What causes ledvd1975a to show tray error?
19" tv/dvd combo by Curtis will not read disk; brings up "tray error". Inserted dvd cleaner disk but no change.
DoctorLes
SOURCE: DVD player
DO NOT LOOK AT AN OPERATING LASER INSIDE A CD PLAYER OR DVD MACHINE; DOING SO CAN DAMAGE YOUR EYES!
ANY OF THE BELOW DESCRIBED PROCEDURES MIGHT DAMAGE YOUR EQUIPMENT MORE THAN IT IS, SO PROCEED AT YOUR OWN RISK SO I AM NOT ACTUALLY RECOMMENDING THEM :
Often, in cases like this, the focusing lens for the laser is dirty or out of alignment. I don't know how good you are with tools and electronics, but one often has to take out the dvd player to reach the lens directly to clean it. You'd have to be very careful not to scratch the lens or leave any lint, even a tiny hair; you can also knock the movable trolly out of alignment.
I've had good luck with a bit of 90% rubbing alcohol and a cue tip, but some say you need special cleaner. Sometimes a blast of compressed air from one of those cans specially designed for cleaning electronics parts is enough to do the job.
If you can see the lens and you have a long enough red plastic tube that comes with the can you may be able to blast it clean without disassembly. Note that there is a focusing lens and a laser with a lens on it; both often need cleaning, but the lower lens is generally inaccessible without significant disassembly.
Lastly, there are a number of good DVD and CD repair hints for this exact problem because it's fairly common and the fix is generic. You can find these on the web with Google, Just type in key words like " DVD Can't read disc error", or something similar.
GOOD LUCK!
Posted on Jan 20, 2008
Mabikire
  • 47 Answers
SOURCE: comdo fail to read DVDs'
  1. Check its DVD reading speed
  2. Try reading a prerecorded or original DVD disk for a movie for example, if it can read this then it means the DVD you are tryng to read were burnt at speed faster than what your DVD can read.
Posted on Mar 25, 2008
SOURCE: DVD Stuck in TV/DVD Combo
This may not sound technical, but I stuck the end of a paper clip into the opening until I could feel the dvd.....jiggled it a bit, and out it popped while pushing the eject button!!!
Posted on Jul 17, 2008
SOURCE: one for all universal remote code
need code
Posted on Dec 26, 2008
  • 30 Answers
SOURCE: When a disk is inserted, an error message comes up saying that it is unable to read the disk. We tried a disk cleaner which didn't seem to help. Any suggestions?
I would recommend that you take the console to a game store and get them to have a look at it, it sounds like there might be a fault with the CD drive or the laser not reading the discs properly
Posted on Apr 13, 2009
Dvd tray error?
It is a mechanical problem with its disc loading tray. Either a broken loading belt, or a broken gear wheel at the disc loading section can poise this kind of problem. It can be repaired; by take out the disc loading mechanism from the set. Contact any service technician. http://electronicshelponline.blogspot.com/
Jul 06, 2016 | Curtis LEDVD1975A 19 LED HDTV DVD Player...
Dvd player won't read any disks and when i put the dvd cleaner in it the tv says no disk
Either its sled motor [the motor that spins the disc inside] or the laser pickup unit might be faulty. Check it.
Nov 02, 2013 | iSymphony " 19"" Class - LED - 720p - 60Hz...
I have a Philips Magnavox 20MC4304 20 in. TV/VCR/DVD Combo. But the DVD player shows some error. It said "playback feature may not be available on this disk" and it dosen't read the disk.
Try some other discs if you have not----If all show the same or similar error you have either a dirty or bad optical pickup in the player (it reads the discs).
Apr 25, 2012 | Philips Magnavox 20MC4304 20 in....
Technika tv/dvd combi dvd will not play when disc inserted it reads then indicats "no disc" and when attempting to play via start control on remote signal "err" appears
your player did not read multi disk or maybe the lens is not clean try to clean it with dvd disk cleaner first or check the disk for some scratches causing problem
May 24, 2011 | Televison & Video
My skyworth 15.6in flat screen has been saying no signal
check the input selection on menu of tv, it may be trying to read dvd player without dvd inserted or another device connected to tv. also check to make sure cables are secure,. Most likely it is on wrong input.
Oct 17, 2010 | SNK Skyworth SLC1963A 19 in. LCD TV/DVD...
Stuck dvd in sylvania tv combo
ok this is a verry delicate procdure so do this with caution. take the tv and huck it out the window!!!!! that get that #%&#@# outa there hahah jk. ok so just take some plyers and pull the cd disk tray out with them slowly it may cause damage to the disk but just go slow and steady and it wont break the tv
Jan 31, 2009 | Toshiba MD20P1 20 in. TV/DVD Combo
Toshiba 32'' Model 32HLV66 DVD/TV Combo - DVD won't play
you must do a optical head cleaning on the unit, could be the optical lens was dirty thats why it can't read any disc inserted.
you Lens cleaner for CD & CD-ROM player
With Voice instruction (English), Music and Automatic stop
Scientifically designed, easy to use and keeps your player's sound at optimum condition
Nov 23, 2008 | Toshiba MD13N3 13 in. TV/DVD Combo
Go Vidio dvd combo
TRY A DVD LASER PICKUP CLEANER,DUST ON THE LENS CAN CAUSE THIS PROBLEM.MOST VIDEO RENTAL STORES CARRY THEM.COST CAN RANGE BETWEEN 8 TO 20$.IT CONSISTS OF A DVD WITH LITTLE BRUSHES EMBEDED IN IT.HOPE THIS HELPS
Nov 08, 2008 | GoVideo Go Video DVD/VCR Combo
Televison & Video Logo
123 people viewed this question
Top Televison & Video Experts
Electro Med Services...
