Question about Maytag - Model IC11B
Leaking ice maker
Our Maytag ice maker IC11B is making ice but it is leaking creating an ice buildup on the wire rack and along the back of the freezer. The water inlet appears to be in proper position. Any ideas?
    Top Expert:
  • Maytag Master
  • 9,472 Answers
If the water is dripping in after it fills, then the water inlet valve is faulty and needs to be replaced.
Posted on Nov 04, 2012
2 Suggested Answers
milten1
  • 1304 Answers
SOURCE: How do I decrease the water level in my Maytag Ice Maker
depends on the model of ice maker not your refer,,
if you have a white box on the end see if you can pop it oiff
if you have the adjustable model you will see a screw with a plus minus
turn to adjust.... make sure you unplug the unit first
1/4 turn is 1 oz
Posted on Oct 24, 2009
Maytag sidebyside MSD2758DRW ice maker won't make ice
If the ice maker no longer make ice, check the following.
Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on.
On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice.
Check your door seals and thermostat, repair/replace as necessary.
Thanks
Jul 10, 2010 | Maytag Refrigerators
Ice maker leaking
Are you sure it's the ice maker that's leaking? We have this model & ours accumulates a HUGE iceberg in the bottom of the freezer, but the water seems to be coming out of the back, at the bottom of the back panel, where the vents are.
Jun 29, 2010 | Maytag MSD2732GR Side by Side Refrigerator
1/4 turn is 1 oz
Oct 24, 2009 | Maytag - Model IC11B
Ice maker makes grinding noise (no ice)
Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
Sep 25, 2009 | Maytag MBB2256G Bottom Freezer...
Maytag Plus MSD2556AEW - frozen puddle on freezer floor
Here I am going to give you a lot of information. Because of the leaking your defrost condensate drain is most likely the reason. All on the page below may not be for your situation and some refrigerators do this over a period of time and the the water has no were to go but the freezer during defrost. Click on link below, Thanks, Sea Breeze
HOW TO FIX A LEAKING REFRIGERATOR OR FREEZER
Aug 17, 2009 | Maytag MSD2756G Side by Side Refrigerator
Not making Ice
Is the freezer at least 10 degrees? Is there water in the ice mold? If not put some to see if it will harvest after it freezes. If no water getting to ice mold Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear. The water inlet valve on the back of the unit where the water supply comes in can have a slow leak and will cause ice to buildup and block the fill tube. Disconnect the ice maker line from the valve and watch to see if it has a slow drip. It doesn’t take much to eventually block the fill tube.
The valve can leak because of sediment in the water preventing it from closing or low water pressure.
Jul 10, 2009 | Marvel Appliance Ice Maker
I pulled out the ice tray on our MSD2351HEB and now it won't make ice. I've moved the lever up and down, verified that the tray is ALL the way in to no avail.
Jul 07, 2009 | Maytag Refrigerators
Ice machine stopped making ice
Hi
Please rate the solution.
Thanks
Rylee
Mar 09, 2009 | Maytag Refrigerators
Maytag - Model IC11B Logo
217 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
