Question about Tascam DM-24 DIGITAL MIXING CONSOLE
Tascam dm-24 digital mixer logic pro 9 issue
Hello, an associate of mine recently purchased the dm-24 digital console. as i am going to be the engineer i need to get it working, and try as i may i cannot find any online drivers or templates to have it act as a control surface and audio interface simultaneously in logic pro version 9. i tried to configure it manually, but as i am new to the device and have never attempted anything as complex as this in logic (or any software for that matter). Is there anybody.. OUT TTHERE.
5 Suggested Answers
otacon
  • 1944 Answers
SOURCE: tascam 1804 mac book pro
Could you please tell me what error message you are receiving?
Posted on Feb 07, 2008
marsrover
  • 682 Answers
SOURCE: I HAVE A TASCAM DIGITAL
http://www.manualnguide.com/download/manual-guide/tascam-dm-24-digital-mixer-automation-manual.html
setup information in manual above-i think cable will be found in a music equipment store near you.
Posted on Jul 18, 2008
SOURCE: Tascam DM-24 Digital Mixer Problem
This mixer is plagued by bad caps in the powersupply. Open the desk. Find the powersupply and change the caps... (big black round capacitors. If the silver heads are a bit round they are failing. They should be dead on flat.
Posted on Jul 31, 2009
  • 6 Answers
SOURCE: Tascam DM-24 mixer is running crazy! Please help!!!
it needs a power supply.
Posted on Aug 16, 2009
How do I hook up my tascam fw1082 to a mixing board?
Hi, There are two ways you can connect it up. You have a TRS (Tip Ring Sleeve) monitor output that could be patched into the inputs of any analog mixer, balanced high level inputs.
You also have a S/PDIF stereo out. If a digital mixer doesn't accept S/PDIF you can get a converter to change S/PDIF to an AES, which any pro digital mixer will work with. I think HOSA has one for about $60.00, you might find something on Ebay as well.
Here is a Link to the TASCAM Spec page for you FW-1082
http://tascam.com/product/fw-1082/specifications/
I hope this helps,
Best Regards,
Mark
Jan 26, 2011 | Tascam Audio Players & Recorders
Tascam 2488MK11 hard drive problem
Hi I had exactly the same problem with my Macintosh, it worked fine until recently but suddenly stopped working. As a matter of fact it is probably due to a compatibility issue of the USB driver after a recent software update of MacOSX drivers. Fortunately I have an old Macbook pro with an old version of MacOSX and the Tascam showed up immediatly and USB worked fine. Therefore, if ou can downgrade your USB driver it might solve the problem.
Jun 27, 2009 | Tascam 2488mkii 24 Track Recording...
I HAVE A TASCAM DIGITAL MIXER TYPE DM-4800. I NEED IT TO CONTROL MY TASCAM HARD DISC RECORDER TYPE X-48. I NEED CABLE CONNECTION AND SETUP INFORMATION
Jul 18, 2008 | Tascam Audio Players & Recorders
I purchased a used Tascam DM-24 mixer about 2 years ago, and it 's been running great. Just about 2 months, it frequently shut itself off with a message:
" Power Supply voltage (+5V) is too low for stable operation. Please restart DM-24".
Of course, many attempts of restarting the board, but it won't turn back on after several hours later, and only lasts about half a day work only. Very frustrating. Any idea I could get help or fixed? million thanks for suggestions. Brian
Dec 31, 2007 | Tascam Quantegy 120 Minute Digital Audio...
Problem with tascam dm 24
Firstly well done for buying an excellent quality mixer. I take it you are referring to a software sequencer (if not why not) to take advantage of the DM24's firewire streaming and eliminate the need for a separate audio interface.
A choice of sequencer really depends on your application as they all have varying strengths and weaknesses, however one thing they all have in common is that the DM24 can be used as a control surface for all the major sequencers.
Cubase - easy to learn and user friendly, however the selection of virtual midi instruments and effect plugins is pretty limited and not great quality. Also it can be a bit unstable if you are using arrangements with lots of recorded audio parts. Its more at home with MIDI applications where you either have your own outboard synths or you have purchased a good set of softsynths.
Logic (Mac only) - Not quite as intuitive to use, however the selection of virtual instruments and FX bundled with the package are excellent quality. Also is a lot more stable for audio applications since it has been programmed to make more economical use of your system resources. This is a good choice if you are multitracking bands and have a lot of audio parts to deal with.
Sonar - this is basically the PC equivalent of Logic though there are a few differences.
Pro Tools- the biggie, and also the most expensive! This is a good all rounder, not had a huge amount of experience with it myself but pretty much every pro studio in the world uses tools and the built in plug ins are second to none.
Note all these have LE (learning edition) versions as well as the full versions, where the LE's are slightly stripped down versions of the full. Look at what your requirements are and make a decision based on whether you are likely to use the advanced functions of the full versions.
Finally if you have the budget, have a look at Reason. This is a virtual synth rack and can be used either stand alone or plugged into your main sequencer. Loads of excellent drums sounds, one great synth, one OK synth, the rex player which is excellent, and a good sampler. If you can justify the cost its well worth having.
Nov 30, 2007 | Tascam Quantegy 120 Minute Digital Audio...
Tascam DM-24 DIGITAL MIXING CONSOLE Logo
133 people viewed this question
Top Tascam Audio Players & Recorders Experts
Sam Palermo
Sam Palermo
John
John
Michial Gueffroy
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
