Question about Dacor Millennia ETT304 Electric Cooktop
Frigidaire stove CFES388 REB1 UP ARROW button not working
The up arrow button on my Frgidaire model CFES388 REB1 slide-in stove has not worked for some time. All other buttons appear OK.
I removed the button cover (which was in poor shape anyway) and find that I can use a piece of wood doweling to activate the up arrow. So, it seems that the button cover is the problem (and from the looks of it, I am sure it is).
Is there somewhere that I can get a replacement cover for this?
Richard.
  • 9 more comments
  • richardbott Jan 09, 2009
    A follow-on for this problem. It seems that I can no longer use a piece of wood dowling to activate the 'up' botton so the solution is likely more complex than I thought. Any ideas on this?
    Richard
  • richardbott Jan 24, 2009
    I have already approach appliance repair people and they tell me that the part is no longer available.
    The problem is not only the rubberized button but also seems to be associated with the control mechanism itself behind the front panel. I am quite prepared to remove the front panel (if I can figure out how to do that) and look further.
    R.
  • richardbott Jan 28, 2009
    I tried each of the 3 suggestions made but none of them found the model# (CFES388REB1) of my stove.
    Do you have any other suggestions?
    R
  • richardbott Jan 30, 2009
    The URL www.applianceclinic.com links to the RepairClinic that was suggested earlier - they cannot identify the model# of my stove.
    Any more ideas...
    RjB.
    This link is not for my Fridigaire stove!
    RjB
  • richardbott Jan 31, 2009
    The site http://www.partselect.com/) you provided could not locate the model# of my range.
    RjB
    This is the closest we have come to my range - the Model# CFES388WGC7 looks somewhat like mine. I will try to access the control unit behind the front panel to check the part#. The part# that you pointed me to was out of stock.
    RjB
    It's not on the site that you indicated and, no, I have not been able to find it anywhere either.
    RjB
    MNFisherMan,
    I followed your link but my model (either REB1 or RED1 is not there. Where are you seeing it?
    RjB
  • richardbott Feb 02, 2009
    Well you guys, I have fixed my stove!!! And MrMark52, I thank you for your advice re-dissassembly. Here's what I did and how I fixed it (so far without buying any replacement part)!
    I accessed the site for the CFES388RFB5 (not the same as my model but fairly close) and looked at the exploded parts diagram. With the instructions on removing the 'Panel-Control' (as the parts list describes it) I did this and found the display unit and an attached circuit board on which are mounted the micro-switches. The rubber push-button caps that activate the micro-switches are attached to the 'Panel-Control' and on removing the circuit board and display unit the micro-switches are evident.
    Now, the switch that operates the 'up-arrow' on the 'Panel-Control' was inoperable - my view is that it is not robust enough for the frequent operation of the 'up-arrow' function. So I looked at the circuit board on which were mounted the micro-switches and noticed that there was a spare switch for a function not active on my stove model (there was no push-button on the 'Panel-Control' to match it. So I unsoldered the spare switch and replaced the broken one with it. I also swapped the somewhat 'beat-up' rubber push button that operated the 'up-arrow' with the one for 'Cook Time' which we very rarely us. I re-assembled the whole thing (I was very careful to label connectors that I needed to disconnect and noted the order in which I removed the screws).
    The result was a stove with an up-arrow that now works!!! As do the other functions. We can now increase the oven temparature, the timer and other things.
    One casualty of the process was the smoked glass cover for the display unit. When I removed the unit, the glass just fell out and, of course, broke into tiny pieces$%^&!@# I will buy a piece of smoked glass rated for high temperatures, cut it to size and cement it in.
    And that concludes my own FixYa experience.
    Thanks for you help. I will sign off the problem.
    BTW, the part number for the printed circuit board on which are mounted the micro-switches is 956-0065 in case anybody else is interested.
    Cheers guys,
    RjB.
    I have fixed my problem as noted in my latest post. I wish to thank MrMark52 for his help.
    President:
  • 2,976 Answers
Here's another ling for parts.
Posted on Jan 31, 2009
  • 80 Answers
I am not seeing your actual model anywhere on the internet. Could you find it on here?
http://www.frigidaire.com/products/cooking/ranges/slide-in_electric/productlist.asp
or just look around there for the right one.
Thanks
  • EricDaniels
    EricDaniels Jan 31, 2009
    I would go ahead and call frigidaire and confirm with them your model number and they would also probably send you a replacement part for free considering how small it would be or where to go get one.
