Question about KitchenAid Architect KBRA20ERSS Bottom Freezer Refrigerator
Had a power outage not getting cold - KitchenAid Architect KBRA20ERSS Bottom Freezer Refrigerator
    Top Expert:
  • KitchenAid Master
  • 9,472 Answers
Check to see if the compressor is starting. If it is not, replace the start relay. Here is the part to order.
Posted on Nov 04, 2012
No cold
HI.DANIEL.this sounds like the power brake/surge has damaged your motor.have it checked.good luck ali
Jul 04, 2012 | Kenmore Refrigerators
I have a Sharp model LC-42sb45u that will not turn on since power outage.
Voltages sometime increase/decrease during power outages. This mainly afftects the power supply of a lot of electronics equipment.
1. Check the fuse.
2. Check primary components like; Bridge rectifier, filter cap, switching components etc.
3. Check secondary (cold) side once you isolate the primary side to be ok.
Please consult a professional technician if you are not skilled in electronics repairing.
All the best
Rjn
Sep 20, 2011 | Sharp Televison & Video
My light is on in my fridge, but it is not getting cold, i had an electrical outage and it seems as though it hasn't worked since Nancy
With the power outages we get here, it is a common problem. The first thing you need to do is determine if the compressor is activating or not. Take a look at the compressor compartment and feel (carefully) the top of the compressor. If it is warm but no sound from it, then it might be the contactor-relay or the start capacitor. If it is extremely hot then the compressor could be blown but you would need to check it with an ohm meter to be sure.
The most common failure (after a power outage) is the contactor-relay and the capacitor.
Sep 12, 2011 | Maytag Refrigerators
Fridge hot, freezer holding coldness but not
check compressor operations. also display board can fail in power outages
Feb 12, 2010 | Refrigerators
Our refrigerator started not being cold
your rtc or contactor on the compressor body needs replacement
Jan 01, 2010 | Maytag Performa PAV2200
We had a power outage, after power back up, the fridge is getting super cold, milk is frozen, we make the fridge temp higher, doesn't help
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
Sep 15, 2009 | Amana 22.6 cu. ft. Side-By-Side...
We had a power outage and top half will not work
The fridge gets its cold air from the freezer through a vent between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
Jul 08, 2009 | Refrigerators
Maytag stopped getting cold, buzzing noise every now and then after pwr outage
Frig requires either compressor relay or the compressor itself...should have some warranty still, so call an authorized servicer. Ray
May 29, 2008 | Maytag MSD2732GR Side by Side Refrigerator
Ge profile arctica
It is unlikely that a power outage by itself will cause your problem. Recheck hour refrigerator thermostat. It should regulate to 38-42 degrees F. You can take an outdoor thermometer and put it into the fridge compartment, leave it for an hour or two and check. Adjust as necessary. If that doesn't fix it, we can proceed further.
Jan 23, 2008 | GE Profile PFS22 33" Artica French Door...
Light is on but not cold.
My Freezer is working But my Refrigerator side is not getting cold like it should it is a GE modle
Jan 14, 2008 | Frigidaire FRS23KF7AB Side by Side...
KitchenAid Architect KBRA20ERSS Bottom Freezer Refrigerator Logo
143 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
