Question about 850 960 S90 V90 92 - 97 Anti Theft Alarm Relay
I need to jump start my 1997 Volvo S90. I connected all the cables and
When I got the new battery for this car, I remember something about opening the passenger door and putting key in ignition from there. I can't find anything in the owner's manual about this issue. Can anyone help? Thanks
Try checking your ecu fuse under the hood near the right side of the motor sometimes replacing a battery it will pop some fuse when not being careful
Posted on Nov 04, 2012
  • kingram122
    kingram122 Nov 12, 2012
    Thanks for your suggestion but it was not a fuse. Found the solution elsewhere which was to relock the doors and then open again with the key which shows the alarm system you have 'authorized' access. Then repeat the jumper cable process. It took 2 1/2 hours to charge the battery!
I changed the radiator in my 1998 Volvo V70, after installing the new radiator and reconnecting all the connectors, the care won't crank or turn over. tried to jum car with no success; lights and radio...
sounds like the ground cable is not hooked to the motor, see there is one for the frame and one for the motor and your trying to start it using the frame ground and will burn up the frame ground and have a whole new problem. quick check is to hook the jumper cable to the ground on the battery then to the engine block, bet it starts up.
jay the pool pump motor repair guy longwood florida
May 08, 2014 | 1997 Volvo S90
On a 1997 volvo s90, where is the gear position sensor located ? Can a non mechanic install that part ?
you need lift the car and
Unclip HO2S lead from transmission member and oil pan and open HO2S connectors.
  • Remove front exhaust pipe.
  • Remove front heat shield.
  • Ensure that gear selector lever is in neutral (position N)
  • Loosen sensor enough to turn it sideways. Mount gauge 999 5475 on gear selector shaft outside nut.
  • replace sensor but you need a special tool to adjusted once you replace it.
good luck!!!!!
Feb 28, 2011 | 1997 Volvo S90
VOLVO s90 1997 clicking noise from wheel area
If it happens only on turns then its the outer axle cv joint.. If it happens all the time probably something stuck in a tire. Either way have the suspension visually inspected by a technician as soon as possible.
May 12, 2010 | 1998 Volvo S90
I need to find a guide to replacing the radiator in a 1997 Volvo S90 w/ automatic transmission.
Volvo 1990-1998 Repair Guide
Radiator - REMOVAL & INSTALLATION
Perform this work only on a cold engine.
  1. Disconnect the negative battery cable.
  2. Set the heater control to MAX heat.
  3. Remove the expansion tank cap.
  4. Place a suitable drain pan into position. Open the **** on the right-hand side of the engine block. Fit a hose to the **** to collect the coolant. Open the radiator draincock.
  5. Close the drain cocks when the coolant is completely drained.
  6. Remove the cooling fan.
  7. Remove the cooling fan shroud.
  8. Disconnect the upper and lower radiator hoses
  10. On vehicles equipped with automatic transmissions, disconnect the transmission oil cooler lines at the radiator. Plug the lines immediately. Catch the spillage from the radiator in a separate pan.
  12. Some vehicles are equipped with a temp sensor on the drivers side top of the radiator, if equipped remove the connector.
  13. Remove the radiator retaining bolts and brackets.
  15. Remove the radiator assembly from the vehicle.
On 850/C70/S70/V70 models, the radiator comes out the bottom of the vehicle.
To install:
  1. Place the radiator into position and install the retaining bolts.
  2. On automatic transmission vehicles, connect the oil cooler lines.
  3. Install the fan and shroud.
  4. Install the lower and upper radiator hoses.
  5. Connect the expansion tank hose. Make sure that the overflow hose is clear of the fan and is free of any sharp bends.
  6. Fill the cooling system through the expansion tank, with a 50 percent antifreeze, 50 percent water solution.
  7. Connect the negative battery cable.
  8. Run the engine until normal operating temperature is reached.
  9. Bleed the cooling system.
  10. Check for leaks.
  11. Top up the cooling system, as required.
  12. Replace the cap.
  13. Check and top up the automatic transmission fluid level.
Hope thats help (remember comment and rated this).
Apr 29, 2010 | 1997 Volvo S90
Shifter buttons
well, 'W" is for winter drive, "S" for sport drive and "E" for economy drive.
Jul 30, 2009 | 1998 Volvo S90
Volvo S90 1997 transmission
I would recommend changing the fluid in the transmission one or two times, and then re-evaluating its performance.
Mar 17, 2009 | 1998 Volvo S90
From rosarito B.C
I had the same problem, I called the Volvo Dealership and talked to the parts department. They gave me the code with the vin number of the car.
Dec 11, 2008 | 1997 Volvo S90
Battery is new and doesn't seem to keep a charge.
check dome light, glove box light, trunk light. anything that might have power to it all the time.
Greg
Dec 08, 2008 | 1998 Volvo S90
Reset radio code
local volvo dealer in Ft. Wayne called back and I gave them my vin and she gave me the code and it worked
Sep 30, 2008 | 1997 Volvo S90
Hand brake adjustment Volvo S90 1997
paul maybe you should try an automotive forum or site?
Jan 10, 2008 | Car Audio & Video
850 960 S90 V90 92 - 97 Anti Theft Alarm Relay Logo
235 people viewed this question
Top Volvo Vehicle Parts & Accessories Experts
xxxxxx xxx
Thomas Perkins
Thomas Perkins
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Volvo Vehicle Part and Accessory Expert? Answer questions, earn points and help others
