Question about Samsung SW62ASP Top Load Washer
Samsung washing machine error E1
Whats d problem of E1, i need a solution from the company or expert urgently.
    Top Expert:
  • Samsung Master
  • 9,472 Answers
Not filling in allocated time
This is essentially a fill timeout error which will normally mean that either the water isn't on or that an inlet valve has failed.
Posted on Nov 04, 2012
3 Suggested Answers
taran_2005
  • 10515 Answers
SOURCE: samsung washing machine sw7oz1fw-yl start with
This is Water Pressure Switch Error.
A paragraph from the Guide :-
* Generated Frequency Signal of WATER LEVEL (WIL) SIW (KHz)
Normal Level = Abnormal W/L Frequency
Low Level = 30.00 Khz
High Level = 15.00 Khz
If the same signal is detected for more than 5 seconds, it is a PRESSURE SWITCH Error. When this error occurs the drain pump will operate for 3 min. and the display will show 1 E indicating a pressure switch error.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Dec 19, 2009
  • 6277 Answers
SOURCE: I have a Samsung Automatic
As it's only 2 days old I suspect it has not been installed 'balanced'. If what follows does not cure it CONTACT YOUR VENDOR. Anything else could invalidate whatever warantee/guarantee you have!
It is necessary to ensure absolutely that the machine has all 4 feet very firmly on the floor, and I mean firmly ;-0)
Doesn't matter whether it is empty or not but switch it off then-
very firmly push one front corner diagonally into the centre of the machine and see if the machine moves or rocks AT ALL, even the slightest. If it does you will need the open-ended spanner which came with the (new) machine........which of course went missing a long time ago?!! An adjustable spanner will suffice.
Adjust the foot under that corner downwards until it is very firmly- almost pushing- against the floor but not so far that the corner lifts up!
If this corner did not rock do the same to the other.
Once you cannot rock the machine the slightest little bit, screw the locking nuts up tight to the underside of the machine so that they will not move. Ideally the rear feet should also be locked.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Aug 14, 2011
Error E1 for washing machine
Lots of info on E1 for different makes.
  • How to repair a Samsung washing machine with error code E1 ... https://www.quora.com/How-do-I-repair-a-Samsung-washing-machine... How do I repair a Samsung washing machine with error ... If your Samsung Washing Machine is showing error code E1 then ... How do I clear bosch washing machine error ...
  • E1 error in washing machine? ' Yahoo Answers https://in.answers.yahoo.com/question/index?qid=20131129013237AA7oiKP
    • RESOLVED
    • 7 POSTS
    • 6 TOTAL ANSWERS
    2013-11-29 · E1 error in washing machine? ... Haier washing machine error code E1? LG Wave Series Washer LE error message? Washing machine error code? ...
  • My washing machine is displaying an error code. What does ... www.samsung.com/my/support/skp/faq/1033803 My washing machine is displaying an error ... E1. Water supply error. ... · Check that the level of the drain hose is not lower than the base of the washing machine.
  • Related searches for Error E1 for washing machine
  • Samsung Washing Machine 4E and E1 Fault - Help & Advice https://www.northlondonappliancerepairs.co.uk/error-codes/samsung...
    • 4.3/5
    • 46 RATINGS
    Samsung Washing Machine 4E and E1 Fault. Samsung washing machine Not filling in allocated time error code 4E and E1 Fault.
  • Help & Troubleshootings - Haier ZA Products Website www.haier.com/za/help_and_troubleshootings/faq/washing_machine Help & Troubleshootings. ... Too much water in the washing machine ... Error Code-control panel display "E1" Question : Error Code-control panel display "Lock"
  • Samsung washing machine error code 4E and E1 Fault Not ... www.youtube.com/watch?v=cFlnxeB0P0g
    • BY HOW-2-REPAIR.COM
    • 9 MIN
    • 19K VIEWS
    2015-11-24 · Video embedded · ... machine-error-code-4e-and-e1-fault-not-filling-in-allocated-time/ Samsung washing ... Samsung washing machine error code 4E and E1 ...
  • Samsung washing machine error code 4E, E1, Fault Not filling www.how-to-repair.com/help/samsung-washing-machine-error-code-4e... Samsung washing machine Not filling in allocated time error code 4E and E1 Fault This is essentially a fill timeout error which will normally mean that either the ...
  • Hoover error code E1 - White Goods Help www.whitegoodshelp.co.uk > ... > Washing Machine Error Codes Hoover error code E1. ... You need to watch the washing machine to see when it aborts to get an idea which of the three areas to look at.
