Question about Lexmark X1240 All-In-One InkJet Printer
Hideous Color My color prints come out w/ way too much green. The prints were brillant up until a couple of months or so ago. I've tried cleaning the terminals on the printer and the cartridge but no luck. This is w/ both web printing and document printing. This printer is less than two years old!!!
  • Glenn Rogers
    Glenn Rogers May 11, 2010
    I 'can' help you to get this resolved. Unfortunately there is no quick trick to solve your problem. We will have to do a complex troubleshooting routine on your printer using email alerts to content written by both of us via this trouble ticket page you are now looking at.
    This could take some time to accomplish. I took a quick look over at Lexmark on your printer model and your printer model may not be Vista ready.
    So, please let me know what Operating System you have, XP or Vista or something older like W2K. OK?
    If you have received an error number provide that or if in the steps below you do receive an error number let me know what that is.
    To start with, I'd suggest you begin with the below from the Tools, Maintenance options at the printer.
    Clean the heads and do a print alignment. Use the lexmark Control Center, by accessing the Tool Icon (looks like a wrench) and then access the Maintenance menu and run maintenance on your color cartridges.
    Once that is done, check the printer properties by going to the Start Menu, Control Panel, Printers and Faxes or a similar title in Vista. Here is where you can set the system wide printer properties such as the default Paper Type. An incorrect paper type in a print job can
    cause this problem you have. So, make certain the paper type matches your paper in the tray. Avoid using the Print Icon in your applications and drop the file menu down and then select Print, this gives you a chance to then click on the Printer Properties button where you can change the paper type for the paper you are using for the type of image you are printing; text with color, text with photo, photo, enhanced photo and so on.
    Give that a go and report back using the comment box below your results and findings. Then we can take this up from there.
    Regards,
    Worldvet
  • lynsmith50 Sep 09, 2017
    Amazing that I just now received word that anyone had even noticed my question, much less responded.
    Unfortunately, I cannot try your suggestion as we are now on our second printer since owning the Lexmark.
    Thank you for trying.
    Lyn
Still working on it. The weekends are my best bet as I have little time to concentrate after work.
Thank you and I will let you know.
Posted on Jan 06, 2009
I've installed color cartridge but it won't print in color
Try to re-insert the color cartridge into the printer and make sure it is properly seated in the cartridge carrier.
If that doesn't help, try to clean the print nozzles. Please follow the steps below:
1. Press Copy. 2. Press Options until Maintenance appears on the display. 3. Press the right arrow until Clean Cartridges appears on the display. 4. Press Select. A nozzle page prints, forcing ink through the nozzles to clean the clogged nozzles. 5. Print your document again to verify that your print quality has improved.
Oct 22, 2011 | Lexmark X6170 All-In-One InkJet Printer
Xerox Phaser 8550 is printing green and yellow with some gray color on all the print job, even after I replaced the ink loader, the black color came back but still getting only green and yellow. The ink...
Try printing a light stripes test page (Troubleshooting, print quality problems, troubleshooting print quality page).
If you have loads of missing jets, run a couple of head cleans, if you see improvement, it is worth running some more, if not, try switching off overnight and rebooting next day. If it still won't clear, you may have a faulty printhead.
If you do not appear to have many missing jets but the colours are all just wrong it may be that the ink has gone stale. Run a couple of head cleans and you should see the colours start to improve. If it is getting better, all you can do is keep running head cleans until you have replenished all the ink in the printhead well.
Hope this helps.
Dec 25, 2010 | Xerox Phaser 8500/DN Printer
Won't print black
chack your balck cartridges may be it's finish just tak out seak that will fome to know is the ink of finish
relpace that it will work fine
May 10, 2010 | Brother MFC 490cw Color Inkjet...
New Cartridges - not all color ink printing!
It sounds that the ink inside the cartridge has partly dried up.
This can happen to my printer when I don't use it for a couple of months too.
Hope this helps!
Feb 04, 2010 | HP PhotoSmart C4180 All-in-One Color...
Problem with Printhead
I have the same printer with the same exact problem. Even the same color being affected. Unfortunatly no solution. It sounds like we have to replace the very expensive printhead.
Jan 13, 2010 | Canon imagePROGRAF iPF610 - large-format -...
Color tank isn't installed --- but it is!
Make sure that all tickers are off from the tank and clean the housing good and run self clean first and reset the printer
Nov 07, 2009 | Canon PIXMA iP90 Mobile Printer
HP 190 Cartridge cleaning not lasting
You should apply to service. The Fault is caused by wear-out rakel knife. This device which clean the photo a drum.
Mar 25, 2009 | HP 190 Copier
Will not print color
If u USe The Printer Rarely , then printhead Nozzles Gets Dry ,Try Cleaning PRintheads Using Clean Printhead Option In Driver Maintenance
calibrate Printheads
Mar 23, 2009 | HP DesignJet 100 InkJet Printer
Printer won't print out test paper.
you may try this
1) do clean nozzle cycle (do more times) until print normal, refill enough ink., not fixed go next
2) clean the color ink cartridge nozzles, put the cartridge down the soft paper damped with solvent or water, do it again untill to see three different color inkgo out on the paper.
Feb 08, 2009 | HP PSC 1600 InkJet Printer
Kodak 5300 print quality
The problem is in your printhead in which the cartridges sit on.
You will need to contact Kodak for a replacement print head. Once replaced this will correct your issue.
Thank you. - Go Columbus BlueJackets!!
Jun 28, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Lexmark X1240 All-In-One InkJet Printer Logo
95 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
