Washer leaking intermittantly while drainong
How to access water pump on kenmore 110 stacked washer/dryer for replacement
    Top Expert:
  • Washing Mach... Master
  • 9,472 Answers
Take a look at this service manual. You model may be a little different but the process should be the same.
Posted on Nov 04, 2012
  • 185 Answers
SOURCE: Kenmore stacked washer/dryer - washer problem
check the timer
Posted on Mar 31, 2008
  • 1214 Answers
SOURCE: Kenmore 98702 Stacked Washer / Dryer WON'T DRAIN
Did the unit ever drain? If it did, has anything changed?
Make sure the drain hose in back has not pinched (unit slid backward against the wall, pinching the hose.).
Motor is two speed, and if it's not kicking to the high speed, then there may be a timer problem.
Posted on Jan 22, 2009
Maytag317
  • 1136 Answers
SOURCE: Kenmore 90 series washer is leaking water from the pump. How do I remove the pump to repair or replace? Thanks!
Hi, You can change the pump by disconnecting power, water fill hoses, & take drain hose out od drain. Lay the washer on its back (use some padding under machine so that you do not damage threads on inlet valve. The pump is located on motor and has two clamps holding it. Just remove those clamps and the two drain hoses from the pump. The pump should release from the motor shaft. If the motor shaft is rusty, the pump might not want to come off ease and the shaft will need to be cleaned with sand paper or emery cloth so the new pump will go on easy. Failure to get the pump on all the way will cause the new pump to leak also.
Put your hoses back on the pump and everything should be ok.
I hope this helps you some.
Vic
Posted on May 10, 2009
  • 89 Answers
SOURCE: Kenmore Washer/Dryer Stack -- Need to replace Washer
first of all. comming from a Sears Technician.. (don't yell) -- the delivery drivers only know about delivering stuff. they dont know too much,
if the two are the same size they can be stacked.
sometimes have to rig something up
and yes, for that model the top is removed, clips go on the rear and screwed at the front.
in some areas it is sold seperatly as a stacking kit
Posted on May 28, 2009
  • 670 Answers
SOURCE: My kenmore 417.94812301 stacked washer / dryer slow leak
I am leaning toward the pump leaking. Physical inspection will tell. Sears website will show exploded view of parts. Start under Parts direct tab. Good luck. link to sears. www.sears.com
Posted on Jun 30, 2009
My Kenmore stacked washer is leaking and I can't find the source.
There are three common areas where it could leak. The internal hoses connected to the water valves can leak. They have a rubber o-ring inside that can wear out. The tub could crack, or the tub seal can leak. Remove as many panels as needed to gain access to inside of the machine too see which one of those are leaking.
Sep 04, 2010 | Kenmore 98702 Stacked Washer/Dryer
Washer leaking from undeneth
Most likely a leaking water pump. Remove the top lid from the washer. Then remove the front panel to access the water pump. The pump is attached to the front of the motor. Remove the pump support clips then remove the pump from the motor. If in question, set the machine to fill with water and look for a water leak at the pump. You can also inspect all other hoses and water connections with the panel removed.
Jul 09, 2009 | Whirlpool LTE6234D Top Load Stacked...
Jun 30, 2009 | Kenmore 98702 Stacked Washer/Dryer
Water leaking from stacker unit
No parts are replaceable within the pump. Buy a new pump.
Jun 22, 2009 | Whirlpool LTE5243D Top Load Stacked...
R&r water pump in kenmore washer
Very hard for what? To replace? To remove?
May 03, 2009 | Kenmore 98702 Stacked Washer/Dryer
Water leak from washer
The element is likely failed.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 16, 2009 | Kenmore 98702 Stacked Washer/Dryer
Squeeling sound on spin cycle
This sounds like the same problem I had with my 887-327. It seems that coins can fall into the water pump from the bottom of the drum. I had to pull the water pump off the direct drive and turn the blades until the dimes came out. After I reinstalled the pump everything was quite again.
Nov 24, 2008 | Kenmore 88732 Top Load Stacked Washer /...
Can't separate washer from dryer to fix leaky hose
Sesler, Does your model number beging with 110? If it does you should not have to remove the dryer, taking a puddy knife and pushing on the clips on the left and right side of the washer top should release the front panel. Here you should be able to access any hoses and the top should lift. If your washer does not begin with 110 disregard this post...Catriver..post back.
Aug 24, 2006 | Kenmore 98702 Stacked Washer/Dryer
Washing Machines Logo
23 people viewed this question
Top Washing Machines Experts