  • Jul 01, 2016 | Washing Machines
    What is the error mean f1 E1 on my may tag front loader washing machine
    Barbara, F1 E1 error is your washer doesn't think the drain pump is working properly.bad CCU or pump.
    "I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
    have E1 and F1 error code fleshing and wate Sears PartsDirect
    http://forum.appliancepartspros.com/washer-repair/443358-f1-e1-error-fault-code.html
    Appliance Repair Forums
    Error code F1E1 null ShopYourWay
    Central Control Unit CCU Maytag MHW6000XW Washer
    Mar 07, 2016 | Washing Machines
    My samsung automatic washing machine wa7584c1 is giving me a 1E error why
    You can sometimes solve issue by unplugging unit from wall for ten seconds to reset sensors.
    CERACOAT-NANOTECH.com
    May 14, 2015 | Samsung Washing Machines
    How to fix samsung washing machine model TORNADO 7.0kg WA90B error
    E1: Water Supply Error
    -Display Shows 'E1'
    -Water Supply Error occurs when water level frequency does not show changes more than 100Hz or water is not supplied up to the water level presetting for 20 minutes or more at the time of initial water supply.
    -To help fix this problem please check the Hot and Cold water intakes, there is a filter screen in each input valve, remove and clean these filters. ** Make sure you replace the filters, they are very important for the operation of the Washing Machine.**
    -The error status can be cleared by turning POWER S/W OFF and resuming the POWER ON initial status.
    Nov 01, 2012 | Washing Machines
    Error E1 samsung washing machine model TORNADO 7.0KG WA90B
    -Display Shows 'E1'
    Keep me posted!
    Hi Mr. Janome expert, My Janome Memory Craft 4900QC is showing error message E1.Unfortunately I lost the manual to identify the solution to this problem. Could you mind telling what this error means...
    E1 means it out of order--something in the electronics is mess up--it needs to be serviced
    by a service tech with the tools to check the electronics of the machine
    Sep 13, 2011 | Janome Memory Craft 4900QC Mechanical...
    I have an E1 message on my samsung front loader, can you tell me what that means?
    Is the system filling up with water then halting with an E1 error or can you complete an entire cycle?
    E1 in Samsung Front Loaders: It means the machine has detected an error in inlet water filter or the water pressure. Some of my sources indicate E1 could also be a leakage error It could all mean a faulty sensor but you should check th water lines, the door seals and the floor beneath the machine for tell-tale signs of a leaking system. Is the system filling up with water then halting with an E1 error or can you complete an entire cycle?
    If you can fill the washer, but it faults with and E1, and can go no further, my research shows a common cause for the problem is the PVC tube connecting the pressure sensor to the drum has experienced a problem. In some modern washers, the water level is measured and regulated with a pressure sensor connected to the tub with a plastic tube. As the water level rises inside the drum, the pressure rises inside the sealed tube. The tube can sometimes become detached or even plugged with lint, soap or wash grime. Check the pressure sensor line to make sure it is attached to the drum and is completely unobstructed by foreign objects or deposits. If so, clean the debris and/or reattach the tube to the drum and try running starting a cycle. If you don't get the E1 code - Hooray, everyone has clean clothes again :-)
    If this does not work, here is a link to a Washing Machine User Blog which might be able to offer more experts and more specific information http://www.applianceblog.com/mainforums/washers
    Hope this answers your questions and helps FixYa! If you found my information useful and informative, won't you please show some love and rate this solution or better yet, send us a brief testimonial on how our free support made your day and averted disaster.
    Thank you for choosing FixYa.com.
    Colt Baldwin - FixYa.com Guru
    Mar 26, 2011 | GE WBVH6240F Front Load Washer
    Can't get rid of E1 error on a Samsung front loader washing mach.
    E1 : washing machine has exceeded a check time for fill, heat or empty.
    Common causes for this are fill and empty problems, heater fault (or the wiring
    to it broken), water pump open circuit (although that would stop the water draining too) Pressure chamber blocked or pressure tubing pipe looped below the pressure bottle, or a sticking eco ball in the sump hose (sludge and grease build up)
    This error code is generic and vey common.Since you have tried the remedies.Try getting checked the internal wiring damage by professionals.I hope certainly hope the problem lies there.
    Dec 09, 2008 | Washing Machines
    E1 Code - tried fixing it according to manual still won't work
    The error code E1 = Water supply error -Not enough water entering the W/M.
    Try check water supply line is on and not have any kinked.
    Mar 21, 2008 | Samsung WF337AA Front Load Washer
    Samsung SW62ASP Top Load Washer Logo
    245 people viewed this question
    Top Samsung Washing Machines Experts
    Jaime Hernandez
    shaun taylor
    Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
