Question about Whirlpool Washing Machines
Whirlpoool front end loader washing machine showing an f 06 error
Cleared the error 06 yesterday, today washed 3 loads and worked fine. on the 4th load it got to rinse cycle and started flashing. Cleared error again and selected a new cylce. Got to rinse and started flashing again. it then jumped to spin and added water but would not spin. finally F06 error again. Need help!!
    Top Expert:
  • Whirlpool Master
  • 9,472 Answers
The F/06 is:
Drive Motor Tachometer Error
The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin, the door will be unlocked after 3 minutes.
The tech. should check these:
Check wire harness connections between the Drive Motor/Tachometer and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU)
Check the Drive Motor
Check the MCU
Check the Wire Harness
Posted on Nov 04, 2012
SOURCE: GE Front Loading Washing Machine seems to be holding water....
manual
Posted on Mar 21, 2008
SOURCE: hoover 600mb 6.0 kg top load washing machine (not as below)
Machine unbalanced or belt is worn maybe
Posted on Apr 04, 2008
SOURCE: aeg 76669 oko lavamat machine not
I have had the same problem. If you switch the machine to off and then to cotton/linen 95, then press at the same time prewash, soaking, qick wash and stain buttons for 10 seconds switch it off. When I switched it on it worked.
Posted on Jun 24, 2008
barkencoa
  • 3463 Answers
SOURCE: Ariston Front Loading Washing Machine error code F07
Error code F07 is indicating that the heater relay is stuck for one reason or another.
This could be a board problem, as this where the relay is located.
However, it would be worth checking that the heater is o/k before you do anything else., as this possibly could cause the relay to malfunction.
Plz rate my solution.
Thanks.
Posted on Jan 13, 2009
blueextc3221
  • 15935 Answers
SOURCE: Washing machine displays an LF error code.
LF = Long Fill
LF flashes when the water level does not change for a period of time after the valves are turned on OR water has disengaged the basket but control does not detect a water level change.
Is water supply connected and turned on?
Are hose screens plugged?
Is water entering the tub? If so check pressure hose connection to machine/motor control.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 07, 2010
Testimonial: "We followed your suggestion and disconnected the hoses and they had "gunk" in them. We flushed them out, reconnected and everything seems to be fine."
Top load machine, been fine til today, will not move thru cycle, keeps turning itself of with 'de' notice, also has leaked some from inside machine
Troubleshooting LG Top-Loading Washing MachineDoor Error. The washing machine gives a flashing beeping DE error that the door (top loader) is still open while this is not the case. The small magnet has broken/fallen off. Attach a new magnet to the door (top loader) that will trigger that the door is now closed. Why dE Error is displayed on the panel of the Washing Machine
Why 'dE' Error is displayed on the panel of the Washing Machine? Last Update date : 2017.01.19
You may encounter a situation when your washing machine displays 'dE' error. This error appears when the door is not porperly locked.
If the Machine is displaying "dE" error, kindly check for the following :
? First and foremost the door must be properly closed.
? You can check the end of the drain hose is too low (Make sure the holder of drain hose in the back is intact).
? Also, you can check the end of the drain hose is submerged in water.
Jan 02, 2018 | Washing Machines
I have an Aqualtis 9l29i washing machine. It is working fine but the wash cycles are all ridiculously long.Put it on the quick wash yesterday,three hours later still washing!! Suggestions please?
1. Front load machines always have much longer cycles.
2. The machine you have has a time saver mode on most cycles.
3. Check with your local Ariston reps on the time various wash cycles should take with your model if this is not specified in the user manual, which it normally would be.
4. These are notoriously bad over priced machines which will give you trouble early in ownership and are expensive to fix. For half the price you can buy a good top loader that will give you at least twice the trouble free years of use and not run ridiculous wash cycle times.
Jan 03, 2016 | Washing Machines
Ac voltage become hihg or low when start ifb washing machine
We got a IFB front loading washing machine last week only after 3 time wash 4 th day it is showing AC-LOW message . the service people came and went but nothing is done what is the next solution?
Same point top loading Godrej 6.5 kgs working fine but water consumption is more in that compared to front loading machine so pls sugeest good solution at the earliest.
Sep 30, 2012 | IFB Washing Machines
He2 plus front load washer keeps showing F21 error code. I cleared the drain pump filter. Still displaying F21 how do i check to see if i need a new pump
If you found a blockage in the pump screen restricting the drainage and it now drains fine but F21 is still there,the error code can be cleared by pushing the PAUSE/CANCEL 2 times within 2 seconds.
If after clearing the error code if it returns on the next wash cycle the pump will need to be replaced.
I hope this has helped you resolve your washer troubles,
Gene
Aug 05, 2011 | Kenmore HE2 Plus Front Load Washer
2008 Samsung front end loader develops a 4E error
When error message 4E is displayed, you should clean the water hose mesh filter. To do this:
1. Turn off the water source to the washing machine.
2. Unscrew the hose from the back of the washing machine.
3. With a pair of pliers, gently pull out the mesh filter from the end of the hose and rinse it under water until clean. Also clean the inside and outside of the threaded connector.
4. Push the filter back into place.
5. Screw the hose back onto the washing machine.
6. Turn on the faucet and make sure the connections are watertight.
Also, please check the following:
• Make sure the source water faucet is turned on.
• Check the water pressure.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!!
Jul 12, 2010 | Samsung WF337AA Front Load Washer
Washing machine stops and flashes 4E
1. WATER SUPPLY ERROR – Display shows 4E.
Water Supply Error occurs when water level frequency does not show changes more than 100Hz or water is not supplied up to the preset water level after 10 Minutes or more at the time of initial water supply. The error status can be cleared by turning the POWER switch OFF and back ON.
Feb 23, 2010 | Washing Machines
Whirlpool front loader not working - Control Lock Light On
Press the End of Cycle Signal for 3 seconds until the Control Locked light turns off.
Apr 05, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Error message LE5E and would only oparate prewash
it's not on 'test' is it,
try turning the machine on while pressing the start and on buttons together until dOFF apears.
Jan 17, 2009 | Hotpoint Aquarius WD640 Front Load...
Washing Machines Logo
174 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