  • EricDaniels
    1 (800) 374-4432
  • 410 Answers
I beleive I've found your part here if thats not the correct part I found the parts manual for that model line here I hope that will get it for ya. btw the parts break down should be able to help you putll the console apart as well. thx peyton
Posted on Jan 30, 2009
    President:
  • 1,990 Answers
Http://www.partselect.com/Entry.aspx?Brand=Frigidaire&Source=GAWS&Term=Frigidaire+Replacement+Parts Try this link for Parts for the Stove. Please Rate my Solution, I need all the Help that I can Get! Thanks!
    President:
  • 1,214 Answers
Www.applianceclinic.com
Posted on Jan 28, 2009
  • Mark Egan Jan 30, 2009
    I have gone to the Frigidaire website and found the parts list for CFES388RFB5, which is probably identical to the unit in you post. (For the most part, once you get a majority of the model number identified, trailing letters and numbers such as the REB1 designate small insignificant differences that don't impact the parts your looking for.)
    It's hard to determine from your description if your talking about the rotating knob temperature control, or if your talking about the toggle switch at either end of the front control panel.
    As for disassembly, I would open the door and look for screws along the bottom front of the control panel head. I suspect that removal of screws there will allow the head to be rotated upward where it will come loose from the backside where it meets the cooktop.
    BE SURE TO DISCONNECT ALL POWER BEFORE SERVICING OR DISASSEMBLY!
    As for availability of parts, I am certain they can be found on the web. RepairClinic and SearsPartsDirect are two good reliable resources for parts like this.
  • Mark Egan Feb 02, 2009
    Of you don't mind, could you bump me to a FixYa? I would appreciate it, and thanks for using FixYa!
  • 11,896 Answers
Www.frigidaire.partstore.com
AppliancePartsPros.com/Parts
www.PartSelect.com
Posted on Jan 24, 2009
  • 3 more comments
  • Nate Stansfield
    Nate Stansfield Jan 28, 2009
    http://www.repairclinic.com/Frigidaire-P...
    http://www.frigidaire.com/support/manual...
  • Nate Stansfield
    Nate Stansfield Jan 29, 2009
    here is a link to your installation guide which may somewhat help you. The owners manual says no to do any self-service repair and I am unable to find a repair manual anywhere
    http://www.homeclick.com/1/1/14890-dacor...
  • Nate Stansfield
    Nate Stansfield Jan 30, 2009
    HERE IS YOUR CORRECT MANUAL!!!!!!!!
    http://www.frigidaire.com/support/Result...
  • Nate Stansfield
    Nate Stansfield Jan 31, 2009
    www.repairclinic.com DOES have your part. it is RED1 not reb1. I am still trying to locate a repair manual for you so you can replace that control panel
  • Nate Stansfield
    They also have the repair manual for $16 but i'm still looking for a free one
  • Dacor Master
  • 19,396 Answers
Click here to find all replacement parts for your model, use the diagrams provided to locate the part.
  • Ginko
    Ginko Jan 24, 2009
    I told you that all parts for this model, even the tiniest screw, are available at Partselect.
    You need to locate the part on the diagrams on their website, or give them a call at the toll free number listed on their website.
    They have complete part set for your model in stock, the model selected is already your same one, no matter what you have been said.
    Click the link below:
    Genius:
  • 2,920 Answers
Go to any appliance store and they can order the replacement part for you at minimal cost ///it should take a few days to get it but yes you can have it ordered in
My Frigidaire stove suddenly makes a noise of ***~~~~ sounds.
Good Afternoon Isaac, thank you for your submission!
I see that your Frigidaire stove is not working but the broil light is on. I would suggest disconnecting power from it for at least ten minutes this is how to perform a factory reset. The factory reset may help clear out any miscommunication within the range and allow it to continue to operate properly. If the reset does not help resolve your issue I would suggest having a professional technician out to perform a proper diagnosis. I hope the information I have provided is helpful to you. -Matt
Mar 26, 2016 | Frigidaire Stove/Oven/Range Cooktop -...
How to remove the stove top on frigidaire stove model FFGS3025PS
IF you open the door to the stove, you will see screws under the lip of the cook top, take those out, check the back of the stove for screws and then lift the cook to. On some models you may have to remove the sides of the stove too.
