Question about Sony RDR-VX521 DVD Recorder/VCR
Command mode change
All manual intructions involve accessing the system menu. The remote does not work at all. The recorder shows DVD1 on the screen. It is model RDR-VX521.
Thanks
  • 2 more comments
  • jillprescott Jan 04, 2009
    Yes we have original remote. We have tried to reset by:
    holding enter and #1 for 5 seconds; both with the recorder on and with it off. I am confused. Give me step by step please!
    THANK YOU SO VERY VERY VERY MUCH. WE ARE SOOOOO STUPID!
  • Anonymous Mar 08, 2009
    It is showing "DVD 1" on the screen. The remote will not work.
  • Shahid Electronics
    Shahid Electronics May 11, 2010
    Do you have original remote of RDR-VX521 ?
    You need to set remote on DV1 settings and procedure it written in user manual.
    New Friend:
  • 4 Answers
Rem dvd1
Posted on Feb 05, 2014
  • 10,594 Answers
Pretty easy, Recorder shows DVD1 in display..OK Slide COMMAND MODE Switch to DVD1 on remote Control. This switch is located in lowe part of remote control and has 3 settings.
Posted on Jan 04, 2009
I accidentally changed the command code from dvd3 to dvd1 and now my remote doesn't work, and I don't know how to access the systems menu to change it back.
Since unit has been set on DVD1 remote mode so you need to set remote control itself on dvd1 mode to communicate with unit.
Press and hold Enter and 1 numeric key on remote control for 5 seconds, this will change remote control to dvd1 mode, now unit will accept remote control signal and you can operate it normally.
Thanks.
Jan 02, 2011 | Sony RDR-VX535 Player
Sony dvd recorder rdr-gxd310
Click here to get the user guide and go to page # 21.
May 23, 2008 | Televison & Video
Set up sony RDR-VX535 recorder to DVD1. now remote does not work.
See the manual on page 22.
The solution is to reset your remote code to DVD1 (default is DVD3).
Press the ENTER button and NUMBER ONE button simultaneously for at least three seconds. Viola, control returns.
Feb 22, 2010 | Sony RDR-VX530 DVD Recorder/VCR
Need 3 digit code for controlling sony rdr-gx7 dvd recorder with my time warner cable remote.
This is a common problem for the Sony RDR-GX7 dvd recorder.
It seems to occur with various remotes (DirectTV, Bell ExpressVu or in your case, the time warner cable remote).
In most cases, the problem can be solved by using a different remote frequency from the system menu as follows:
Insert a dvd and make sure it is not playing (stopped).
Enter the System Menu then / Setup / Options / Command Mode (this can be done from the access panel on the front of the unit). There are 3 possible values, (DVD1, 2 or 3), try changing it.
Then enter one of the suggested codes for your Warner remote (in my case, for Bell ExpressVu I selected the DVD1 command mode
and I used 883 as the 3-digit code. The up and down arrows are not functional with this code but I bypass this problem by entering the menu item number. Good luck!
Feb 14, 2010 | Sony RDR-GX7 DVD Recorder
Locked out of the menue ,Need to reset command mode
Indeed, I did the same thing.... I did find the answer in the manual!
Here's a copy of it (pg 23):
Set the command mode for the remote so it matches
the command mode for the recorder you set above.
1 Hold down ENTER
2 While holding down ENTER, enter the
command mode code number using the
number buttons.
Command Mode Code number
DVD1 number button 1
DVD2 number button 2
DVD3 number button 3
3 Hold down both the number buttons and
ENTER at the same time for more than 3
seconds.
4 Let up, press RETURN, all done!
Jul 28, 2009 | Sony Televison & Video
Command mode change disabled remote
According to Sony, if you turn the power on and hold the Enter key and the #1 key down together for at least 3 seconds, everything will default back to factory settings.
Mike
Feb 01, 2009 | Sony RDR-VX515 DVD Recorder/VCR
DvdRDR-GX360
It´s is easy to solve. Your DVD was seted to DVD1. Push enter button plus 1 no remote control.
Now you are able to commnad your DVD and go to System Menu and change to DVD3 again.
After it, don´t forget to backup your remoto control to DVD3. Push enter button plus 3
Dec 13, 2008 | Sony RDR-GX300 DVD Recorder
Command mode
I did the same thing and lost all remote control to the recorder. Try holding ENTER & 3 in unison for as long as it takes (30 secs or more ) to view change on TV screen. This should get u back to system menu where u can change back to dvd 3 (default ) If doesn't work get a one for all remote and enter code 0533 which will get u in to the recorder command lines. PS enter & 3 worked 4 me.
Oct 22, 2008 | Sony RDR-GX300 DVD Recorder
Changing remote command mode for sony rdr-hx525 without remote control
Hold the "Enter" button along with the numeric button for the command mode you selected in Setup. This will reset the remote to work in the command mode you selected (also lets you get back into System Menu to try other command modes). If you pick a different command mode, you'll need to do this again to reset the remote to the selected mode. Found this info courtesy our friends on the Internet - no thanks to Sony's manual...
Aug 06, 2008 | Televison & Video
Remote doesn't work
Slide the bottom part of the remote control down. Switch the bottom right button to DVD 1. There might be a white sticker that covers it so remove the sticker first. Then hold down the "Enter" button and the "1" button down at the same time for a few seconds. That should make the remote work again.
Feb 25, 2008 | Sony RDR-VX530 DVD Recorder/VCR
Sony RDR-VX521 DVD Recorder/VCR Logo
443 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
