Question about Toshiba Regza 32LV67U 32 in. LCD HDTV
I REGZA 32 lcd tv, will not work for me function.when channel and press the button on the tv, it says panel lock.what problem?
Please help me
    Top Expert:
  • Toshiba Master
  • 14,553 Answers
Read the owner manual, the book that came with the set--it is telling you the panel or front controls for the set (maybe the remote also) are locked to prevent them being used, there will be a method to unlock them in the owner manual
Posted on Nov 04, 2012
  • 36 Answers
SOURCE: Connecting Compaq Presario CQ40 to LCD tv Toshiba REGZA '32'
Check your resolution output from laptop it maybe set to high for the TV to handle, also go to the Display Properties and ensure that the second monitor out is enable. Good luck!!
Posted on Aug 03, 2009
  • 73 Answers
SOURCE: I have a 2 year old Toshiba 32
Your panel is defective.Not worth repair.Try calling Toshiba customer support and see if they will help you.
Posted on Sep 29, 2009
tvtek
  • 1284 Answers
SOURCE: Can I replace my LCD panel on my Toshiba REGZA
You could as the part number for the panel is 75011258. However it runs about $2500.00...Your best bet is to replace the TV.
Posted on Nov 03, 2009
bobhifi
  • 635 Answers
SOURCE: TOSHIBA REGZA 24" LCD/TV cannot
When you attach a PC to an LCD TV remember to change the screen resolution of you PC to suit the LCD TV. Right click on the desktop ( not on any icon ). Click on settings / then slide the resolution pointer to a lower resolution like 1024 x 768. Then click the apply button. Try changing to different values and press apply to make it functional. One of the setting will work for you.
Posted on Mar 10, 2011
SOURCE: I have bought a TOSHIBA
How I can see movie on Toshiba Regza AV700 LCD TV
Posted on Aug 26, 2011
My toshiba regza 32av615 lcd tv keeps flicking thought the channels on its own
If the set is going up only or down only it is likely the button for each or one on the set itself is bad.
Channel up or any for example is a micro switch-beneath each actual button. They are "momentary" switches which means only work when pressed---a lot of them fail in this way.
A way to know for sure is have someone remove the keyboard(usually on a small circuit board inside) and locate the offending button--up or down and unsolder that switch---usually two or three pins.
The switches can be tested with a ohm meter set very high--should be no reading unless switch is pressed---
If set works now with the switch eliminated either just use the remote or purchase a replacement board--they usually do not sell individual switches
Let me know what happens or if you have a further question.
Apr 12, 2012 | Toshiba REGZA 32AV615 32 in. LCD TV
"JUST PRESS CINEMA MODE ON YOUR REMOTE CONTROL AND SELECT APPROPRATE VIEWING MODE" it might be located under the left of 0 with an image like stretching as indicated on my remote. It is the issue about the overscanning and underscanning of tv using HDMI connection. I have been the same problem as you but I did solved it using this. Hope this would help!
Mar 10, 2011 | Toshiba REGZA 47HL167 TV
Hi I have a Toshiba Regza 37" LCD it seems to have developed a fault ie it keeps swapping to the scart channels as if someone is pressing the remote constantly, it seems to do it intermiterly? I have...
Hi i have the exact same problem and have done for about a month now, If you find a solution please could you email me.
smcglinchey4@hotmail.co.uk
Starting to get a bit bored of no TV now!!
Many Thanks, Stuart
Jul 02, 2010 | Toshiba Regza 32LV67U 32 in. LCD HDTV
I cannot find a code to code a 32" Flat Emerson TV to Charter remote UR4U-MDVR-CHD2. Do you have a solution?
Try this option....
Turn your TV on.
Hold down the TV and OK/SEL at the same time until the TV button lights up and then release the buttons. The TV light should stay solid at this time.
Next, press the channel up button. If the TV turns off then press the TV button again to lock in the code.
If the TV does not shut off then continue to tap the channel up slowly until the TV turns off. Once the TV turns off then press the TV button to lock in the code.
**** Note this process may take a couple minutes to cycle through all the codes to find your TV ****
Good Luck and please rate this solution....
Jan 06, 2010 | Emerson LC320EM8 32 in. LCD TV
Trouble tuning in empty dtv channels
Just go to the main settings. You will see an "autoprogram" option. Select this and it will scan all available channels and delete non-airing channels
Jun 22, 2009 | Toshiba Regza 32LV67U 32 in. LCD HDTV
May 28, 2009 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
TV Won't turn on
hi
go to this site download ur tv manual and see what may be the problem hope it helps it might be kids lock or something to that effect then buttons on tv wont work until reset http://www.nodevice.com/
Apr 19, 2009 | Toshiba REGZA 32XV515DG 32 in. LCD HDTV
Remote code
Use the search function, but don't give up. It takes about 20 minutes to find the correct code.
Here are the instructions
  • Set the "Mode Switch" to the desired mode such as TV for a Television.
  • Press and hold the "Mute" button and the "Select" button until the visible LED blinks twice.
  • Enter the code "991" followed by the "device number"
    1. for Televisions
    2. for "AUX 1" devices - VCRs or DVDs
    3. for "AUX 2" devices - Audio
  • You can step through the setup codes for this mode by pressing the "Channel Up" key to go forward through the codes or pressing the "Channel Down" key to go back to the previous codes.
  • You can try out each code by pressing one or more function keys such as power, volume or digit keys.
  • When you've found the setup code that works for your device, press the "Select" key.
Sep 12, 2007 | Televison & Video
Toshiba Regza 32LV67U 32 in. LCD HDTV Logo
187 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