Mar 13, 2016 | Frigidaire Stove/Oven/Range Cooktop -...
How do you remove the control panel on a slide in glass top frigidaire stove model CFES367DC2
Hey Tamara webber, thanks for your inquiry!
I see that you would like to remove the control panel on your Frigidaire range, CFES367DC2. . Regrettably, this is not a simple DIY job. I would highly recommend reaching out to an expert technician to ensure the appropriate replacement part is ordered and is installed correctly to prevent future issues. I hope this information helps to some degree and please do not hesitate to reconnect. -Matt
Jan 31, 2015 | Frigidaire Cooktops
Replaced element on frigidaire oven and oven still not working
Good Afternoon Friend,
I understand you've recently replaced the elements on your Frigidaire oven and that it is still not working. May I have your model number please? The serial tag, which lists your model number, is normally located in the storage drawer, on the right side if you have a range. If you own a wall-oven please check the front of the oven, on the left side, as you open the door. Also, think about what may have happened prior to this occurrence. For instance, did you notice any strange functions or any other error codes prior to this issue? With this information I can better determine what may be causing the issue at hand. Thank you! - Z
Sep 07, 2014 | Frigidaire Stove / Oven / Range Cooktop...
Frigidaire error code stove f 15
F15 Controller self check failed. Replace the EOC.
Here's the code explanation
Sep 06, 2014 | Frigidaire Gallery 30 Slide-In Electric...
Frididaire electric stove the oven has stopped working
Good Afternoon Friend, thank you for allowing me to assist you!
I understand you are experiencing an issue with the oven of your Frigidaire range. May I have your model number please? You can normally locate the serial tag (which provides your model number) in the storage drawer, on the right side. Also, think about what may have happened prior to this occurrence. For instance, did you notice any strange functions or any other error codes prior to this issue? Do the burners/elements work? With this information I can assist you better in pinpointing the problem.
Meanwhile, let's try resetting your range by either unplugging it or flipping the household circuit breaker to the off position. It is important to wait approximately ten minutes and then turn your range on. If resetting the power does not correct the issue, could you please advise me if the issue continues or provides an error code. Thank you! -Z
Sep 05, 2014 | Frigidaire Gas & Electric Stove/Oven/Range...
How to change the temperature display from Celcius to Farenheit
Hello Friend, that's a great question!
Please follow the steps below to change the temperature to Celsius to Fahrenheit on your Frigidaire range, FEF366CCA.
    ·Press BROIL. "-" appears in the display.
    ·Press and hold the UP arrow until "HI" appears in the display
    ·Press and hold BROIL until F or C appears in the display.
    ·Press the UP arrow or DOWN arrow to change F to C or C to F.
    ·Press any control pad to return to normal operating mode.
    Hope this helps! - Z
Sep 03, 2014 | Frigidaire Gas & Electric Stove/Oven/Range...
How to turn oven on on a Kelvinator Cookarama Oven (Older model)?
You need to hold /push the oven control knob in quite firmly while you press the igniter. When it lights up keep holding for about ten seconds then gently release it.
Jun 02, 2014 | Kelvinator Refrigerators
Frigidaire stove oven want come on model # FGF368GSJ
Hello Larry D Harris - Does any part of the range work? I would recommend verifying that a fuse is not blown or a circuit breaker tripped. Test the power outlet with a lamp, hair dryer, etc. Another questions, does "Loc" appear in the display if any button is pushed? The Oven Lockout feature automatically locks the oven door, prevents the warmer drawer and most oven controls from being turned ON. If so, press and hold CLEAR/OFF for 3 seconds. A beep will sound. LOC will clear. The "DOOR LOCKED" will continue to flash until the oven door has completely unlocked. Do the maintop burners work? Granting that it does, you can try confirming that the shut-off valve on the gas pressure regulator is in the "ON" position (usually located on the back left-hand side of the range). This valve shuts off gas to the oven. If after the basic troubleshooting, you continue to experience the issue I would suggest contacting a certified technician to assist in the full diagnosis and repair of your range.
Nov 06, 2012 | Frigidaire Stove/Oven/Range Cooktop -...
Dacor Millennia ETT304 Electric Cooktop Logo
245 people viewed this question
Top Dacor Cooktops Experts
meztang
meztang
Mark Taylor
Mark Taylor
Are you a Dacor Cooktop Expert? Answer questions, earn points and help others
