ,is it good-solid data or is crazy . micro gets hot, have a correct 5Volt on its VDD pin. lot of cuestion that I hope helps you!!!
Jul 08, 2007 | Sony HMD A220 17" CRT Monitor
Open Questions:
See all Sony HMD A220 17" CRT Monitor Questions
Sony HMD A220 17" CRT Monitor Logo
259 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
