Hi!!!!! I hav installed UNIX os in 1 drive..... Now the other three drives showing some problem .... So with out any harm of data to unix drive.....i can re-installation for the other three or not
  • 3 more comments
  • m_ranjan24 Jan 04, 2009
    I have a OS of Windows XP Professonal for three drives(C,D,F) and m having a Linux OS(E) ........
    But now from XP OS i m getting some problem ....so wat should i do for it but the Linux OS is nt giving any problem......
    Suggest me As Soon As
    Thanking You.
  • m_ranjan24 Jan 05, 2009
    The thing is that ....
    whn i click on the E drive (it showing put a driv to it )......it has no problem.......
    but whenever I go any (click) task on winXp it showing virus detection mesage.......
    Ther r some option on the virus detection window that
    1>move to quant...
    2.>delete
    3.>rename
    4.>deny access
    5.>ignor
    Whn i press the move to q.....that virus messege again comes....
    After that I tried for alll option but the coming of virus message is repeated.....
    After that I hav deleted the file froom wher I m getting the virus messege....
    After that a new file is created......(.VIR)file ..........whn I click on that it showing the virus detection messege.........
    1>move to quant...
    2.>delete
    3.>rename
    4.>deny access
    5.>ignor
  • m_ranjan24 Jan 06, 2009
    now i m installed AVIRA.............
    pls replyyy
  • Deboo Geek May 11, 2010
    What kind of UNIX is this and what is the problem shown with the other 3 drives? What kind of drives are these? IDE or SATA or SCSI?
    What do you want to re-install on the other three drives? Windows or UNIX?
    Please try to detail what you want and what the problem is that you want solved. It will help you get better help from everyone. :-)
    Regards,
    Deboo
    Scholar:
  • 77 Answers
It would be helpful if you can detail what this "problem" that you say your Win XP is showing, really is. Is it an error message when you click Drive E in MY computer? What is the error? Or what is the problem?
You can re-install windows if you _really_ need to. The only thing it might do is overwrite grub boot menu, which you can reinstall with knoppix (as kingsolmn suggested) or with the bootable Linux CD which you used to install Linux.
But be careful to backup your data - your C:\Documents and Settings\Username  to another drive before reinstalling.
Posted on Jan 04, 2009
  • Deboo Geek Jan 05, 2009
    This virus problem and the Linux installation and re-installation of Windows are totally two different things. And Linux installation is _not_ causing the virus problem.
    I suggest you first download the Malware bytes anti malware:
    http://www.malwarebytes.org/mbam.php
    Install it and scan and remove any malware that you seem to have.
    Which antivirus are you using?
    Problem Solver:
  • 13 Answers
I would suggest using a "Live" Unix system disk to fix the file system problem. Sometimes file system locking by the host operating system will cause problems accessing secondary HDDs. Try the free Knoppix system (www.knopper.net), this system works from a CD so that you have complete access to all of your drives. Use this to move/copy/save data so that the drives with problems can be formatted/reallocated.
The logic card of my TallyGenicom 6312L line printer has been repaired. it is not working on Unix OS but working in Windows envirinment. what is the solution?
The solution depends very much on the cause of the problem. I note that you can print from Windows, this indicates the intrface you are using is functioning correctly and it should therefor be possible to print from Unix to the same interface if it is connected to the Unix system. If the printer is connected via a network interface, check the IP address on the printer to ensure it matches the IP address set up for the Unix print queue. Try pinging the printer from Unix. Ensure the EMULATION setting on the printer matches the Device Type selected on Unix. You may need to identify if any data is being sent for Unix perhaps try sending a test text file to the printer. A common cause for printers not printing from Unix is no Carriage Returns or Line Feed commands in the data. Try setting Auto CR to ON in the printer, of this does not work try setting Auto LF to on. If there is still a problem please post the connection method and also any errors or symptoms seen when printing from Unix
Sep 27, 2011 | TallyGenicom 6312 Matrix Printer
When i turn on PC i get "windows error recovery" windows failed to start. A recent hardware or software change might be the cause. To fix the problem: 1. Insert your windows installation disk and restart...
You need a Windows OS install or upgrade disc appropriate for the one on your computer (including the service packs you have installed). The Acer disc will only restore to the original configuration. You will need to try to get an OS disc from Microsoft (difficult if your computer is out of warranty) or from someone who has one. Try locating a Windows User's Group (many of the members have multiple OS discs and will lend them out) in your area or a local repair person. Then you can use the Recovery Console.
Alternatively, get a Unix CD and an external hard drive or optical disc writer. Boot from the Unix CD (usually you can press F12 to access the choose boot location). Then plug in the USB hard drive or optical disc drive. Mount this disc and copy your important data from the non-bootable disc to the external media. Then run the Acer disc and download all the updates before trying to reinstall software and return the files to your machine from the .
