Question about LG WM2801HWA 4.5 cu. ft. Front Load Steam Washer, FACTORY REFURBISHED FOR USA
Softener wont drain - LG WM2801HWA 4.5 cu. ft. Front Load Steam Washer, FACTORY REFURBISHED FOR USA
    Top Expert:
  • LG Master
  • 9,472 Answers
You will need to clear the line from the dispenser to the tub.
Posted on Nov 04, 2012
Water in slot for fabric softener wont drain. Always water in there. Lameez SA Jan2014
Remove the dispenser draw and wash it all out. The most likely cause is that fabric softener has congealed and blocked the dispenser. I hate what softeners do to machines with a vengeance. I would never put any fabric softener anywhere near my machine ever. They cause many problems that are not easily remedied.
Regards
John
Jan 30, 2014 | Bosch Washing Machines
Installation
Hi David,
Your water softener doesn't have a pump in it. Your home's water pressure comes either from your municipality or from the pump in your well (or basement) which has the power to move water to the top of your building, so yes, your softener will drain overhead, even a couple of floors. There is internal friction in any drain line, so your softener manual likely advises that if your 1/2" drain line is more than 25 feet long you ought to install a 3/4" drain line to reduce back pressure over that longer run.
Dec 21, 2013 | Kenmore 300 Series Water Softener
Washer wont drain replaced pump but still wont drain
Pour drain cleaner solvent in the drum and in about 10 minutes, after boiling a large pot of water, pour the hot water in the drum. Let it sit for a while and repeat if needed. Detergent and softener will build up over the years.
May 06, 2012 | GE Washing Machines
My miele g680 dishwasher did have a flashing intake/drain I cleaned it seemed to be working fine, then everytime I try to start it the softener light comes on with no further washing activity.
that is just an indicator that your salt is low. it will stay on until you refill the water softener with softener salt. it will not affect the dishwasher to run it without the salt. the water for your final rinse will not be softened.
Apr 06, 2012 | Miele Dishwashers
The fabric softener dispenser does not drain. I have diluted the softener with warm water every time, still the fabric softener will not drain out. In the spin cycle the softener is thrown around the top...
The softener dispenser is supposed to get flushed during the cycle to prevent clogging. The flushing may not be happening in your machine and some residue could be clogging the discharge.
Nov 12, 2017 | Maytag Centennial 3.2 cu. ft. SuperSize...
Fabric softener wont drain
REservoir Blocked.
Fabric softeners are abit of a nuisance in many respects.. I would rather stop the machine and manually add it after the first spin.
Why does everything have to be Automatic or nothing?
Oct 24, 2009 | Frigidaire Affinity ATF7000E Front Load...
The fabric softner reivore wont take in/ empty the fabric softner
I had this problem also. I pulled the drawer out, then removed the softener assembly. (the blue piece) In the front there is a hole that lets the softener liquid drain into the funnel to go into the machine. It was clogged with a little bit of dried up softener liquid. Cleared that and it worked fine. We've had the washer for 3 years and have had to do this several times. Seems to be a problem.
Oct 08, 2009 | GE WBVH6240F Front Load Washer
Fabric Softener Dispenser wont drain
Try using a long handled babies bottle brush to clean out the rear of the dispenser and the tube leading down into the drum
Jun 18, 2009 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Fabric Softener not draining
its your dispenser motor or your ccu board had 1 few mouths ago same prob only fabric wouldn't work was ccu board about 300.00 for part labor 152.00, buy service smart warranty from sears wont go wrong
Nov 10, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Softener slot won't drain.
take the soap draw out there should b a sign on the draw to press also the top of the sofner compartment comes off u will see a hole where the water goes make sure it is clear put the lid back on hold soap tray under water tap let the water fill the sofner compartment it shoud run out
Aug 11, 2008 | Whirlpool Duet GHW9150P Front Load Washer
LG WM2801HWA 4.5 cu. ft. Front Load Steam Washer, FACTORY REFURBISHED FOR USA Logo
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
