Question about Fisher and Paykel Washing Machines
Fisher and paykel washer fills in short bursts then stops and spin ld light lights up and beeps
GW709AU model
  • nova Nov 04, 2012
    hI THERE, when both hold and spin ld lights are on in diagostic mode there are no lcd lights on in the wash cycle however, when the hold only light is on ther is the 3rd light in wash cycle in green the 6thy and 7th lights are orange and the 8th light (spin) is intermittantly showing red light?
    Top Expert:
  • Fisher and P... Master
  • 9,472 Answers
Posted on Nov 04, 2012
SOURCE: GLW10US won't do anything but beep
We love our new Bosch but... THE BEEPING IS TERRIBLE!!! I put a load in to wash when we go to bed. The beeping wakes us up. It is BAD!!
Posted on Jun 17, 2008
  • 713 Answers
SOURCE: We have a Fisher and Paykel toploader, smart drive
Hi just read you posting.Could you please confirm the fault code for me.1st push and hold the WASH TEMPERATURE DOWN button then press the POWER button until the machine gives you 2 short beeps,then release both buttons.Now press the SPIN UP or DOWN button until the HOLD and SLOW SPIN LEDs are both on.Now the fault code will appear in the WASH PROGRESS lights.Please reply to confirm which lights are lit.Are they the same as your 1st posting?To get back to normal operation turn machine off at the power point.Looking forward to your reply.
Posted on Jul 05, 2010
  • 713 Answers
SOURCE: washing machine stopped during spin cycle
Hi just read your posting.Now on the wash progress line of lights ,there will be 8 in this row.Starting from the left to the right which lights are lit.Is it the 2nd ,3rd and 7th or the 1st, 4th and 8th ---etc---?Please reply with additional information and I can help you rectify this fault on your machine.Looking forward to your reply
Posted on Jul 27, 2010
Jahn27
  • 1554 Answers
SOURCE: My Fisher and Paykel GW709AU
It sounds like there's a problem in the water inlet system. The machine repeats the process several times because of the Restart Feature which retries starting the machine to correct the problem. The machine completely stops and sounds the alarm because the Restart Feature failed to correct the problem. The fault code is indicated as a series of flashing Wash Progress LEDs.
Indicate explicitly which among the Wash Progress LEDs are lit or flashing to determine what and where the problem really is for further troubleshooting. You don't have to accept or reject and rate this post to add information, comments, and follow-up questions. But accepting the solution will not terminate your communication with the expert. You may continue communicating with the expert as long as you need assistance regarding the issue stated herein.
Posted on Oct 24, 2010
SOURCE: my fisher paykel washer GW709au
Firstly,I am not a service technician,I am a mechanical fitter, I do however try to find solutions to problems before calling the pro's.Sometimes,and in this case it works.
3,5,7,8 code lights indicate an "out of balance fault" Fault 43 according to F&P, It is not a hard job to fix, you will need a new/second hand micro-switch and possibly 2 female spade electrical connectors,a pair of crimping pliers, a star/philips head screwdriver,and a flat blade screwdriver.
Firstly you need to electrically isolate the machine, ie. pull the plug from the power outlet. Then remove the 2 screws at the back of the control pannel,lift from the back and it unclips at the front, lay it on its face. We need to get access to the out of balance switch which it to the right of and under the electrionic control box.Remove the single screw holding the electonics box(black box) and move wires so as to allow the box to be lifted up just enough out of the way to access the switch. Use a flat blade srewdriver or strong fingers to unclip and remove the microswitch, replace the switch but inspect the spade terminals for corrosion, replace if corroded. There is a waterproof upgrade for this problem from your dealer. Or you can do what I did and get some spare switches from other electronic devises, they are quite common. The part number for the switches I am using is 120727C.Mine came from the door switch of a microwave oven, but before pulling apart your microwave read up on them as they have a different set of safety rules. Good Luck with it.
Posted on Dec 29, 2010
Smart drive 051 error code 32
Have you tried unplugging it and plugging it in again?
Nov 22, 2013 | Fisher and Paykel Washing Machines
Model Gw709AU
When you start your machine is the water just go stop go stop,
Just wait for the machine to display an error code on the wash progress lights and beeps constantly.
It could be the Rotor Position Sensor, out of balance switch or lid magnetic reed switch.
Your error code will determine this.
Is your machine beeping & showing a weird pattern of lights on the wash cycle, It is displaying an error code,
To read this error code you start at the red spin light & work to the left only add up the lights that are on. Red spin light = 1 2nd rinse light =2 1st rinse light =4 last wash light=8 4th wash light=16 3rd wash light=32 2nd wash light=64 1st wash light=128
j8paojvh5jrgaaaaabjru5erkjggg==
Feb 20, 2013 | Fisher and Paykel Washing Machines
MW511. 2 & 7 lights flash, beeping. No agitate or spin?
Fault code 66 is pressure sensor is faulty
66. (01000001) Pressure Transducer Error [Ptx Frequency > 90 kHz]
Note: this supersedes Fault code 65 from V41 Motor controller code onwards.
The Motor Control module has received signals from the water level sensor (Ptx)
above normal frequency values.
Primary Source: Motor Control module
Action: Replace Motor Control module
Apr 20, 2012 | Fisher and Paykel Washing Machines
We have a Fisher and Paykel toploader, smart drive 603. After setting up a washing cycle and pushing the start button, the machine starts for a few seconds with the water filling in in short bursts (rather...
Jul 05, 2010 | Fisher and Paykel GWL11 Top Load Washer
Starts and stops
A failed inlet valve is not uncommon in F&P machines. The hot valve is different to the cold one, so don't exchange them. Not a big job for a tech to do in-laundry. Good luck....Nomess
Jun 11, 2010 | Fisher and Paykel Fisher & Paykel Washer
F & P Smartdrive 708 has all lights showing when powering on, but will not start wash cycle. Have tried turning off at wall to re-set; taken lid off but still no go
take the motor shroud with the magnets in it off you will probably find corrosion on the terminals on the small circuit board clean it off, whilst you are at it check your pump is spinning freely if not pull it off and dismantle it clean the rotor it may have a rust buildup on it, when putting it back together give the bearing holder a few taps to centre the shaft before you tighten the screws completely, if it tightens up when you tighten the screws give it another couple of taps either side of the bearings until it frees up
Oct 30, 2009 | Fisher and Paykel Fisher & Paykel Washer
F&P Smartdrive 058 filling in short bursts then stopping.
I had the same problem today. shephonos 18 had the correct diagnosis. Out of balance micro switch seized. Situated under the main circuit board. Cherry electric Corp 0.1amp 125 volt sptd type switch. jaycar has them for under $4.
I un-seized it with some electrical cleaning spray, fixed itshort term, no worries.
Thanks Stephanos 18.
May 04, 2009 | Fisher and Paykel Fisher & Paykel Washer
well i don't have any experience with this brand but i would say you need to change the fill switch it senses how much water is in the tub shuts the water off then starts the washer its also called the pressure switch
Feb 16, 2008 | Washing Machines
Washing Machines Logo
305 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
marley mcelhinney
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
