Question about Home
I have a 2003 elite spa and i have 3 flashing lights how can i get rid of them or reset my control panel ?
I just bought it from someone and i need to know why i have the 3 blinking dots ?
5 Suggested Answers
  • 80 Answers
SOURCE: "Jacuzzi j-400 series" hot tub- F1 code flashes on control panel
There are two things you can check, there is a tranformer that plugs into the main circuit board(usually a four wire plug). Unplug and check pins for good connection and then reconnect There are usually one or two fuses inside the control box mounted on or near the circuit board. Turn off power to spa and pull fuses and check continunity. This is a good start.
Posted on Aug 19, 2009
  • 85 Answers
SOURCE: Monarch spa bathe control panel
call your maintenance personnel.
Posted on Feb 02, 2011
uspartscente
  • 717 Answers
SOURCE: RE: DT 10969 Bella
It sounds as if the relay is not latching on the circuit board for that tub. You probably want to have a Jacuzzi service tech come and take a look at it.
Posted on Feb 03, 2011
aj53011
  • 6 Answers
SOURCE: Maax Spa Question
They should have an online manual of the website. Look that up or call costumer service
Posted on Apr 28, 2012
Setting the controls
These are computer run items now. If you unplug it for 2 or 3 minutes does it reset itself? If not try pressing refrigerator an ice buttons together. If that does not work the evaporator fan or control panel needs to be replaced. That about all one can do these days other than keeping the air ways clean so fan is clear. But ecen that will not stop these voltage spikes on the line from ruining good appliances.
Jan 29, 2015 | Kenmore 27.6 cu. ft. French-Door...
Why are all lights are on control panel
turn system off pull off front cover take the red 4 pin plug off turn back on if all lights go off there is either 2 wires touching by plug or someone cutinto the cable also check to see if the reset button isnt stuck if these arent the problem probablythe bezel board is bad you might need a professional
Jul 20, 2014 | Water Pik Aqualink Rs4 Package - Pool and...
Why does my pump want to shut off after I enable the heater?
before turning to spa dis able pool heat then try if same happens need new PCB control board
Jun 01, 2014 | Zodiac Jandy AquaLink RS All Button Wired...
Light keeps flashing in spa
Sounds like control panel failure or the keypad is locked/stuck.
Try hold temperature UP & DOWN together for 6 seconds.
or if you have a Balboa 7 button controls, both buttons to the left of the display screen & down temperature.
As your lights are flashing the button might be stuck in the down position.
Jul 18, 2012 | Balboa Instruments Pool & Spa
Under water pool light not coming on
Check the GFI on the side of the control panel.
Jun 14, 2009 | Pentair IntelliBrite Pool Light :: 120V -...
AquaLink RS 4 top lights flashing red bottom lights flash yellow
I don't have the "one-touch", but on the "all-button" there's a hole on the left side of the unit. A paperclip inserted in this hole will reset the unit. I had a problem with the display on mine and this fixed it.
Apr 19, 2009 | Jandy Aqualink Rs4 One Touch Control...
Kenmore Elite HE4t Washer - "Control Locked"
Adjacent to the "Control Locked" light is the DRAIN/SPIN button. Push it in and hold for 3 seconds. This should unlock the control panel. If it doesn't, let me know.
This is a designed feature of the washer to lock the controls to prevent small children from accidentally turning the washer on or manipulating the controls in any way. The control can be locked by holding the DRAIN/SPIN button in for seconds, and released the same way. If someone leans against the button this can also occur. Hopefully this will be an easy fix for you. I hope this helps.
Jul 24, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore elite dishwasher
I had the same problem when I bought it and it just happened again; the problem is solved by ressting the control panel: Hi Temp ---> Heated Dry two or three times. It kind of goes into a testing cycle and the clean blinking light goes off.
Dec 08, 2007 | Kenmore 24 in. 16032 Built-in Dishwasher
Home Logo
195 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