In Win7, everyone can create this from Start > All Programs > Maintenance > Create a System Repair Disc. (So then you get one burned from any Win7 computer as long as you match Home Premium, Professional, Ultimate.)
I hope this helps.
(please note that if your restore disc provides an OS earlier than XP SP3, Windows Update will not work. You will have to manually find the updates on microsoft.com)
Aug 18, 2010 | Acer Aspire™ T180 PC Desktop
How to install unix sco kindly give full details
start the computer with the Unix disk in the drive.
Choose the option to run unix without installing to the pc.....(this runs without a HDD>Itll take some time but let it install all the way, and as system is fully running..Choose "install unix " from the drop down menu.
After installation, eject the cd and set up to boot from the HDD.
Jan 27, 2010 | Apple OSX 10.3 for Unix, Mac
What are the differences between windows vista and unix
Hmmm... This is a BIG question, and it has a HUGE answer.
Have you ever seen Unix and Vista? I think you would immediately see the difference between the two.
1. Vista has a Graphic User interface, Unix is a command line interface.
2. Totally different systems (Filesystem, application, Kernel... whatever)
3. Age - Unix is ooold, and Vista is new (Unix dates back from the 1980's)
Well i can go on like this for days ...Google it more.
Darko, Serbia
Mar 19, 2009 | Microsoft Computers & Internet
Unix
Improving UNIX server performance NOTES.INI settings Most NOTES.INI settings that affect IBM® Lotus® Domino® server performance apply to all UNIX® platforms.
NSF_Buffer_Pool_Size_MB Many machines that run UNIX have very large amounts of physical RAM. Use the parameters NSF_Buffer_Pool_Size_MB or PercentSysAvailable Resources to control how much memory Domino is allowed to use. Each Domino instance on a UNIX machine can reference a maximum of 4GB of RAM.
Disk and memory requirements When a UNIX system runs Domino server software, the server must have enough disk space for program and data files and enough memory to handle swapping and the number of processes. You can also change several system parameters to improve server performance.
Disk I/O tuning Maintaining multiple file systems for operating system files, swap space, transaction logs, and data improves overall server performance.
Use RAID 0+1 hardware for the disk drives on which the data files reside. Use multiple smaller disk drives instead of a few large disk drives for Domino data. Domino does not perform simple predictable sequential reads; therefore, disable Read Ahead Cache and enable Write Cache.
Keeping swap space on its own separate striped volumes improves server performance at high loads. The transaction logs should always be on the most reliable and highest performing disk subsystem available to the system hosting the Domino server. Transaction logging must be on its own disk drives for improved server restart time, reliability, and availability. The logged transactions are written to disk as fast serial writes to a sequential file that is of configurable size in 4K blocks.
Console and database logging To improve server performance, limit the amount of information that is logged to the log file (LOG.NSF) and the console.
Feb 21, 2009 | Computers & Internet
I want to download unix os for free how can i do this
Please click on the below link and select version of unix you want to download like Solaris, Fedora etc... Click on that link and select the free option. You need to login once before downloading..
http://www.tech-faq.com/download-unix.shtml
Thank you...
Feb 02, 2009 | Microsoft Windows Vista Ultimate Edition
What is the difference between unix and linux
UNIX is a operating system which has only command user interface, and if the unix is installed in the system you cant install any other operating system after that ... one separate system must be allocated for the unix ...
LINUX is the graphical user interface and it supports multiple operating system ..
UNIX and LINUX are almost same, almost all commands which supports in UNIX supports in LINUX too .. with some extended features just like GUI(GRAPHICAL USER INTERFACE),SECURITY,MULTI USER,MULTI TASKING,etc
COMMAND USER INTERFACE - the input is made to the computer by using commands and the output is obtained by command or by printer ...
GRAPHICAL USER INTERFACE- the input is provided to the computer through the other input devices like mouse,joystick etc
the input is provided either by command or by the just clicking the mouse on the particular icon ...
example for graphical user interface is windows,Macintosh etc ...
thank you
bye
any doubts you can reply me
i am always here to assist you
please rate my solution
Aug 19, 2008 | Microsoft Windows Server Standard 2003 for...
Acer 5050
Do you have or did you make the recovery installation optical media [dvd or cds]. If you have the option to make the recovery media - you should do it now - as you may need to reformat the hard drive.
Mar 16, 2008 | Acer Aspire 5500 5570-2609 Laptop
Acer 5050
by default acer 5050 have 3 partitions
1. OS partition (C)
2. Data (D)
3. Recovery partition (hidden).
If you deleted recovery parition, you can't recover your C parition using Alt+F10. Your only option is recovery from cd/DVD recovery that you created. if you didn't create the cd/dvd, you can call acer support to buy the recovery dvd.
Mar 16, 2008 | Acer Aspire 5050 Notebook
Installation of printer in HP UX 9.5
wat is your Operating System u used?
Mar 03, 2008 | Office Equipment & Supplies
Computers & Internet Logo
54 people viewed this question
David Payne
David Payne
