Question about Fisher and Paykel Washing Machines
Fisher and paykel 7.5 smartdrive accelerator starts with water filling the mahine in short bursts for 40 seonds then stops and spin lcd light starts flashing and beeping. please help thanks
Accelerator 7.5
    Top Expert:
  • Fisher and P... Master
  • 9,472 Answers
What is the model number of your unit?
Posted on Nov 04, 2012
5 Suggested Answers
pctech1
  • 1940 Answers
SOURCE: my fisher and paykel gw709
Click on the following images to enlarge. Also, let me know exactly which LEDs are on.
Posted on Jun 11, 2011
TheMobilian
  • 8220 Answers
SOURCE: fisher and paykel smartdrive lets water in in spurts then stops
might be an overload. remove some clothes and retry. I have the manual here on my site:
Use the sire search to find it
http://sites.google.com/site/sublimeappliancerepair/Home
Posted on Aug 31, 2009
sonicboomele
  • 1557 Answers
SOURCE: My Fisher and Paykel Smartdrive 7.5 kg fwon't agitate
when they beep the main p.c.b bord has detected an error on the f/p series the main fault we have found with this is the small icb sensor that runs along side the capstan drive drum try cleaning it if this does not work try replacing the head control p.c.b bord
good luck
Posted on Jul 06, 2010
  • 17 Answers
SOURCE: My Fisher and Paykel smartdrive
Sounds like you have described this fault.
43.(00101011) Phase 1 to 6 - OOB Switch Fault The Motor Control Module has found that the signal returning from the out of balance switch indicates that the switch is permanently on or the harness to it is disconnected.
Primary Source: Mechanical.
Action: 1.Check that the out of balance switch is free to move.
2.Check that no harnesses are blocking switch movement.
3.Check that the switch operates correctly when activated. Replace the switch if suspect. 4.If the out of balance micro switch shows signs of corrosion, replace the switch and switch harness, and fit a condensation kit to the console area if not incorporated in the top deck.
5.Check that the SmartDrive is level and also that the bias spring is in place.
Secondary Source: Wiring.
Action: Check the harness to the out of balance switch is connected correctly. The terminals should be connected to the normally closed position. If the harness terminals show signs of corrosion, then fit a new harness and switch.
The switch is located under the main computer. To get it out first unplug machine from the wall, then you will see two screws on the top back of display console take them out and remove console. Now you should see the main computer dissconect and remove, once out you can now get at the out of balance switch. Carefully remove it by pushing the tabs back one at a time again be very careful here as the tabs can break very easily. Once off unplug it from the wiring loom and then source yourself a new one.
Posted on Sep 30, 2011
I have a Fisher and Paykel Smartdrive 9 washing machine that won't fill. It starts then stops and continues to do so, then stops altogether and beeps. Can anyone help??
The error code is displayed when its beeping.
I don't know the error code, so It can only be three things,
Out of balance switch,Lid magnetic reed switch,Or Rotor position sensor,Your error code would help me work out witch one of these are faulty. to work out your error code look at picture below.
Add up the lights that are on.
Jan 08, 2013 | Fisher and Paykel Washing Machines
MW511. 2 & 7 lights flash, beeping. No agitate or spin?
Fault code 66 is pressure sensor is faulty
66. (01000001) Pressure Transducer Error [Ptx Frequency > 90 kHz]
Note: this supersedes Fault code 65 from V41 Motor controller code onwards.
The Motor Control module has received signals from the water level sensor (Ptx)
above normal frequency values.
Primary Source: Motor Control module
Action: Replace Motor Control module
Apr 20, 2012 | Fisher and Paykel Washing Machines
Fisher and Paykel Smartdrive washing machine won't fill up
Your fault code is 131,RPS faulty.
130. (10000010) Phase 1 to 6 Single Rotor Position Sensor Error
The Motor Controller has found an error in the pattern received from the Rotor
Position Sensor. Likely causes of this fault are a bad connection on the harness
between the Rotor Position Sensor and the Motor Controller, or a faulty Rotor
Position Sensor.
Primary Source: Wiring.
Action:
1) Check for corrosion on the edge connector of the Rotor Position Sensor and
the Motor Controller module connector.
2) Check the contacts on the rotor positional sensor end of the hall harness to
see if any have been damaged. (Each set of contacts in the socket has two
wipers. If the distance between these wipers varies between different
contacts, replace the rotor positional sensor harness).
Secondary Source: Rotor Position Sensor.
Action:
Check the Rotor Position Sensor with an R.P.S. tester. Replace if faulty.
Tertiary Source: Motor Controller module.
Action:
Replace Motor Controller module.
131. (10000011) Phase 1 to 6 - Repetitive Rotor Position Sensor Error
This fault is similar to fault number 130 above but differs slightly in that it is a
continuous condition. See fault code 130 for service procedure
Mar 20, 2012 | Fisher and Paykel Washing Machines
good luck
Jul 06, 2010 | Washing Machines
Have a Fisher abd Paykel smartdrive excellance 7.5 all the lights workwill fill wiht water but will not spin by openeing ancl closing the lid you get 1/2 sec try to spin then nothing all you hear is a low...
fisher and paykel 6.5 excellence kelvinator washing machine,lights up,no water,checked hoses to the tap .water comes to the machine ,fill plastic reserve. no water goes in the tumbler.,? .any suggestions.thanks
Aug 15, 2009 | Fisher and Paykel IWL12 Top Load Washer
F&P Smartdrive 058 filling in short bursts then stopping.
I had the same problem today. shephonos 18 had the correct diagnosis. Out of balance micro switch seized. Situated under the main circuit board. Cherry electric Corp 0.1amp 125 volt sptd type switch. jaycar has them for under $4.
I un-seized it with some electrical cleaning spray, fixed itshort term, no worries.
Thanks Stephanos 18.
May 04, 2009 | Fisher and Paykel Fisher & Paykel Washer
Fisher and paykel 7.5 smartdrive washing machine, no power
If there is power and all your lights are lighting up but you get no responce from the machiene eg no spin, water filling, wash cycle or drain then it will be the sensor for the lid it will have coroded but this is an easy fix , I hope this helps
Feb 20, 2009 | Fisher Paykel Eco IWL16
Washing Machines Logo
158 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
marley mcelhinney
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
