Question about Epson PowerLite Home Cinema 710HD Projector V11H475020
Epson powerlite home cinema 710HD powers on but no blue screen
Just opened the box and set it up. played ps3 game and it was fine. powered off via remote. hour+ later powered on via remote and nothing is working-no bright image just a weak dull image w/no blue screen, no response from any buttons remote or on machine, fan works, a/v is open, all cables connected well/properly. Why won't it work?
  • steven barwise Nov 04, 2012
    its brand new too, today
SOURCE: Lamp is on but not no signal from projector coming out !!!
i figured it out. open it up, and make sure the ribbon cables are securely plugged in.
Posted on Apr 03, 2008
chilibball
  • 85 Answers
SOURCE: blue dots in the middle of the screen
The image processor must be getting old and worn out. Call Epson or go onto their website and see if it is  a dDIY project or if you will ned to send it in.
Posted on Apr 27, 2008
Basti
  • 1447 Answers
SOURCE: Epson TW10 Projector displaying "error in epson cinema filter"msg
Hi
What is the error message? Are there lights flashing on the panel? Keep us posted. thanks!
Posted on Nov 29, 2008
zabolyx
  • 38 Answers
SOURCE: images has a blue color across the center
Wow, 3 in a row. As described on 2 other projector issues this is very similar to those others. I'll repeat the info here.
I assume this is an LCD. I don't remember the s4 being a DLP projector.
This sounds like the LCD panel used for the blue color has gone out. The image is made up of red, green and blue images layered upon the screen. If the blue panel has gone out then there is nothing filtering out the red light in the image.
It looks like yours has just a secone of the panel dying or comming loose from it's connector.
It could be a simple open and reconnect fix. I personally have never opened a projector, so I'm not going to walk you through it as I do not know how hard it would be to tinker with. It should eb a cheap fix for a true repair man though.
Posted on Apr 01, 2009
EduTech
  • 54 Answers
SOURCE: Epson powerlite 83+. It comes on, then the 'heat' light flashes
Go to http://files.support.epson.com/pdf/pl83pl/pl83pl00ug.pdf#page=80&view=FitV&pagemode=none page 80, "What to do when the lights flash" . If that doesn't do it or it's not clear, please get back to me.
Posted on Jun 26, 2009
One Blue line is on the screen
open up the projector and you will see a small screen attached to the lamp and a Flex Cable attached to the screen,
Remove the cable and Clean it with Alcohol Liquid from both sides then put it back and check.
Aug 02, 2015 | Epson PowerLite Home Cinema 3020 LCD...
Why is my epson powerlite 3020 beeping?
This usually comes from using an aftermarket bulb. Not sure if Epson intentionally engineered this annoyance or if it's from something inherent in the cheaper bulbs.
Sep 07, 2014 | Epson PowerLite Home Cinema 3020 LCD...
Epson powerlite home cinema 8100 picture quality problem?
It can be a bad lamp. Under menu setting, select Dynamic or presentation. Those are my favorite picture settings.
Aug 30, 2014 | Epson Powerlite Home Cinema 8100 Home...
Epson powerlite home cinema 8100 problem with picture
Dark pictures after a lamp change normally indicate that the lamp isn't aligned properly, or that it has been touched with bare fingers and caused a black mark, or it's an inferior (budget) lamp.
Aug 30, 2014 | Office Equipment & Supplies
Epson projector is stuck in start up mode
1, the lamp is ok
2,the lamp ballast is ok
3,seems that the power supply or mother board is defective
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color
wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry Lampdeng Limited
Mobile: 0086-13178867858
Wechat ID: 008613178867858
Whatapp ID: 008613178867858
Skype: lampdeng@hotmail.com
http://www.lampdeng.com
Dec 24, 2012 | Epson ELPLP69 - V13H010L69 Projector...
The temperature sensor light is flashing on PowerLite Home Cinema 1080. How do I reset the temperature sensor without sending it to be reparied by an authorized Epson company.
Fist thing you need to do is check all the filters.
Take them out and use a vacuum cleaner on a gentle **** to clean out the dust.
Use the brush attachment also go around the projector and de dust all the grills.
Please dont forget to vote if you liked my answer
thanks
Feb 11, 2011 | Epson PowerLite Home Cinema 1080 Projector
Well my epson projector fell and now the screen doesn't play it just shows the white screen but the audio works perfectly fine.
~ power on the unit and disconnect all sources (dvd,computer,etc) * if it shows "No Signal" and Blue screen, the unit is ok~ try using another cables
Jun 17, 2010 | Epson PowerLite® S4 LCD Projector
Epson PowerLite Home Cinema 710HD Projector V11H475020 Logo
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
